Harbor freight pressure washer?
Discussion in 'Detailing' started by dspilot, Feb 8, 2020.
  1. Mar 3, 2020 at 5:47 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I used a gas washer all the time until the pump failed. While waiting for a new pump I went to Home Depot and got their smallest electric washer just to do the job I had planned for that day ( I had just started cleaning the back porch when the pump blew up and since I was in cleaning mood that day I did not want to postpone the task). Anyways, now I am so in love with the electric washer I used it all the time. I have replaced the gas washer's pump but have only used it once since, and it was just to test the new pump.
  2. Mar 6, 2020 at 5:41 PM
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    I'm actually in the market this year for an electric washer. Been using my uncle's Honda washer, after a while I get tired of the noise. Hard to find an electric that pushes between 1.5-2gpm though
  3. Mar 6, 2020 at 6:27 PM
    ZPMAN
    Minnesota
    15+ years on my electric pump 3500psi/4gpm this thread just reminded me to change the oil. Always remember to have a good filter and a thermal relief (gas or elec) if your pump doesn't shut down automatically.
    9am53 and dspilot[OP] like this.
  4. Mar 6, 2020 at 6:48 PM
    Electonicsfanatic
    Electonicsfanatic New Member
    Wesley
    2017 Tundra Crewmax Limited 4x4
    Amazon Sunjoe was only $70 and if you register with them they will give you a no questions asked two year warranty after registration. I use mine with and extra attachment to run my MATCC foam cannon. Sure I have a gas one that is 3100PSI but, I want to keep my paint.66E3762C-8637-4664-AC71-AE942FAE6230.jpg
  5. Mar 30, 2020 at 6:09 AM
    msikk
    msikk New Member
    I have the HF Electric, it's ok, not great. Dragging the electric cord around is kind of a pain, but it gets the truck washed. I wouldn't use it for anything serious though!
  6. Apr 9, 2020 at 6:54 AM
    BuckeyeChuck
    BuckeyeChuck New Member
    Ohio
    2020 crewmax limited TRD
    N-Fab podium steps, Trd rear sway bar, oem tailgate lock, diy armrest charger.
  7. Apr 9, 2020 at 6:58 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    I'm going to make one suggestion to anyone getting their first electric pressure washer: Try to avoid the ones that have the hose reel near the top of the unit. The one I have been using for a couple of years now has that and it drives me nuts. When spraying the hose gets very rigid and doesnt want to cooperate with you as you navigate around your truck or project and if the hose is connected at the top of the unit, if its not got a sturdy wide base it will fall over. I have broken off the handle to roll up the hose, so its a pain to roll it up now, and I'm always haveing to manuever it around to keep it from faling over. I wide base one with things mounted lower (like in the on up above) would prevent these issues.
    Its more of a nit pick than anything, but if you have the option ot choose I'd consider it.
  8. Apr 9, 2020 at 7:32 AM
    briarpatch
    briarpatch New Member
    Most of the reels on the consumer grade units are not robust, and the hoses that come with them are not the most flexible on the planet....not a good combo. When I finalize my wall-mounted setup, I'm gonna spring for a good quality hose (maybe Kobrajet) and reel (Ely). Both can be pricey....but I plan on not having to replace them
  9. Apr 9, 2020 at 8:24 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I just purchased a Ryobi/Honda 3300psi gas powered pressure washer with the idle down feature (saves gas) and a 50 ft hose. Much better than the craftsman I had before. I've used electric, but like the simplicity of only needing to connect a hose.
  10. Apr 9, 2020 at 8:33 AM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    I’ve got two of these, work great and never a problem. Good value, good quality. Recommend.
    Boerseun[QUOTED] likes this.
  11. Apr 18, 2020 at 8:01 PM
    Bust
    Bust New Member
    Shean
    I was thinking about getting this one. Has good gpm for my foam cannon. Thoughts?
  12. Apr 19, 2020 at 8:31 AM
    briarpatch
    I have a SunJoe SPX3000 and really like it. Both the GPM and PSI are overstated on almost every electric pressure washer out there. Mine is rated at 2030 PSI and 1.76 GPM.....neither of which are accurate. Even with that, it's a unit that, if it dies, I'd buy another one. It's given me two years of solid performance, and shows no signs of slowing down.
  13. Apr 24, 2020 at 7:30 PM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    I.bought a green works 1600psi at lowes for $100 strictly for washing my truck. Had for almost 2 years and it's been fine.
  14. May 11, 2020 at 8:24 AM
    owb2gp
    owb2gp New Member
    ID
    I'm going to buy the SunJoe SPX3000 here soon. What foam cannon would you recommend? Will probably use it for soap and instabead.
  15. May 11, 2020 at 8:52 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    Do foam cannons work with smaller electric PWs?
  16. May 11, 2020 at 8:54 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    owb2gp[QUOTED] likes this.
  17. May 11, 2020 at 8:54 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    How small? But they should
  18. May 11, 2020 at 8:59 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    lets say 1700PSI 1.2 or 1.5 GPM...like the typical ones we are talking about in this thread
  19. May 11, 2020 at 9:08 AM
    #49
    fisherman951
    Tony
    2017 crewmax 4x4
  20. May 11, 2020 at 3:07 PM
    #50
    briarpatch
    I've no idea what instabead is, but so far I've only used mine for soap. I have one of the 20.00 Amazon knock offs, and I have an MTM PF22, which goes for around 90.00. Does the cheap one work....yes it does. Does the MTM work better, yes it does....without question. MaxShine sells one for about 35.00, and it works well, too. Regardless of which one you purchase, you'll get better foam if you swap the orifice in the foam cannon out. They typically come standard with a 1.25mm one....replace it with a 1.1mm one. It will make a significant difference in the foam you get. The specs on the SPX3000 are overstated at 2030psi and 1.76 GPM. I'm guessing it's closer to about 1400 psi and 1.5 gpm.....still more than enough to do a car.
  21. May 14, 2020 at 9:04 AM
    #51
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Question? Would a pressure washer be safe to use on an Alumawood patio awening?
  22. May 16, 2020 at 8:08 AM
    #52
    Boerseun
    Ferdie
    Sarasota Florida
    Yes. Depending on the size of the pressure washer, don't get too close if you are concerned, and use a wider angle tip to start out with. But you should not have any problems. I pressure wash my bug screens on my porch and have not had any issues, and those things are not very strong.
  23. May 18, 2020 at 9:16 AM
    #53
    vl184009
    Vicky
    Southern, Ca.
    Thank you for the response, this is one of the main reasons i am considering buying a pressure washer.
  24. May 21, 2020 at 9:31 AM
    #54
    ccheezy
    ccheezy New Member
    North Carolina
    2020 CrewMax Limited
    "What are you hauling there son?" "ass"
    Bingo. I have bought into the Ryobi ecosystem and I'm in on this one.
  25. May 21, 2020 at 9:35 AM
    #55
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    I just got one to wash dirt bike and trucks. So far it's worth it for the 79 bucks.
  26. Jun 26, 2020 at 7:11 AM
    #56
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  27. Jun 26, 2020 at 8:46 AM
    #57
    Bust
    Bust New Member
    Shean
    I picked up the HF one on sale, it's not terrible. Used it several times already. The only problem, can't use my Matcc foam cannon with the type of connector wand has.
    dspilot[OP] likes this.
