Got a 2019 Tundra limited and I want to tow a toy hauler, doable?
Discussion in 'New Member Introductions' started by adhesivo, Jan 9, 2019.
  1. Jan 9, 2019 at 6:49 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Commercial? No.
  2. Jan 9, 2019 at 6:50 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from NC.
  3. Jan 9, 2019 at 6:50 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Welcome from Northeast Connecticut. I have a 2015 SR5 TRD DOUBLE CAB. My tow capacity is 10500 but i had to add helper springs because of rear squat. If you don't have a brake controller get the P3 because everyone is having problems with the OEM. E-trailer is the cheapest and the sell the plug and play wire harness. ESP sells a replacement panel for the controller so you don't have to drill holes to mount it.20181201_141752.jpg
  4. Jan 9, 2019 at 6:52 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Nice old Ford
  5. Jan 9, 2019 at 7:19 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Welcome!
    Look on the side of your door sticker for your max payload. Your calculated payload = any mods you did to the truck over OEM, what you carry inside the cab/bed, wt of occupants, and the hitch weight.
    Online it says a 2019 Limited max payload = 1520lbs, max towing capacity = 8800lbs.
    The corresponding max hitch weight is probably 880lbs, going towards that, our Tundras sag in the rear, you would need a WDH and airbags. The brake controller syncs your brakes with the trailer brakes. And going towards the max towing capacity, you can't drive fast or you'll feel the sway and regardless, you really need to anticipate your stopping distance. That's how I feel towing around 7500lbs, I cruise at a conservative speed between transport trucks, and hate when people cut me off when there is heavy traffic.
    Commonly for our trucks, it's the payload that is the limiting factor first.
    If you stuck with your initial toy hauler, I'd go 3/4T pickup or higher, sacrificing ride quality of course when not towing.
    OR18TRD likes this.
  6. Jan 9, 2019 at 7:37 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  7. Jan 9, 2019 at 7:49 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    OR18TRD likes this.
  8. Jan 9, 2019 at 7:50 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    OR18TRD likes this.
  9. Jan 9, 2019 at 7:53 PM
    Bmbulldog2013
    Bmbulldog2013 New Member
    Alfred
    Placentia, CA
    2018 Tundra tRd Sport CM 4x4
    Welcome from SoCal... That 86 F150 looks clean.
  10. Jan 9, 2019 at 7:58 PM
    Part_time
    Oregon
    But the power doesn’t stop there. In fact, all sixteen configurations of the six trim levels can all tow at least 10,000 pounds. All trim levels with the 5.7-liter V8 include the TOW/HAUL Mode, which holds lower gears for longer, increases throttle response, increases pulling power and increases engine braking.
    From the article. I know what you are getting at in am just going by this.
  11. Jan 9, 2019 at 8:01 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    There is the ability to pull something and then there is the ability to pull a load safely, just because the truck has the power to move a 10,000lb load doesn't mean it should. When you start adding 4x4 and larger cabs its adding more weight which reduces capacity.
  12. Jan 9, 2019 at 8:05 PM
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    The 2015 SR5 TRD 4x4 Off Road DC is 10500 Tow . Sticker inside the door. That's way i bought it
    SWIPE likes this.
  13. Jan 9, 2019 at 8:09 PM
    adhesivo
    adhesivo [OP] New Member
    Thanks guys, what about my second question regarding the brake wiring? bullshit?
  14. Jan 9, 2019 at 8:16 PM
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    E-trailer sells a plug and play wire harness for the P3 Brake controller.
  15. Jan 9, 2019 at 8:23 PM
    adhesivo
    so do I need to buy wiring harness on top of what comes standard on the 2019?
  16. Jan 9, 2019 at 8:28 PM
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Yes it plugs into the factory harness. Don't waste your money on OEM controller. They don't work for crap. There has been a bunch of threads about them
  17. Jan 9, 2019 at 11:31 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    This. Using anything at more than about 80% of its rated capacity gives me the heebie jeebies. “Rated for it” does not equal “its a good idea.” FWIW, I tow a 5000 pound trailer quite regularly, tundra handles it fine.
  18. Jan 10, 2019 at 3:40 AM
    AndyO
    AndyO New Member
    Andy
    2019 Cavalry Blue CM 4x4
    I've read a lot of the threads and there's two sides to that. some have issues and some don't. I would see how it works with your setup before spending the extra money and before taking any trips of course. that's my plan anyway. there's a good towing thread that has some videos linked that show you how to get it set up properly, as well as some about what happens when you don't set it up properly...
    https://www.tundras.com/threads/know-before-you-tow.26095/
    and Not to beat the horse, but since no one has mentioned it, I'm pretty sure you can be in legal trouble if you're involved in a accident and found to be overloaded. its just a bad plan all around.
  19. Jan 10, 2019 at 4:31 AM
    #49
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Don't let the dealer rip you off that amount of money for a brake controller and install when you can do it yourself. Here is what you need.
    Harness - Tekonsha 3031-P Trailer Brake Control Harness 2-plug Wiring Adapter - Toyota https://www.amazon.com/dp/B0781KTCPT/ref=cm_sw_r_cp_apa_i_VHZnCbT4V96WK
    Brake controller - Tekonsha 90195 P3 Electronic Brake Control https://www.amazon.com/dp/B000P17NXQ/ref=cm_sw_r_cp_apa_i_XNZnCb80J594N
    Brake controller trim - ESP Truck Accessories 2014-2019Toyota Tundra Tekonsha P2 Brake Controller Mounting Kit https://www.amazon.com/dp/B073FNJN32/ref=cm_sw_r_cp_apa_i_dQZnCb021XRMG
    I had to hardwire my own brake controller on my 2019 4.6L crewmax because it doesn't come stock with tow package but the wiring is there. Thanks to a good writeup I was able to get it done.
  20. Jan 10, 2019 at 4:42 AM
    #50
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    20181201_141752.jpg that's what i said earlier. Here it is done
  21. Jan 10, 2019 at 4:45 AM
    #51
    TundraTSS19
    San Antonio, TX
    Yeah you said some things and that was about it. You didn't provide any helpful links for him to locate what he may need to do the job and so that's what I did. That's what the forum is for. To help others.
    SWIPE and Adriver71x[QUOTED] like this.
  22. Jan 10, 2019 at 4:51 AM
    #52
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Yea all i gave him was E-trailer because i didn't know if his part numbers were different from mine because mine is a 2015
  23. Jan 10, 2019 at 4:59 AM
    #53
    TundraTSS19
    San Antonio, TX
    It's the same but all good. Nothing has changed from '14 to present. The one thing that has been updated from tekonsha is the plug and play harness. It has an extra ground cable that is needed.
  24. Jan 10, 2019 at 5:02 AM
    #54
    Adriver71x
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Yea it took me a hour to find a place to put it. After i was done i found the ground post on the left side of the column
  25. Jan 15, 2019 at 9:56 PM
    #55
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Unless things have changed there is no plug and play harness for 18+ Tundras.
  26. Jan 16, 2019 at 4:58 AM
    #56
    TundraTSS19
    San Antonio, TX
    Yes I do understand and know there is no plug and play option for 18+ tundras. I hardwired mine in myself using instructions that were given from a member that posted on this forum. Install went good. You still need to get the correct harness for the vehicle so that it has the proper ground cable and you can remove the head that would normally be on the plug and play end to hardwire to your vehicle.
  27. Jan 23, 2019 at 7:21 PM
    #57
    adhesivo
    I still don't get the harness thing, if my tundra comes with the 9 pin connector and brake controller, what harness am I missing?
  28. Jan 23, 2019 at 8:30 PM
    #58
    TundraTSS19
    San Antonio, TX
    Need more info about your Tundra. Is it 4.6L or 5.7L with tow package. The harness you'd need is going from aftermarket controller to the factory hook up for the factory controller if you have the tow package.
    Tekonsha 3031-P Trailer Brake Control Harness 2-plug Wiring Adapter - Toyota https://www.amazon.com/dp/B0781KTCPT/ref=cm_sw_r_cp_apa_i_W9tsCbR8PPQ2T
  29. Jan 23, 2019 at 8:45 PM
    #59
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’d buy something with higher towing capacity.
  30. Jan 23, 2019 at 10:15 PM
    #60
    adhesivo
    It's a 2019 trd off road, so crewmax 5.7L 4x4 with tow package.
