GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 1, 2022 at 10:49 AM
    #211
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    I only know a little from previous experience.. its just my ocd i guess. I don't think you need to worry about the added weight and what tire load range you go with. Generally speaking a lighter load index with be equivalent to a softer ride. But anything in a C, D, E will handle any added weight just fine and should be sufficient for your Tundra. If you're towing heavy I think its better to go for the stronger ply tire.. so E for sure.. but I think your choice of the 295 in a Load range E should work out great.
    PapaDave418 likes this.
  2. Mar 1, 2022 at 11:02 AM
    #212
    TJD1776
    TJD1776 New Member
    Appreciate the insight, my friend! I'll be keeping an eye on your build, so keep us updated.
  3. Mar 1, 2022 at 4:47 PM
    #213
    2bak
    2bak Thanks
    M
    Bellingham WA
    2018 CM
    35s! Photos after install.
  4. Mar 1, 2022 at 5:16 PM
    #214
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Love the KO2s.. had them on my last 3 vehicles.. but wanted to mix it up for this truck. Excited to see how they look.. those things look massive! Are those for 18 inch or did you go 17s?
  5. Mar 1, 2022 at 5:40 PM
    #215
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Great shot using the bed camera!
  6. Mar 1, 2022 at 6:42 PM
    #216
    2bak
    2bak Thanks
    M
    Bellingham WA
    2018 CM
    18s!
  7. Mar 2, 2022 at 6:08 AM
    #217
    oxlsu40
    oxlsu40 New Member
    2022 Black SR5 4x4
    Thanks, and I do not know the width and/or offset. I looked online with zero luck. Also not a fan of all the poke.
    72Blackbird[QUOTED] likes this.
  8. Mar 2, 2022 at 9:40 AM
    #218
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Question for anyone with aftermarket wheels, did aftermarket tpms sensors work on the new wheels? Will the truck read it without having to take it in to get reprogrammed? Just wondering if I need to be an A-hole and ask discount tire to take the stock tpms sensors out of the oem wheel and put into the new ones... seems like a lot of work to just to get the oem sensors.
    Thanks
    hairychestedfrog and PapaDave418 like this.
  9. Mar 2, 2022 at 1:47 PM
    #219
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    https://www.tundras.com/threads/2022-tpms-sensors.103035/
    Similar questions with some part numbers
    ToyoTundra89[QUOTED] likes this.
  10. Mar 2, 2022 at 2:44 PM
    #220
    hairychestedfrog
    hairychestedfrog New Member
    Idaho
    22 Tundra SS Red Plt CM
    Discount put my tires on my new wheels. They took the sensors off the OEM wheels and put them on the new at no cost, just standard installation charges.
  11. Mar 3, 2022 at 10:27 AM
    #221
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Got the wheels & tires installed. 295/70/18 Cooper Evo M/Ts on Battle Born Echos 18x9 @ +18mm offset. 2" Leveling Kit up front.
    Overall, I'm good with the look. Even with the leveling kit, I might have considered going a tad bit smaller on the tire. I'm up in the air now that they're actually on the truck. Sometimes I look at it and think they look too big and other times I think they look just right. I had to remove the front mud flaps & do a very minor tuck on the front wheel well liner due to slight rubbing. Super easy & a 5 min mod with a 10mm wrench. No rubbing at all now.
    I definitely feel the impact the tires with the gearing. It's noticeable but probably not enough to for me to regear. If I had gone any bigger it wouldn't be a question as to regear or not. If I had gone 35 x 12.50s....I would 100% look at regearing as soon as something became available.
    What's odd is the speedo. I would love to hear anyone else's experience who has gone bigger tires and tracked their speed with an external GPS speedo app. At first, my speedo reads 70 mph but I'll actually be going ~75mph...as I expect. However, over the course of a few miles on the highway at constant speed the 2 speeds will come almost into alignment. Speedo will read 70 and GPS will fluctuate between 70 & 71mph. I don't know if it's my GPS app being inaccurate or the truck's computer is somehow actually adjusting. I doubt it, but it keeps happening after a few miles at a consistent speed.
    Poke - Looking back from the front:
    Poke - Looking forward from the rear:
  12. Mar 3, 2022 at 10:46 AM
    #222
    randomquickness
    randomquickness New Member
    Looks good! Did you happen to weigh that wheel/tire combo? I can’t imagine needing to do gears until 37’s or larger. They are probably heavier, and unsprung weight is a serious power robber.
    KroppDuster likes this.
  13. Mar 3, 2022 at 10:53 AM
    #223
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    I think it looks great. I am looking at a slightly smaller tire [285/65/18] mainly because it has no speedometer error [ , yet is a bit meatier in width [reminder that the tires we get in Canada are GARBAGE on this truck]. I like the poke setup you have plus that would be the next size up I would lean towards.
    KroppDuster[QUOTED] likes this.
  14. Mar 3, 2022 at 11:07 AM
    #224
    KroppDuster
    Bilstein 5100s
    92lbs according to my bathroom scale.
  15. Mar 3, 2022 at 11:23 AM
    #225
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    Truck turned out great! I dropped mine off this morning to have my Methods and some 285/75r18 Duratracs installed. Hopefully the rub isn't too bad until I get my Westcott kit. I'll post how my speedo reads against my gps app when I get it home.
  16. Mar 3, 2022 at 11:40 AM
    #226
    TJD1776
    TJD1776 New Member
    What methods did you go with? And what Westcott kit?
    I was strongly considering some 285/75/18, but think I've decided on 275/70/18.
    I was worried about poke with +18 so planned on sticking with the stock wheels for now, but Kropp's poke above looks pretty damn good to me... So now, of course, I'm undecided ha!
    Definitely interesting in seeing your progress from today with the Duratracs...
  17. Mar 3, 2022 at 11:54 AM
    #227
    NDirish44
    NDirish44 New Member
    Shouldn’t be to much poke with a +18. Wescott designs did a video with the 3/1 and +18 methods on 35s. Looked really good. I have the exact setup on order. Just waiting for the kit to come in. 35x12.5x18 toyo AT3s with method 316s +18 and the 3/1 kit.
    TJD1776[QUOTED] likes this.
  18. Mar 3, 2022 at 12:14 PM
    #228
    21CGtundra
    Robbie
    SLC, UT
    I went with the Method MR310 Con6 18x9 +18 wheels. The duratracs weren't my first choice but after buying the wheels and lift I didn't want to throw another $1,600 at new tires so I found the duratracs used local for $300. They'll get me by until I can fork out more money for some new tires. I'll keep the same size though.
    ToyoTundra89 and TJD1776[QUOTED] like this.
  19. Mar 3, 2022 at 12:18 PM
    #229
    TJD1776
    TJD1776 New Member
    I think that's a solid move right there...can't beat $300 vs $1,600... Digging those method's, too.
    Post those pics later, definitely wanna see the setup and poke. I'm thinking you'll be happy.
  20. Mar 3, 2022 at 12:26 PM
    #230
    21CGtundra
    Robbie
    SLC, UT
    Will do! I had 295/70's and some +18 Method Roosts on my 21' Tundra and I thought it was perfect. Decided to skinny them up a smidge to gain a little more height on this one.
    ToyoTundra89 likes this.
  21. Mar 3, 2022 at 1:57 PM
    #231
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    I think it looks spot on…the 92lbs is the sluggishness you feel so hopefully you have ‘before’ gas mileage so you can track what you are getting now.
  22. Mar 3, 2022 at 2:12 PM
    #232
    KroppDuster
    Bilstein 5100s
    You’re probably right on that. It’s 25-30lbs more than the OE combo so about 125-150lbs extra weight on the truck.
    On a side note: I feel like the sluggishness is a more noticeable on this Tundra than other trucks I’ve owned. Not an apples to apples comparison, but I had a 2007 F150 with the 4.6L V8 a long time ago. I went up several sizes with a new wheel/tire combo and I don’t recall it being near as noticeable on that truck. That truck didn’t seem to skip a beat with the added weight. I don’t recall the OE combo but I went to some cheap 34’s on that truck.
    I was averaging 18.8 mpgs (mixed) before the setup. I’ll keep an eye on it over the next few weeks to see how bad it drops. As long as I still get around (or better) mpg than the 2.5 GEN then I’m still coming out ahead.
  23. Mar 3, 2022 at 3:17 PM
    #233
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    That looks so dang good! Cooper's generally run large, so that's essentially a 35" tire.. but dang it looks awesome! Super excited now for my set up when it comes.
    Curious, did the stock lug nuts work? Or did they have to supply spline style?
    Why did you go with an MT? Was it for style or do you hit rough terrain often?
  24. Mar 3, 2022 at 3:31 PM
    #234
    KroppDuster
    Bilstein 5100s
    Thanks!
    I supplied my own spline-style lugs. Bought them off Amazon and just gave them to the installers. I was able to buy them cheaper than what Discount Tire would charge. They were totally cool with it.
    Honestly, I went with the Evo M/Ts because they were lighter than a lot of other A/Ts in the same size. The Evo M/Ts are only 61 lbs each. The BFG A/T KO2s in the same size come in at 75 lbs. Most of the Nittos & Toyos that I looked at were mid to high 60's. I've run BFG A/Ts on just about every vehicle I've ever had before. This is my first true M/T tire.
  25. Mar 3, 2022 at 3:52 PM
    #235
    Breathing Borla
    Northern Illinois
    lighter weight tires are hard to come by when you want 33"+
    something tells me the heavier tires are going to hit this truck harder than in the past as far as acceleration and MPG
  26. Mar 3, 2022 at 4:26 PM
    #236
    21CGtundra
    Robbie
    SLC, UT
    Got mine back. Love it!!!
    Method MR310 Con6 wheels 18x9 +18 wheels with 285/75r18 Wrangler Duratrac tires. No lift what so ever right now. I have the Westcott kit on order.
    Very little poke with the 285’s.
    DoubleCab, ramnj, xwarcat and 13 others like this.
  27. Mar 3, 2022 at 4:54 PM
    #237
    bigjuice
    WA State
    2024 Terra TRD Pro
    Yeah I feel the same with this truck vs my 2.5 gen also (3/2 lift on 295/70/18 Method 304s)
    …as long as I beat that mpg which was 10-12 on its best days I am a happy camper.
  28. Mar 3, 2022 at 5:07 PM
    #238
    bigjuice
    WA State
    2024 Terra TRD Pro
    Nice…can’t wait to see how these look when it’s all put together.
    Did you narrow down your tire choices as yet?
    BTW…envious of all that garage space…even with the Tundra in there it still looks large
  29. Mar 3, 2022 at 5:21 PM
    #239
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Thanks! Yea the garage sold the house. That was my 1 thing on my list to not compromise on is the garage space. Not yet on tires.. Definitely like the more narrow tire idea now. 295/70 or even this 285/75 that RSG did looks solid.
    Screenshot_20220303-170946_Instagram.jpg Screenshot_20220303-171014_Instagram.jpg
    DoubleCab, ramnj, Livin and 3 others like this.
  30. Mar 3, 2022 at 7:30 PM
    #240
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I like it!
