Glad I was introduced to Bead Maker.
Discussion in 'Detailing' started by djhase, Jul 11, 2019.
  1. Jul 11, 2019 at 5:25 PM
    War Machine
    War Machine SSEM # 5 3MW
    19NOlimited, Trooper2, TRD-tv and 2 others like this.
  2. Jul 11, 2019 at 5:27 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Does this replace waxing the truck? Or do you still wax when using this stuff?
  3. Jul 11, 2019 at 5:36 PM
    War Machine
    Yes, it replaces wax. Don’t put anything on top of it.
    Watt maker and Pinay like this.
  4. Jul 11, 2019 at 6:52 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Separate bank accounts, and I have two identical Tundras one bone stock and the other you guys know about. JK!
    She is pretty cool about the stuff I do, we have been married for a long time and have never really nitpicked each other. But it’s still best she not physically see all the boxes.
    dradd, Watt maker, Boerseun and 2 others like this.
  5. Jul 11, 2019 at 7:24 PM
    War Machine
    I could have written that myself.
  6. Jul 14, 2019 at 7:26 AM
    Falconsfan
    Falconsfan New Member
    Southern Ohio
    Couldn't just buy bead maker, my wife is hating my new truck, so far I've ordered this, led bulbs, mufflers and tips(to be installed) tinted windows...i know the list gonna keep growing
    Watt maker, War Machine and Pudge like this.
  7. Jul 14, 2019 at 7:38 AM
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
  8. Jul 22, 2019 at 3:23 PM
    Falconsfan
    Southern Ohio
    Order delivered today.....its pouring rain....figures:(
    Boerseun and War Machine like this.
  9. Jul 23, 2019 at 6:43 AM
    War Machine
    Once you get it applied, you’ll look forward to rain.
    Pudge and NewImprovedRon like this.
  10. Jul 24, 2019 at 1:21 PM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I did clay/megs 205/ megs ultimate wax a couple weeks ago, the truck sits a lot during the summer so today I wiped off the dust and did a liberal coating of bead maker and man I like it. 32 bucks for a gallon is a good value in my opinion.
    Remember my Tundra is a 2011 former work truck ( 146k) that likely never saw a garage until I bought it last summer, cleaned up nice
    [​IMG] [​IMG] [​IMG]
    whodini12, Boerseun, Newm and 8 others like this.
  11. Jul 24, 2019 at 4:35 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Can you use the bread maker on a tonneau cover like the Bakflip?
  12. Jul 24, 2019 at 4:37 PM
    War Machine
    You can but it doesn’t last at all. Nothing I know of does.
  13. Jul 25, 2019 at 4:05 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    20190725_173829.jpg Did mine yesterday. Its definitely a 3 rag process.
    1 to spread
    2 to start drying. (This rag i would keep damp ish)
    3 to buff it out.
    At first i was very skeptical and after taking a break and coming back i started noticing it gets glossier as it sits so i used the dry rag to polish a bit more, and if it was kinda hazy i would use the wet rag and fully chase it with the dry one for an even coat.
    Very nice results i must say.:woot:
  14. Jul 25, 2019 at 4:29 AM
    briarpatch
    briarpatch New Member
    Does it replace wax?.....sort of. Both can be used as an LSP. Much like a traditional carnuba wax, it does not last long. I use it as a booster to existing protection (sealant), once every 3-4 weeks.
    War Machine likes this.
  15. Jul 25, 2019 at 4:41 AM
    War Machine
    Exactly this. Due to it’s short longevity, I don’t recommend Beadmaker as a stand-alone protectant, unless you don’t mind re-applying once a month. I love Beadmaker for it's unique properties. It’s definitely better than wax imo, but it has the same durability. The company claims that it lasts months, but that just hasn’t been the case for me, or anyone else I know who has tried it.
    As with anything, conditions make a lot of difference. On a garage kept vehicle that isn’t driven everyday? It probably lasts a lot longer. My truck stays outside, and is driven every day, so a month is generally as far as it goes. Luckily it’s relatively cheap and easy to use.
    NewImprovedRon likes this.
  16. Jul 25, 2019 at 5:55 AM
    Drew C
    Drew C New Member
    I just got it. I’m in the process of detailing my truck. I still need to glaze, apply sealant and then a wax (probably multiple coats of the last two). This will be the final step.
  17. Jul 26, 2019 at 5:22 PM
    Falconsfan
    Southern Ohio
    So I used bead maker this morning on my wife's camry(she borrowed the truck this morning after I got home from work) and let's get this out of the way, I'm a dumbass....i was tired and tried to do way too much of the car at one time, still looks good but I can see residue from where I didn't get it fully buffed off, I've tried going back and trying to buff it off, I even sprayed it with hose and re dried it thinking that would smooth it out, but no go. So what would be the best way to correct this? Rewash car? Re apply bead maker? Im at a loss, meguires quick detailed didn't help, tried it. 20190726_201158.jpg
    Still looks good but I can see the issues, definitely beads up great and I need to finish windows(ran out of glass cleaner)
  18. Jul 26, 2019 at 5:31 PM
    groverdill
    joe
    Rathdrum ID
    did my 16 Stingray today. The pictures dont show the paint as well as in the sun, I am very happy with the results.
    Washed/clayed/Megs205 yesterday
    1 coat bead maker today
    whodini12, Trooper2, Pinay and 2 others like this.
  19. Jul 26, 2019 at 6:29 PM
    #49
    War Machine
    A lot of times you can just spray more of whatever product it is and buff again. So, try just hitting it again and see what happens. Pretty sure that’ll do it.
    NewImprovedRon and Pinay like this.
  20. Jul 26, 2019 at 6:29 PM
    #50
    War Machine
    Gorgeous!
    Pinay likes this.
  21. Jul 26, 2019 at 7:10 PM
    #51
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I used it on my truck and wife's car tonight, but it got dark so I'll have to wait til tomorrow to see it out in the sun to see how it really looks. In the garage under the lights, it looked good.
    War Machine and Pinay like this.
  22. Jul 26, 2019 at 7:11 PM
    #52
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    The best result is after curing for a day so tomorrow will be good! And rub the panels, will be slick as snot! Pardon my French...
    Pudge, NewImprovedRon and War Machine like this.
  23. Jul 27, 2019 at 7:43 PM
    #53
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I did have to go back and buff a couple spots on my wife's hood in the sunlight, but it did make it look good. She has a black car and it has never had a real good shine even after waxing it. It has swirl marks from the car wash and always had a slight haze to it. It looks better than it ever has. My truck has a nice shine too. My wife even made the comment that she liked how slippery her car felt now. I noticed it to when I went to close my door and my hand slipped right off of it.
    Pudge and Pinay[QUOTED] like this.
  24. Jul 27, 2019 at 8:46 PM
    #54
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    Damn! Take my money Autogeek
  25. Jul 30, 2019 at 3:05 PM
    #55
    Falconsfan
    Southern Ohio
    Finally got a chance to use bead maker on my truck. 20190729_192144_HDR.jpg 20190729_192155_HDR.jpg 20190729_192208_HDR.jpg 20190729_192225.jpg
    It was starting to get dark so I didn't get great pictures, and it's been raining today so I guess I get to see how it beads soon.
  26. Aug 4, 2019 at 1:31 PM
    #56
    Drew C
    Drew C New Member
    I tried it on my wife's vehicle - dark metallic blue range rover. Maybe I'm not doing it right but a lot of smears and streaks that I couldn't really buff out. I detail the vehicle (clay, polish, sealant, 2 coats of wax) then beadmaster. I'm going to let it be for a bit and then take a look it it.
  27. Aug 4, 2019 at 8:41 PM
    #57
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Not sure I would use it over wax, that could be the issue. Or maybe you didn't use enough? Sometimes if it's hot out you have to apply quite a bit to a towel then spray the vehicle lightly, this helps a lot with the streaks
  28. Aug 5, 2019 at 7:45 AM
    #58
    briarpatch
    I agree with Pudge....not sure I'd use it over a freshly applied wax. I like Bead Maker...buy it by the gallon. After a while, you realize that it's best application is a booster for existing protection, but typically not right after that protection has been applied. My vehicles get a light coating of it once every three weeks, as that's the normal duration between washes - three cars, only one of me. Those same three vehicles get two legitimate details per year...once before entering winter and then once in the early spring time. Each detail ends with a top quality sealant, such as McKees HiDef, Wolfgang Deep Gloss Sealant, or Jescar Powerlock.
  29. Aug 5, 2019 at 9:59 AM
    #59
    Drew C
    Drew C New Member
    THe last coat of wax went on Saturday, Beadmaker was Sunday. The wax was fully cured at that point.
    FWIW, my wife actually noticed the steaks. She barely noticed the work from last weekend.
  30. Aug 5, 2019 at 10:32 AM
    #60
    briarpatch
    I've never really had an issue with it streaking. In areas where you see the streaks, a light re-application should take care of the problem. I always use a separate microfiber to wipe off...keeps me from having to constantly flip the one I use for application. I have heard of some issues with streaking when it's very humid.....what was your weather like when you applied it and were you in direct sunlight?
