General Supercharger Thread
  1. Nov 30, 2021 at 1:47 PM
    #931
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    agreed.
    the MAF will hold you to under 500whp.
    the graphs I posted above is about the safest you can go on stage 2 without making changes to airbox. mine is stock - RIGHT NOW.
  2. Nov 30, 2021 at 1:51 PM
    #932
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    Supercharged with aftermarket wheels and tires
    I bet it’s badass still though with the 80! Does your nannies kick in a lot? If I don’t use them it just lights them up!
  3. Nov 30, 2021 at 1:52 PM
    #933
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the nannies ride shotgun!
    it will not keep traction without them. I just hate when it cuts power.
    will try some non-adult runs in the morning.
    Saltyhero13 likes this.
  4. Nov 30, 2021 at 1:56 PM
    #934
    nobodyintexas
    nobodyintexas What?
    South of Houston
    now THAT'S an intake tube!
  5. Nov 30, 2021 at 1:56 PM
    #935
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    Yeah I hate it to! Caltracs didn’t help it? Probably helps more for axle wrap.
  6. Nov 30, 2021 at 1:59 PM
    #936
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Caltracs work well. awesome customer service.
    ZERO wheel hop.
    differential does not move under load.
    NOT for off-roading. no articulation.
    I've changed a u-joint in a previous lifetime....never again.
  7. Nov 30, 2021 at 2:05 PM
    #937
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    If you don’t mind me asking, which one did you get? 400 dollar set or 500 dollar set? My wife says what’s next? Lol!
  8. Nov 30, 2021 at 2:12 PM
    #938
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Fastlane47 likes this.
  9. Nov 30, 2021 at 2:12 PM
    #939
    nobodyintexas
    nobodyintexas What?
    South of Houston
    and painted them red to match the sway bar.
    Stangman likes this.
  10. Nov 30, 2021 at 3:25 PM
    #940
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my wife says the same
    then I sent her the definition of the Diderot effect.
    she went silent
    I won that one
    Saltyhero13 and Stangman[QUOTED] like this.
  11. Nov 30, 2021 at 3:26 PM
    #941
    nobodyintexas
    nobodyintexas What?
    South of Houston
    naw man. That tube is dead on
    how did you tune around it?
    D3 said it’s a monster to tune around the larger tube using the same MAF.
  12. Nov 30, 2021 at 3:45 PM
    #942
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    I have a good buddy that is awesome at tuning!
    nobodyintexas likes this.
  13. Nov 30, 2021 at 3:54 PM
    #943
    nobodyintexas
    nobodyintexas What?
    South of Houston
    How much better is your stage 1 than the one I posted?
    I’m intrigued
    I think Q1-22 I’ll punch it up a tad
    that intake is my first answer to the question I have yet to ask.
  14. Nov 30, 2021 at 4:40 PM
    #944
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    I’m just remotely tuning it with no dyno. Been doing all kinds of data logs. So I don’t know what hp I’m at but it’s much stronger!
  15. Nov 30, 2021 at 4:43 PM
    #945
    nobodyintexas
    nobodyintexas What?
    South of Houston
    ah. It’s good to hear positive news about remote tuning
    tuning stage 1 is awesome
    stage 2 is perfect
  16. Nov 30, 2021 at 5:01 PM
    #946
    Stangman
    Stangman New Member
    07 Tundra Crewmax
    My stock air box tune ran flawlessly! No hiccups at all. This Prospeed intake tune is a tad bit rich for safety until we can get all the adjustments to fine tune it with the pulley. He said we still have more adjustments in timing and other things we can make for even more power. Hell it’s unbelievable now for a Crewmax with a 85 on it.
  17. Nov 30, 2021 at 8:12 PM
    #947
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Got a call from Peterson Performance and they’ve moved up my install date, for those following along. December 9th is the day! Just in time for me to take unsuspecting coworkers for a ride to the liquor store during the company Christmas party. This should be fun.
    Vr0ck, omgboost, Platinum714 and 5 others like this.
  18. Dec 1, 2021 at 3:47 AM
    #948
    nobodyintexas
    nobodyintexas What?
    South of Houston
    2022 Diderot list:
    Prospeed airbox
    Transmission valve body thing
    nice AFR & boost gauges
    This should bring me to the precipice of what the stock block can handle. sorta.
    then:
    some mondo brakes to stop this bitch.
    I should note that I have all of y'all to thank for this crap.
    sd172, omgboost, Platinum714 and 2 others like this.
  19. Dec 1, 2021 at 3:58 AM
    #949
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll add:
    taking the leaf springs off/on will kick your ass. having a 20yr old to help is advised. <oh, and have a yayo (bearing) press avail>
    it will take a few days to figure out the proper tension. It's easy.
    I go a tad past the 1/4 turn because the road into our warehouse is LUNAR. and the bars will clatter when the diff bounces. extra tension remedies that.
    once dialed in, I have yet to fiddle with them.
    HOWEVER....make sure you properly torque all the leaf spring U bolts and such.....then, go back a day later and torque again. Heed this advice.
    ____
    So, today's 0-60 run was a flop. the traction bars did their thing, but fog had a thin coating of smeg on the street. The tires would NOT hook up.
    for the record - I'm doing one 3sec push of the nanny button.
  20. Dec 1, 2021 at 4:26 AM
    #950
    nobodyintexas
    nobodyintexas What?
    South of Houston
    advice - make sure they have the flam-o-gadget to take out the fuel pump from the tank. it's a special wrench from Toyota.
    My shop had to go get it from toyota - you flex fuel boys didn't need to do this.
    boostedtrdpro[QUOTED] likes this.
  21. Dec 1, 2021 at 6:21 AM
    #951
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I am living vicariously through you. I would really like a stage 2 supercharged Sequoia but given the area and traffic I drive in, there are not many opportunities for me to open up the throttle.
  22. Dec 1, 2021 at 6:30 AM
    #952
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I hear you.
    it is quite the challenge to find a safe spot. I have a couple of wide "farm to market" roads. but traffic is the challenge.
    pulling onto an on-ramp is viscous. 70mph comes very quick.
    omgboost[QUOTED] likes this.
  23. Dec 1, 2021 at 3:46 PM
    #953
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Bummer on no articulation, I was thinking of buy caltrac vs sdhq ones to save $1000 .
  24. Dec 1, 2021 at 4:04 PM
    #954
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It may articulate a little. But not much
    it’s definitely not for off road
    It’s the only indication on my truck that it is not stock
    sleeper.
    omgboost likes this.
  25. Dec 1, 2021 at 4:29 PM
    #955
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Stop being a bitch and put it in 4wd and yeet that skeet :D
    You'll never get a good 0-60 time in 2wd, no way to put the power down unless you have slicks and weight maybe.
  26. Dec 1, 2021 at 4:53 PM
    #956
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Yes sir
    Will do in morning
    who does #2 work for?
  27. Dec 2, 2021 at 3:51 AM
    #957
    nobodyintexas
    nobodyintexas What?
    South of Houston
    using a app called "FastR"
    4hi 0-60 5.58sec
    i only got to 3/4 pedal. damn. I think I can do a 5.3
    no loss of traction. it just went. hat tip to @snivilous
    just a violent takeoff. I was not expecting it to just shit & get.
    It could be faster - I think the 1-2 shift is the Achilles heel. it still feels mechanically soft. way better than un-tuned stage 1 tho'.
    <I'm parlaying a new valve body from IPT here - I 'm giving a thumb's up in the general direction of the fellla that threw that mod on the board>
    2-3 pulls very hard - it's deep in the TQ band at this point.
    I don't know how a TRX holds it together. doesn't it run in the high 3's?
    Scanguage:
    IGN is normally 30 it went to 12 whatever that means.
    AFR went to 11.9 almost instantly - it must sense pedal position?
    no nannies kicked in. which is nice. the motor did it's thing & made glorious noises.
    You know when the Dr. tells you to say ahhhh....just put a W in front of that. that's what it sounded like.
    I'm thankful for this forum & it's childish influence and stewardship to rodding.
    it is the comic relief to life's epic.
    now, I have to go prepare for a board meeting that happens next week.
    If I can do a better 0-60 time - I'll post.
  28. Dec 2, 2021 at 4:38 AM
    #958
    boringdriver
    boringdriver New Member
    2015 LX 570
    Get yourself a Dragy!
  29. Dec 2, 2021 at 4:50 AM
    #959
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Done....I just ordered it
    on sale today & free shipping.
    curse y'all.
  30. Dec 2, 2021 at 5:10 AM
    #960
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'd like to hear a @dirtydeeds exhaust with a stage 2 harrop.
    nasty.
    the TRD is nice. no rasp.
    I think a little rasp would be nice.
