General Supercharger Thread
  1. Jun 18, 2023 at 6:44 PM
    #9031
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    im running digital. AEM X series gauge
  2. Jun 18, 2023 at 9:04 PM
    #9032
    50Shades
    J
    West Coast
    i feel like a noob with all my queries. so i changed the vacuum lines from the manifold to the FPR, and also new T-fitting and lines to the gauge sensor. still doing the same.
    did a mild gradual pull to check, i noticed that boost doesnt really drop abruptly, but rather slowly before the truck shifts. then boost climbs back to where it was after it shifts. also, boost slowly drops when im getting close to my 110ish mph speed limit (yup i didnt take off the governor)
    so it might be my tuning or some sort of torque management? i recently just got my boost gauge to work so im just now noticing my numbers.
    I dont feel loss of power. and if it is just my tuning then disregard all my stupid questions lol. never had a blown truck before. had a modded turbo diesel before my tundra.
    appreciate all y'alls patience and inputs!
    i let off the throttle a bit early for braking room.
  3. Jun 18, 2023 at 9:20 PM
    #9033
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'd say that's the least of your worries because it's running pretty lean, most target an AFR of 10-11, certainly not high 12s or 13. Was that actually floored too? I feel like my truck would've gone to a lower gear.
    HulkSmurf14 and 50Shades[QUOTED] like this.
  4. Jun 18, 2023 at 9:22 PM
    #9034
    50Shades
    J
    West Coast
    not floored. probably 3/4 throttle max. lean you say? okay i gotta talk to my tuner for sure!
  5. Jun 18, 2023 at 9:33 PM
    #9035
    snivilous
    SW UT
    Your boost is more or less proportionate to your throttle position, I would do a full throttle run and use that as your reference point for if the boost is tapering off (maybe you said it was still doing it at WOT and I missed it). Boost isn't really tune sensitive, the blower spins so many revolutions for each engine revolution so that's a fixed amount of air the blower is always moving (ignoring any efficiency changes with rpm, which do exist but should be minor). Thats why you have instant boost at idle if you floor it since essentially it's always making the same amount of boost, the bypass valve is what "disabled" or reduced the amount of boost. And the bypass valve is vacuum operated, ie essentially throttle position controlled. If the bypass valve closes fully and stops any bypass, then you have full boost and the same boost at any rpm (give or take in theory).
    That's why I would use full throttle as a reference since the throttle position is electronically controlled so may move around a bit and thus the amount of boost, if it's floored then it should make max boost since the throttle will just be fully open (assuming traction control isn't kicking in).
    In regards to your tune, the governor being removed is extremely easy so the tuner should do that. AFR targets are mid 10s as I said, this is because the tundra piston rings have a small gap and if the piston gets hot and the rings expand it's been known for the rings to seize and destroy the engine, and the easy fix is you just run it really rich to keep the engine cooler.
  6. Jun 18, 2023 at 9:39 PM
    #9036
    50Shades
    J
    West Coast
    jotting down all this info... thanks a lot man. im learning a lot of new shit everyday. hoping someday i can pass these knowledge to someone else too. thank you!
  7. Jun 18, 2023 at 9:50 PM
    #9037
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    How’d you get the gauges to sit in the craven cluster?
  8. Jun 18, 2023 at 9:55 PM
    #9038
    50Shades
    J
    West Coast
    the gauges are actually sorta floating. the hardware to secure the gauge pod isnt even tightened all the way down, i can see like 3 or 4 thread of the allen bolt. had to do it this way for clearance.
    so the AEM gauges actually fit without modification. you just have to insert them inside the pod at an angle and then slowly push the gauge in.
    and the bezel of the gauge touches the mount snug and tight.
    so these floating gauges are secure inside the pod through friction from the bezel touching the mount. even though the allen bolts arent tight, its very secure and doesnt move.
    and the bezel touching the mount tight secures it and prevent its from moving up and down. but you can still move it to your preferred position and it'll hold its position.
    i can take a better pic or even a video tomorrow when the sun is out for more clarity.
    reywcms[QUOTED] likes this.
  9. Jun 19, 2023 at 5:52 AM
    #9039
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Interesting, not sure that’ll hold for myself and how I offroad but I have a solution I’m going to try out.
  10. Jun 19, 2023 at 8:22 AM
    #9040
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Mine are pretty similarly mounted, that's why I suggested you ask for longer allens.
    50Shades[QUOTED] and reywcms like this.
  11. Jun 19, 2023 at 9:13 AM
    #9041
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    We need to update and add whipple info.
    Winks4x4Toy likes this.
  12. Jun 19, 2023 at 9:15 AM
    #9042
    50Shades
    J
    West Coast
    that was me who added you on IG btw.
    and yea with the way you wheel your truck maybe eventually it'll loosen. but its pretty snug in there in my opinion.
  13. Jun 19, 2023 at 9:16 AM
    #9043
    50Shades
    J
    West Coast
    haha yea i didnt ask for longer allens.
  14. Jun 19, 2023 at 9:56 AM
    #9044
    snivilous
    SW UT
    Give me Whipple info and pictures then :D
  15. Jun 19, 2023 at 10:00 AM
    #9045
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Whipple: 2.9 Twin Screw
    Issues - TBD
    Includes- 340LPH DW Fuel Pump, DW 650cc Injectors,Interchangeable Pulley, Stocky pulley size 3.625"
    Belts -
    "Stock" Gates Micro V Belt -120" K081196
    "Gates HD - 120” K081196HD
    Couplers -
    Rebuild -
  16. Jun 19, 2023 at 10:23 AM
    #9046
    snivilous
    SW UT
    Alright I updated the first page with the Whipple information. Can someone give me a list of what is included with the Harrop? I just have "modular pulley". Is there a tune, or fuel pump, spark plugs, or anything beyond the base supercharger assembly included with any of the stages? I want to add information of what exactly is included or not included in each kit.
    Winks4x4Toy and HulkSmurf14 like this.
  17. Jun 19, 2023 at 10:28 AM
    #9047
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Ah should add the tuner is MPV Hp Tuner unit, plugs not included but recommended. 102mm inlet can also add links to their site https://whipplesuperchargers.com/index.php?dispatch=products.view&product_id=502
    HulkSmurf14 likes this.
  18. Jun 19, 2023 at 10:29 AM
    #9048
    50Shades
    J
    West Coast
    Stage 1:
    85mm Pulley
    DW 340LPH Fuel Pump
    8PK2990 Drive belt
    They claim factory tune works, but in the manual states it has to be calibrated and tuned
    Stage 2:
    80mm Pulley
    DW 340 LPH Fuel Pump
    DW 650cc Injectors
    8PK2990 Drive Belt
    Tuning is a must.
    Uses stock spark plugs for both stages.
  19. Jun 19, 2023 at 10:39 AM
    #9049
    50Shades
    J
    West Coast
    Stage 3 has a 75mm pulley and they offer fuel rails as well. upgraded manifold and ports to support 16 injectors
    HulkSmurf14 and reywcms like this.
  20. Jun 19, 2023 at 10:40 AM
    #9050
    snivilous
    SW UT
    I didn't even know stage 3 was a thing!
  21. Jun 19, 2023 at 10:50 AM
    #9051
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Great info! Found this site after one of my 200 cell metal cats imploded and blocked my exhaust. Just read the 302 pages yesterday. Lots of great info. Nice to see there is support for the Tundra. Dropped off the grid when it didn't seem to be going anywhere back in 2015...
  22. Jun 19, 2023 at 10:53 AM
    #9052
    50Shades
    J
    West Coast
    oh yea they have a stage 3. but they dont have a kit for it. i feel like prospeed basically covers the parts needed to support a stage 3 so harrop didnt bother in US market. just my opinion haha
  23. Jun 19, 2023 at 10:53 AM
    #9053
    50Shades
    J
    West Coast
    welcome back!! enjoy your stay
    Mdl[QUOTED] likes this.
  24. Jun 20, 2023 at 6:07 AM
    #9054
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Re: intake air temp
    so it’s damn hot in houston
    Africa hot
    but my IAT has held steady at ~28 degree delta
    It has been that for some time, even when it’s cool out
    I would have thought the delta would have increased as the ambient rose
    How do the maggy folks account for this delta when it gets tuned? Or is it immaterial?
    Black@Blue19 likes this.
  25. Jun 20, 2023 at 6:11 AM
    #9055
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Gold foil for starters...and a larger heat exchanger from Frozenboost.com, Type 101....and bypassing the Throttlebody water "cooling/warmer" function
  26. Jun 20, 2023 at 6:49 AM
    #9056
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Facts
  27. Jun 20, 2023 at 7:06 AM
    #9057
    snivilous
    SW UT
    My truck runs fine regardless of the temperature so I do nothing :rofl:
  28. Jun 20, 2023 at 8:02 AM
    #9058
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Toby, aka @snivilous has been helping me to fine tune the truck.
    - I have IPT valve body, before the tune, 1-2 shift can be jarring, it would feel like a horse is kicking you from the back, it's great when the truck is loaded down or towing, but when empty and in city traffic, it's miserable, with Toby's tune, it is as smooth as it gets.
    - There were some spots during driving on previous tune feels "flat", now it feels good all over.
    - I've bought lot of stuff and services over the years, I always said Ken/Zuk @ Gearinstalls.com is perhaps the best service I've ever had, Toby is up there with Ken/Zuk, he took the time and asked me to extensively datalog and verify what works and what didn't.
    just as a side note, I've measure acceleration at test facilities, the truck is now about 3150kg/6950lb with me in it, the last time I've measured anything the truck was about 200lbs lighter, and I'm getting exact acceleration time.
  29. Jun 20, 2023 at 8:03 AM
    #9059
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I feel like hard valve body shifts is super old school hotrod stuff that really isn't needed lol
  30. Jun 20, 2023 at 8:05 AM
    #9060
    50Shades
    J
    West Coast
    your sig needs to be updated now with the whipple lol
    and i may have missed it but your tranny is still stock?
