General Supercharger Thread
  1. Dec 2, 2021 at 5:59 AM
    #961
    Saltyhero13
    Saltyhero13 Throbbing Member
    nobodyintexas[QUOTED] likes this.
  2. Dec 2, 2021 at 6:23 AM
    #962
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    I ordered a Harrop kit around the first of Nov. Supposed to be here in late Dec or early Jan. All the supply lines being clogged will make me wait.
    Will do the install myself, BTDT from years back. Interesting to read about some of the issues with the Tundras. I will update after install. In the meantime all I can do is read about other's adventures.
    The only other mods to the truck are the full race exhaust from Dirty Deeds and the JBA headers. And a 4'" lift and 35" tires. Oh and it is a DCLB so it needs more torque.
  3. Dec 2, 2021 at 7:52 AM
    #963
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Assuming IGN is your timing advance, it will run less advance (retard) under more throttle/load. Those numbers sound right, for cruising and idling around it'll be in the 30s and at WOT drop into the teens. If you hear pinging that is usually a combination of needing better fuel and running less timing (lower number) though the truck should do that automatically if it detects knock. With that gauge you wont be able to know if it's retarding timing due to knock, but generally those numbers match what I've seen at least.
    AFR if you stomp it will immediately dump fuel and go into open loop, meaning it's not basing the fueling off of sensors because the time it would take for the sensors to get data and then adjust is too long. So simply, yes it's looking at throttle position, obviously how the truck controls AFR in general is a lot more complicated though. 11.9 or there abouts (I always forget) is the richest the stock sensors can read, meaning in reality you were probably richer than that and the truck just has no way of knowing (but again, it's open loop so it's essentially blindly dumping fuel so that's not a bad thing it can't read richer, it just makes you blind to what your real afr is). That is normal too, the common afr I've seen people shoot for is ~11.5 at WOT which is also what Viktor has mine setup for.
    Take away, it seems normal. Next time actually floor it and I'm sure it'll go faster :D
  4. Dec 2, 2021 at 12:58 PM
    #964
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
    Should have mine by the weekend, let us know what kind of number you get.
  5. Dec 2, 2021 at 1:54 PM
    #965
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Will do
    been watching videos today on how to use it
    it gets here Monday
  6. Dec 3, 2021 at 4:31 AM
    #966
    nobodyintexas
    nobodyintexas What?
    South of Houston
    doing an oil change this weekend.
    found a Blackstone test in the cabinet.
    I'll send in a sample (w/TBN)
    I've been running Kirkland 0w-20 since 4500miles. 5000 mile intervals.
    I'll bet you it's as clean as ever.
    Apparently it has about 19 dyno runs on this oil. Let's see how Costco treats the 5.7L.
    My '06 sequoia would do 7500miles per oil change. I sent in a sample & had about 3000 more miles left on the oil. I loved that SUV.
    boostedtrdpro and omgboost like this.
  7. Dec 3, 2021 at 4:41 AM
    #967
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I will do a proper yeeting of the skeet on Tuesday.
    on clean oil.
    Dragy comes in Monday.
  8. Dec 3, 2021 at 7:10 AM
    #968
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I bet some friction modifiers in your engine oil, diffs and the transfer case will help you shave off another 1/2 second from 0-60. They really shine on acceleration, not so much for steady state. I have tried a few with no ill effects and will continue to use them.
    Let me know if you want some suggestions.
  9. Dec 3, 2021 at 7:11 AM
    #969
    nobodyintexas
    nobodyintexas What?
    South of Houston
    you have piqued my interest.
    please expound.
  10. Dec 3, 2021 at 7:48 AM
    #970
    sd172
    sd172 New Member
    South Dakota
    This is what I currently have in my engine:
    8 quarts of 15w40 Delo SDE (conventional) - switching to Castrol GTX 10w30 conventional for the winter
    4 oz of ZDDP additive (https://www.amazon.com/gp/product/B002INKQD8) - wear protection
    8 oz of PTFE/Teflon additive (https://www.fluoramics.com/tufoil/tufoil-for-engines/) - low pressure friction modifier
    4 oz of graphite additive (https://www.amazon.com/gp/product/B002Y2OY2C) - low-mid pressure friction modifier
    4 oz of polyol esters POE (https://www.amazon.com/gp/product/B088Q4C8CL) - should keep piston rings carbon-free
    The goal was to keep the oil looking 'normal' and not get questioned during my warranty required oil changes. If you are ok with your oil looking somewhat weird, there are two excellent options to use instead of graphite:
    Molybdenum disulfide MoS2 (https://www.amazon.com/Liqui-Moly-2009-Anti-Friction-Treatment/dp/B003U4O414)
    Hexagonal boron nitride hBN aka 'white graphite' (https://www.amazon.com/Liqui-Moly-20002-Friction-Modifier/dp/B001CZODH8)
    Anything that goes into the engine oil should have 1 micron or smaller particle size, because the OEM oil filter will start to remove particles of 20 micron or larger from the oil. All of the above additives will not be caught by the oil filter.
    You have more choices when it comes to the differentials and the transfer case since no filter. This is what goes in during my next fluid change:
    PTFE powder 1.6 micron (https://www.amazon.com/gp/product/B084VNXNMK) - 1 gram/quart - low pressure friction modifier
    Graphite powder 5 micron (https://www.amazon.com/gp/product/B0098RA524) - 1 gram/quart - low-mid pressure friction modifier
    Tungsten disulfide WS2 powder 0.6 micron (https://www.amazon.com/dp/B00WP4306U) - 1 gram/quart - mid-high pressure friction modifier
    nobodyintexas likes this.
  11. Dec 4, 2021 at 5:14 AM
    #971
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Re: intercooler staying on.
    I replicated the issue.
    if you push the start button to the "on" but not holding the brake...so as to not actually start the engine, but be able to put it in neutral to roll off ramp after you change the oil.
    and then turn the truck off
    the intercooler MAY stay on until you actually cycle thru those steps again.
    just passing on damn interesting stuff.
  12. Dec 5, 2021 at 3:00 PM
    #972
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Has a max HP attainable in stage 1 been established? (Tune, headers, larger intake, PLUS stage 1).
  13. Dec 5, 2021 at 3:39 PM
    #973
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not yet - we are waiting for @Saltyhero13 to get off his wallet. :)
    I reckon you would need larger injectors as well.
    all in - I would image 480whp-ish on the 7psi stage 1 pushes. I did 453whp all stock on stage 1.
    Intake was not an issue with stage 1 - I don't think headers make a sig diff on forced induction motors.
    or thereabouts.
  14. Dec 5, 2021 at 3:41 PM
    #974
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    By stage 1 do you just mean the largest 85mm pulley? If you added headers, a larger intake and a tune you would have to definitely have larger injectors. DAP said I needed the 650 injectors even just to get a tune with the 85mm. I think we are getting hung up on the “stages” cause that’s what Harrop uses to differentiate running the 85mm pulley with no tune vs the smaller pulleys with larger injectors and a custom tune.
  15. Dec 5, 2021 at 3:44 PM
    #975
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Agreed. I assumed the 85mm pulley.
    thanks for keeping us honest.
    Silver17[QUOTED] and 1UP like this.
  16. Dec 5, 2021 at 3:53 PM
    #976
    1UP
    1UP Truck Gang
    Yes, buying the stage 1 pkg from harrop and then adding all the other goodies like injectors, headers, etc...
    I guess my real question is has the the max hp been established from the 85mm pully.
  17. Dec 5, 2021 at 3:55 PM
    #977
    nobodyintexas
    nobodyintexas What?
    South of Houston
    there's that word "safely".
    I struggle with it constantly.
    Saltyhero13 and 1UP like this.
  18. Dec 5, 2021 at 3:57 PM
    #978
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll use the word safely in a sentence:
    My dragy came in early and I am going to safely attempt a 0-60 pull in the morning.
    HonorNotInner, sd172 and Silver17 like this.
  19. Dec 5, 2021 at 3:59 PM
    #979
    1UP
    1UP Truck Gang
    Lol, I meant within reason (no methanol or insane boost)
  20. Dec 5, 2021 at 4:01 PM
    #980
    Silver17
    Eastern PA
    If I had to guess I’d say the 85mm with injectors, headers, intake and tune will net you similar gains to just the 80mm pulley with injectors and a tune, without the headers and intake. Bang for the buck I think the pulley is hard to beat. Now the 80 with all of those extra goods will be good for a nice chunk more of power.
  21. Dec 5, 2021 at 4:01 PM
    #981
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the 85mm pulley is a trap.
    it leads to the 80mm.....and so on.
    however - I'll stand by my 480whp guesstimate of full tilt 85mm pulley.
    1UP likes this.
  22. Dec 5, 2021 at 4:04 PM
    #982
    nobodyintexas
    nobodyintexas What?
    South of Houston
    well said.
    stage 2 costs ~$800 + tune.
    Saltyhero13, Silver17[QUOTED] and 1UP like this.
  23. Dec 5, 2021 at 4:15 PM
    #983
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll add - and it's probably much easier to tune with just the pulley & injectors.
    all those other variables add time to the tune $.
  24. Dec 5, 2021 at 5:00 PM
    #984
    Saltyhero13
    I'm going straight to Stage 4 to stay ahead (and confuse everyone).
  25. Dec 5, 2021 at 5:03 PM
    #985
    Saltyhero13
  26. Dec 6, 2021 at 3:47 AM
    #986
    nobodyintexas
    nobodyintexas What?
    South of Houston
    bootage of the scootage
    yeeting of the skeet.
    run 1
    run 2
    run 1 had a little driver hesitation.
    run #2 was all in
    both 4hi - no loss of traction - full tank of scoot fuel.
    I don't know what else I could do. that second run is damn close to the 0-60 calc's based on weight & HP.
    I'll say again - I don't know how a TRX does not tear itself apart doing low 4's.
    Dragy is simply an entry drug to a 75mm pulley.
  27. Dec 6, 2021 at 4:04 AM
    #987
    Silver17
    Eastern PA
    Looks like a good way to start the week! Did you do any brake boosting at the launches or just stomp on it from takeoff?
  28. Dec 6, 2021 at 4:05 AM
    #988
    nobodyintexas
    nobodyintexas What?
    South of Houston
    1st run > stomp
    2nd run had a tad of brake boosting - to take the shock away from the trans.
  29. Dec 6, 2021 at 4:06 AM
    #989
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm sure some of you hyper sum'bitches could get another 10'th of 2 out of it. @snivilous
    snivilous[OP] likes this.
  30. Dec 6, 2021 at 4:14 AM
    #990
    sd172
    sd172 New Member
    South Dakota
    Now with Dragy and your baseline you can start some tribological additives. It’s easier to get the fridge sliding when the floor is wet :amen:
    nobodyintexas and Saltyhero13 like this.
