General Supercharger Thread
  1. Dec 21, 2023 at 2:32 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Did you also replace the fuel pump? If the little valve wasn’t installed correctly this would cause a fuel pressure issue. And it’s very easy to install wrong
    Fastlane47, Mdl and HulkSmurf14 like this.
  2. Dec 21, 2023 at 2:40 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Well tuner did get back........ According to them this is what is required run the 76mm pulley at 5280:facepalm:
    Mdl likes this.
  3. Dec 21, 2023 at 3:04 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Except noone (literally not one person) has tuned this exact combo. Elevation tunes are a LOT different than what most of us run. Less air = less fuel needed.
  4. Dec 21, 2023 at 3:10 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Yes. Replaced pump with DW300c. After starting it runs fine until getting up to operating temp. Then the fuel trims start drifting off extremely rich and never corrects back to normal. Justin at OTT suspects the injectors based on the data. No change in air demand. No change in pulse width. Just starts going real rich almost as if it were stuck open. Hoping DW can help out. Kind of hesitant to get another set from them
  5. Dec 21, 2023 at 3:14 PM
    VWTim
    Corvallis, OR
    DW is a solid company, if you ended up with a dud set, I'm sure they'll work to make it right.
    Mdl, ARES35 and nchlsbr[QUOTED] like this.
  6. Dec 21, 2023 at 3:23 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    That’s a Prospeed email for sure.
  7. Dec 21, 2023 at 3:24 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea I’m very skeptical it’s injectors. But as mentioned DW is solid contact them and they’ll test them etc
  8. Dec 21, 2023 at 3:24 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Without a doubt
  9. Dec 21, 2023 at 3:26 PM
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    What direction would you point me in? As far as what to look into?
  10. Dec 21, 2023 at 4:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, I don't know that he NEEDS the fuel rails, the injectors and the pump would be okay. What do you all think?
    Mdl and ARES35 like this.
  11. Dec 21, 2023 at 4:14 PM
    ARES35
    Mile high
    Yeah said tuner looking to sell me a bunch a shit. I have no problems upgrading injectors and fuel pump but damn all that to run a 76. I'll go straight to the 70mm at that point
    Mdl likes this.
  12. Dec 21, 2023 at 4:16 PM
    ARES35
    Mile high
    Dingdingdingding!:spy:
    Black@Blue19 and Mdl like this.
  13. Dec 21, 2023 at 4:22 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    @Grenades4Bacon ?
    Black@Blue19 likes this.
  14. Dec 21, 2023 at 4:23 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Check the correct vacuum line is going to the regulator. Then I’d reach out to DW and pull the injectors to send them. I’d do all that before dropping the tank and checking the pump wiring etc
    Silver17 and nchlsbr[QUOTED] like this.
  15. Dec 21, 2023 at 4:24 PM
    M3Tundra-JK
    Scott
    2005 GX470
    My first thought too! Gotta move that product
  16. Dec 21, 2023 at 4:25 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Definitely be ok with the pump and injectors on that setup
    Wynnded[QUOTED], Mdl and ARES35 like this.
  17. Dec 21, 2023 at 4:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    I'm running stock fuel rails and its all good! Installed 750's and 450 walbro running about 58-60psi with DW regulator boost referenced no issues.
  18. Dec 21, 2023 at 5:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What type air filter you running? Try running without it and see if any change. KN is not a good filter.
    Check fuel pressure. Could have a bad regulator/not doing its job.
    Vacuum leaks. Get some MAF spray and spray all around and see if any changes in rpm. Use the red hose to direct it at tight connections. I had line split right at the connector.
    Clean MAF...
    reywcms and nchlsbr[QUOTED] like this.
  19. Dec 21, 2023 at 5:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yeah, he never replied if he figured it out...we need resolutions posted to help others.
  20. Dec 21, 2023 at 5:51 PM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    @nchlsbr
    InjPW, Airflow, RPM - Constant
    Fastlane47, Mdl and nchlsbr like this.
  21. Dec 21, 2023 at 6:25 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Was about to say :rofl:
  22. Dec 21, 2023 at 6:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Got my cup holder! ;):rofl:Going belt shopping tomorrow.
  23. Dec 21, 2023 at 6:41 PM
    ARES35
    Mile high
    You went straight for the widow maker. Nice!
  24. Dec 21, 2023 at 9:02 PM
    snivilous
    SW UT
    Someone hurry up and install one so I at least know if they fit correctly :rofl:
  25. Dec 21, 2023 at 9:13 PM
    ARES35
    Mile high
    Planning on getting the 76 on this weekend! I'll then datalog at idle and through the rpm range. No WOT until I see some injector duty cycle and trims though. @Wynnded may have me beat if he's hunting belts tomorrow :cheers:
  26. Dec 22, 2023 at 1:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    So I just wanted to update as I'm running GM style 102mm throttle body with a D2A converter. I had the p0101 code, maf out if range. That is usually when your exceeding the 5volt parameters. I did a few pulls to 10-12psi. The next day I started her up and as it warmed up it stalled out, code p2103, throttle control circuit high. Did some troubleshooting consulted @snivilous and Grant at Torque Rush. Thought to be TB related as I used a mid range TB. Come to find out it was an air leak possibly by the gasket used while I stacked adapters to fit the 102mm TB. Guessed it was an air leak after data logged showed 12afr at 10psi.
    I removed the TB for inspection and all was good, cleaned everything up and reinstalled without gasket and used fipg. Running smooth at idle and and no codes or stalling after cold start.
    Air leaks are a bitch and will cause havoc for you and your engine!
  27. Dec 22, 2023 at 5:14 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Seems like this is working out! Guess I’ll be on this after the big brake kit gets thrown in lol
  28. Dec 22, 2023 at 7:42 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    <cannon fodder>
    We had a 24 Jeep Wagoneer for a rental up in Gatlinburg.
    it had the Hurricane TT in it.
    crappy vehicle, but man oh man, is that engine a monster.
    smooth as silk & mounds of TQ. Butter smooth.
    That is all.
    Merry Christmas to all you mongrels.
  29. Dec 22, 2023 at 10:00 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Glamour Shots.
    The 70mm nearly fits inside the 86mm!
    Mounted up! There appear to be no fitment issues. :thumbsup: The centering ridge actually feels to be tighter than with the stock pulley. The bolt holes all aligned, the bolts all threaded in easily by hand.
    This is with the stock belt. There doesn't appear to be any belt alignment issues. :thumbsup: I've driven it with the stock belt. I'm sure that it's too loose. I haven't romped on it or anything....yet, I'll gradually get into it later today when I talk to one of the other parts stores about trying to find a shorter belt. This might also be a good way to see if the grooves do anything to the belt ribs. There didn't seem to be any with the pulleys made for the TVS1900, so I don't expect to see any here.
    So the belt I'm looking to try first would be anywhere from 114.5-115". The book at the first parts store only showed belts just over 15" and just over 13". Nothing in the 14" range. Who's to say how old and dated that info is, but the same could be said for Gate's website as well as the store's internet sources. They also mentioned that the belt tensioner may have markings on it indicating a range of acceptable belt tension. So maybe we'd be okay with anything in that "range". I don't know if that's the case with the tensioners on our trucks or not and I don't recall if I saved the one I replaced some 10 years ago to see. I'm going to have to have a dig. Otherwise, do any of you have one laying about that's handy, to have a look?
    Side note: I'm just referring to belt lengths to the nearest approximate 0.5" as we're just going to have to go with what ever is available that works. I did have this part store order the ~115"+ belt, with the holiday, they won't have it until Wednesday. I also have a 40 second video of the truck running with with the stock belt, just waiting for it to upload.....:tumbleweed:
  30. Dec 22, 2023 at 10:07 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Looks awesome! Great work @snivilous
