General Supercharger Thread
  1. Feb 28, 2024 at 1:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Voltage for odb pins 5 and 16? 7.5 amp fuse for obd good under dash. Just a double check... check 16 ground to chasis, check for ground with pin 5 then 4 to ensure pins have good grounds.
  2. Feb 28, 2024 at 1:59 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Yes and yes
  3. Feb 28, 2024 at 2:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well then...that bites! Anyway to bench test the ecu? Usually you can find a gently used ecu. If you get one with the same exact part number it's plug and play. But you'll have to cough up 4 credits to HPT.
    Before that route or dealership course is taken try submitting a support ticket to hpt!
    NatesNightMare likes this.
  4. Feb 28, 2024 at 2:50 PM
    helidave
    flagstaff
    2015 DC 4x4
    I put tickets in with HP and VF to see if they could recover it or provide info for flashing it on the bench. I'm sure it's possible, but I can't find any info on how to do it on a tundra.
    If I got a used one Id still have to take it to the dealership to program it to the VIN, yea?
    koditten likes this.
  5. Feb 28, 2024 at 3:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've heard of one being done on the bench bur don't have the equipment. If you get one with exact part number it's plug and play no programming. Just install and start it up. Same part number for same type vehicle.
  6. Feb 28, 2024 at 3:48 PM
    helidave
    flagstaff
    2015 DC 4x4
    Cool... Found a used one with the same p/n and overnight shipping. Gonna give it a shot.
    NatesNightMare and FrenchToasty like this.
  7. Feb 28, 2024 at 4:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Some have free returns too. Just in case...
    Good Luck!
    helidave likes this.
  8. Feb 28, 2024 at 5:29 PM
    Terndrerrr
    Terndrerrr 927000 miles to go
    Music City
    6UR-FE
    Dang. Another reason to go for an older truck.
    What I really want to do is the Sequoia transfer case mod.
    VWTim likes this.
  9. Feb 28, 2024 at 5:35 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I visited my Sequoia transfer case in my shop at home this weekend. Unfortunately the truck is still 2,000 miles away.
    Terndrerrr[QUOTED] and Mdl like this.
  10. Feb 28, 2024 at 5:38 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    New pulley installed, thank you sniv!!
    I’ve said it before and I’ll say it again, I hate the belt on the 5.7. Anyway, all is installed. No code at idle. No code with normal driving. It’s pouring and dark right now so didn’t get a chance to lean into it but it def hits boost quicker. Not sure about afr yet but will report back tomorrow
    I’m still on mag kit 535 injectors and fuel pump so we will see how she holds up.
  11. Feb 28, 2024 at 5:48 PM
    snivilous
    snivilous [OP] snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Is that stock belt or using the shorter one? I agree the 5.7 belt is an absolute royal pain. Talk about lack of room to reach things.
    reywcms likes this.
  12. Feb 28, 2024 at 5:54 PM
    carn_dogg
    Pat
    Eastern Shore MD
    using the shorter one. Removed the one that came with mag kit and installed the heavy duty one that you shared a week or so ago in this thread. Worked great. Tight fit. Maxing out the tensioner for sure but it works. No room in there to get my arms. Two pry bars to get the ribs to seat properly.
    snivilous[QUOTED][OP] likes this.
  13. Feb 28, 2024 at 5:55 PM
    carn_dogg
    Pat
    Eastern Shore MD
    And guess who took the entire belt off before loosening the 86mm pulley bolts. This guy. So I was grabbing the pulley with one hand while loosing with the other.
  14. Feb 28, 2024 at 6:15 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 65mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    You only do that once... usually.
    carn_dogg[QUOTED] and ZPhilip like this.
  15. Feb 28, 2024 at 7:02 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    If it didn't work, you probably need to bench flash to recover. You can send in your ECM part number and a photo of the board to VF for instance, to see if Mat will help you, but I have to warn you he's gotten really frustrated lately with people using VF to recover when bricking with other softwares
    Wynnded and reywcms like this.
  16. Feb 28, 2024 at 7:19 PM
    helidave
    flagstaff
    2015 DC 4x4
    Mat gave me the first couple steps to do the bench flash, so I'm going to pull the ecu tomorrow and give it a shot. I'm sure if I wasn't already a VF customer he would have been less helpful.
    Wynnded, Mdl and mZiggy[QUOTED] like this.
  17. Feb 28, 2024 at 7:59 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hope it gets sorted out without getting a new one. GL!
    helidave[QUOTED] likes this.
  18. Feb 28, 2024 at 8:00 PM
    helidave
    flagstaff
    2015 DC 4x4
    I hope so. New one is like $1300!
    Mdl likes this.
  19. Feb 28, 2024 at 11:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Dealership pricing...fleabay for $100-200.
  20. Feb 29, 2024 at 3:48 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I've been there...glad I didn't have to pay for it
  21. Feb 29, 2024 at 7:30 AM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    For those with FFV trying to get 60 psi high mode with boost reference may benefit with this hack found in the HP repository. It probably has been shared at some point but I'm way behind the curve and didn't see any pictures of jumper and relay pins. Anyway for FFV super install has the removal of the F/PMP VSV relay. That deactivates the high mode y switch and uses the low mode 43 psi regulator, we have 2. You can either ground pin 1 with relay installed, somewhere in the engine bay or jumper between pins 5 and 3. I just made a spade jumper and can confirm with key off circuit is open, key on circuit closed and high mode switched and activated. Attached is the diagram from the repository, relay location and my jumper. I am just a noob sharing what I searched and found.
    Wynnded, e30cabrio, Mdl and 2 others like this.
  22. Feb 29, 2024 at 7:39 AM
    koditten
    Kirk
    Midland of the Mitten
    You guys are scaring me with all this " bricked" ECU banter.
    I want to do my own install, but am afraid to turn the truck into $50+k paperweight because I fucked up installing the tune.
    Please assure me I'm being overly dramatic.
    ARES35 likes this.
  23. Feb 29, 2024 at 7:43 AM
    ARES35
    Mile high
    When tuning just make sure your battery is charged, a lot folks like to trickle when writing a new tune. Also make for damn sure your laptop is fully charged. Also Editor needs a internet connection while writing. So make sure your wifi if tuning at home or hotspot when road tuning has a good connection. When I tune I just send it. I've lucked out so far:notsure:
    M3Tundra-JK likes this.
  24. Feb 29, 2024 at 7:44 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    As long as you:
    1. have the truck battery hooked up to a charger while flashing.
    2. Do not disconnect the flash tool from the computer or truck while flashing.
    3. Do not have the computer shut off on you while flashing like @helidave then you will not have this issue.
    Even if it does happen, there are solutions to the problem. It does not make your truck a 50k paperweight, but it could lead to a few days of downtime.
    M3Tundra-JK, helidave and reywcms like this.
  25. Feb 29, 2024 at 7:49 AM
    helidave
    flagstaff
    2015 DC 4x4
    Make sure your equipment is setup correctly and is reliable before you start and the chances of failure are pretty low.
  26. Feb 29, 2024 at 8:01 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Ok so new 76mm pulley rips. Boost hits quicker. Wants to break loose more all through rpm range in 1 and 2.
    Hard to tell afr and boost while driving but appear to hit 5psi accidentally quite often and def go passed 10psi. I want to say around 12psi. I see afr go to 10.8 but does goes up from there while getting only. Hard to see what it hits while driving but need to figure that would to see if I need larger injectors and a tune. I think I may need more fueling and tune.
    Innovate afr gauge gave me a e8 reading. Reboot got rid of it though and seems to be working as it should now.
  27. Feb 29, 2024 at 8:04 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    ARES35, Saltyhero13 and helidave like this.
  28. Feb 29, 2024 at 8:13 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Like others have mentioned:
    1. truck on battery charger (real charger, not a trickle charger)
    2. laptop should be hooked up to power as well (unless you REALLY trust your battery)
    3. I would also recommend running windows updates before attempting flashing...I've heard horror stories about reboots due to updates
    4. Turn off radio, AC, unplug any devices, shut doors (I also remove the fuses for my power amp steps, intercooler pump and fuel pumps, not necessary, but I like to over do things...)
    M3Tundra-JK, PolishedTRD, Mdl and 4 others like this.
  29. Feb 29, 2024 at 8:58 AM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    I might catch :crapstorm: but I went against the advice of HP Tuners when it comes to where I run the VCM Suite...
    Initially I ran VCM Editor on a new Lenovo laptop my employer gifted me. That was until it crashed while editing (fortunately not while uploading a tune). I figured what the hell, if it freezes on a lap top, what do I have to lose trying it on a Mac?
    For years, I've ran Windows on Macs through Parallels, problem free. I currently have Windows 11 on a MacBook Pro M3 and MacBook Air M2, which has proven to be more stable than any Microflacid native computer I've used. Since the initial crash, I primarily use the Air when running VCM Editor and it has worked flawlessly.
    I'm not saying that I'm doing it the right way, but it has been right for me.
  30. Feb 29, 2024 at 10:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I posted a few times back about 4firemandan and his fuel mods/intake that I copied. He was FFV while mines not.
    He's got a few of the high psi mods and deletes for FFV. Search for him as he's got some good info.
    https://www.tundras.com/threads/5-7-supercharged-e85-fuel-system-diy-project.101526/
    ARES35[QUOTED] likes this.
