GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Dec 27, 2023 at 9:01 AM
    #4171
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Worth giving it a shot.
  2. Dec 27, 2023 at 9:21 AM
    #4172
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Yes, unbolt the lower ball joint from the control arm, sway bar, and loosen adjustment cams on control arms. I didn’t even unbolt the lower shock bolt on the second side. Just unbolt top bolts and pull strut assembly out at top and slide in spacer. Alignment only had the toe out of spec.
  3. Dec 28, 2023 at 5:11 PM
    #4173
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    ReadyLift 2” Mickey Thompson 275/65/r20
    ReadyLift 2” level
    Mickey Thompson Baja Legend EXP
    275/65/20 stock 1794 Wheel
    Really loving this setup. Thanks to the massive info in this thread.
  4. Dec 28, 2023 at 9:39 PM
    #4174
    chrispage
    chrispage New Member
    Thought I had posted a few already.. some phone ones for now but I will get some with my camera eventually..
    Vossen HF6-3 (22x9.5) -25 on 305/40’sIMG_5787.jpg IMG_6679.jpg
    pandatss22, OC_808, Siopao and 11 others like this.
  5. Dec 29, 2023 at 4:26 PM
    #4175
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Volk TE37XT M Spec -10 offset, Toyo RT Trail 35x12.5x17, stock suspension.
    OC_808, Siopao, CYBERO24 and 4 others like this.
  6. Dec 30, 2023 at 2:23 PM
    #4176
    Welshflynavy
    Welshflynavy Flyin Jets!
    Austin
    Pensacola
    24 MGM Limited TRD OR
    295/65/20 on stock limited trd off road. No lift, no rubbing!
  7. Dec 30, 2023 at 6:23 PM
    #4177
    ScootARoot
    ScootARoot New Member
    TJ - aka Dada
    Georgia
    2024 Limited OR - Smoked Mesquite
  8. Dec 30, 2023 at 7:39 PM
    #4178
    abgiles
    abgiles New Member
    2022 CrewMax Limited - Wind Chill Pearl
    TRD Grille w/Rough Country LED, Tuffskinz products,
    You are correct, the first ones will NOT fit. Forerunners and Tacomas have the same bolt pattern, but different stud and hub sizes. Several people have purchased them and found out after the fact.
    As far as the last ones are concerned, they are the TRD Pro wheels, and would fit just fine. I'd recommend scouring Facebook Marketplace, and be willing to jump on a set if they come up for sale within your driving distance. I've seen sets on there for $1500 for the 4 wheels alone (sold quickly), $2000 for the wheels alone (took a bit, but sold), and $3000 for wheels and tires (still posted).
    The deals are out there. Where in Georgia are you? I know of a set in Jacksonville, FL that was just for sale for $1500, and if I hadn't already purchased my wheels and tires, would have jumped on them.
    ScootARoot[QUOTED] likes this.
  9. Dec 30, 2023 at 7:42 PM
    #4179
    abgiles
    abgiles New Member
    You can also find the TRD ones that are shown in a couple of messages above your post. I picked up a set for $600, but have seen them anywhere from $500 to $1000 for just the wheels.
  10. Dec 30, 2023 at 7:52 PM
    #4180
    ScootARoot
    TJ - aka Dada
    Georgia
    That's what I was thinking, just wanted to get that cleared up before looking for a set of wheels to match my tires. I had those but in bronze on our Tacoma I sold two years ago, and really liked them. I already know what tires (I can get family discount from Goodyear - Cooper discoverer at3 xlt, don't know size I want yet)
    I'm in north GA close to Dawsonville. I've never bought used wheels before. Any tips for what I should be on the lookout for when I start shopping around?
  11. Dec 30, 2023 at 7:53 PM
    #4181
    ScootARoot
    TJ - aka Dada
    Georgia
    WOW! I'd love to find a set for $600! I'm in no rush, so I will definitely keep an eye on any deals I see
  12. Dec 30, 2023 at 8:05 PM
    #4182
    abgiles
    abgiles New Member
    They're out there. Wish I could find some of the TRD Pro ones for that price. As far as looking at used, just make sure they're not scuffed up, should have stampings on the inside, with bolt pattern/offset, etc. There are a ton of threads here about what sizes work with what offsets, if you have a lift or not, etc. It took me 2 months to find wheels I wanted. I love the TRD ones, but ultimately found the Fuel Catalyst with the red barrels and instantly fell in love with them. These are a +1 offset, so they stick out more (poke) but I've got some RekGen mudflaps that will cover that once I get them installed.
  13. Dec 30, 2023 at 8:09 PM
    #4183
    abgiles
    abgiles New Member
    Also be aware that the stock lug nuts will not fit with aftermarket wheels. The TRD and TRD Pro wheels use the same lug nuts, but since you're like me, and have the limited wheels, you've got the chrome lug nuts. If you buy a set of black TRD/Pro wheels, ask if they come with the lugs, as they're not cheap from Toyota, and the aftermarket ones that claim to be same as factory suck.
    Reaper_16 likes this.
  14. Dec 30, 2023 at 8:23 PM
    #4184
    ScootARoot
    TJ - aka Dada
    Georgia
    Thanks!
    Nice find! Those look good on there. Yeah, with the offset stuff that's a big reason I want to stick to OEM type wheels like the TRD ones. I keep going back to the Method wheels because so many people have them and it's easy to see how they'll look and if I;ll need spacers. It's not difficult, I just don't want to purchase some wheels and then be stuck trying to get rid of them because I don't like the look or they don't fit properly. I'm okay with a little poke, but I really like the clean/sleek look.
    Ah good call on the lug nuts! Also wasn't aware about aftermarket ones not being good - not something I want to skimp out on.
    Yep, I have the AVS rear setup. Just bought the Readylift from a guy on here for a really good deal. I'm looking for a good setup for the front. I like Bilstein,but can't find a good kit, so likely will pickup a stage 2 or 3 from Icon. Thanks for your help!
    Sorry to hijack the thread :threadjacked: I'll let us get back at it :blahblah:
  15. Dec 30, 2023 at 8:30 PM
    #4185
    xvemericavx
    xvemericavx New Member
    2023 Tundra TRD Sport 4x4
    Anyone have pics of a TRD Sport with factory rims/bigger tires and a 1.75 RC lift?
  16. Dec 30, 2023 at 8:38 PM
    #4186
    abgiles
    abgiles New Member
    You didn't hi-jack anything. This is exactly what this thread is here for. Happy to help out.
  17. Dec 31, 2023 at 3:47 AM
    #4187
    The Limited Alex
    The Limited Alex Beer Budgeter
    Alex
    Huntsville, Al
    2024 Crewmax Limited 4x4- Ice Cap
    1794 grill/mustache. 20% tint/40% windshield tint. Gun magnet. Raptor lights. Snowflakes. RC 1.75 level.
    Just an FYI to the thread. I found some wheels that I was very interested in, but they were Ram/Nissan bore size (77.8) if you’re willing to put spacers on, this company makes a bore adapter that you can purchase with any hub bore to wheel bore, and in 1, 2, or 3” spacers.
    https://venumwheel.com/products/6x5-5-wheel-adapters-hub-centric-hub-wheel-bore-conversions-only
    I’ll accept the criticism, but I have a fatal attraction to snowflakes. Found a set on Facebook marketplace for a steal. They’re +20 offset, so with the 1” spacer/bore adapter, I’ll be around -5. Hopefully it won’t be too much poke. If it is, I’ll probably combat it with the RC fender flares. :spending:
  18. Dec 31, 2023 at 2:28 PM
    #4188
    Momcar160
    Momcar160 New Member
    22 TRD Sport 4x4
    abgiles likes this.
  19. Dec 31, 2023 at 8:17 PM
    #4189
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Does anyone know if you can get the trd pro bbs wheels painted a different color or would that be a bad idea?
    Or if bbs makes a similar sized wheel that is not black?
  20. Dec 31, 2023 at 8:39 PM
    #4190
    CYBERO24
    CYBERO24 New Member
    East Coast
    2023 Tundra Platnium
    SS3 Pods, SS6 Fogs, Talon Skid & Cat, Rays ALAP 07X w/ 285/70 Toyo OC AT3, TRD Pro fenders, beat sonic amp, Peragon Tonneau,
    One of our members has the OEM BBS cerakoted bronze or copper in this thread.
  21. Dec 31, 2023 at 8:44 PM
    #4191
    GilFavor
    GilFavor New Member
    Nice, any idea of a chunk of pages? Like 1-50, 51-100 etc? lol
  22. Dec 31, 2023 at 8:48 PM
    #4192
    CYBERO24
    CYBERO24 New Member
    East Coast
  23. Dec 31, 2023 at 8:50 PM
    #4193
    GilFavor
    GilFavor New Member
  24. Jan 1, 2024 at 10:23 AM
    #4194
    GilFavor
    GilFavor New Member
    4mm and romanlegion like this.
  25. Jan 2, 2024 at 11:00 AM
    #4195
    Shep1824
    Shep1824 New Member
    Justin
    2023 Tundra Limited Hybrid
    Just installed Nitto Ridge Grappler 275/65R20 on mine. I am really liking them so far!
  26. Jan 2, 2024 at 12:14 PM
    #4196
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    295/70/18 BFG T/A KO2. Fits great, looks awesome, no rubbing at all. Stock height, no lift. It looks like a real truck now instead of looking like it skipped leg day at the gym.
    I would have preferred a 285/75/18 for a slightly taller skinnier tire as I like the "big tires but tucked" look, personally not a fan of poke. Unfortunately BFG does not make the KO2 in that size and I was dead-set on the KO2 because I really really love the look of that tire. I'll be installing a Cornfed 1" front level soon.
  27. Jan 2, 2024 at 12:26 PM
    #4197
    backinblack
    backinblack New Member
    James
    Thought I'd put these here in case anyone has been looking at them.
    17" Icon Thrust Smoke Satin Black. My pictures aren't the best, and honestly NO pictures on the internet look as good as they do in person. I was a little iffy when I ordered them, but I couldn't be happier now that they are on the truck!
    jachal and Hugh_Jaynus like this.
  28. Jan 2, 2024 at 1:30 PM
    #4198
    PROTERRA
    PROTERRA @201.PRO
    Sal
    So Cal
    2024 Tundra TRD PRO
    Bronze Volk TE37XT M-SPEC 17x8.5 -10 Offset
    Wrapped in Toyo Open Country AT's 37x12.5
    I might be one of the first Terra's on 37's.
    When this color was announced for the 24 Pro's I said bronze would look amazing with it. You guys be the judges if I was right :).
    Anyone on IG feel free to follow the build, I'll follow back. @201.PRO
  29. Jan 2, 2024 at 1:46 PM
    #4199
    GilFavor
    GilFavor New Member
    Looks great even without a level
    4genRunner[QUOTED] likes this.
  30. Jan 2, 2024 at 3:30 PM
    #4200
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    How's your MPH after going to that size tire? I was hoping to not see much of an increase but looks like I'm between 3-5 MPH faster than speedo with mine.
