Has Anyone Painted/Plasti Dipped Their OEM Wheels?
Discussion in 'Wheels & Tires' started by plumber802, Nov 24, 2018.
  1. May 25, 2020 at 4:07 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Had the winter wheel set (OEM rims) powdercoated.
  2. Dec 8, 2020 at 2:33 PM
    TundraGuy66
    TundraGuy66 New Member
    Mat
    2020 Cement Tundra TRD
    I like the color....what product did you use and what is the color?
  3. Dec 8, 2020 at 6:44 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Plasti dip Anthracite with gloss
    EBDE832C-2593-4169-8BCE-9C4989E106F8.jpg 478A13DA-77D6-4636-A3C9-5E6A84EFAD75.jpg
  4. Dec 8, 2020 at 6:59 PM
    Meanjoe
    Meanjoe BT3 USN
    Wayde
    Salem, Oregon
    SOLD: 2020 Tundra SR 4x4 Double Cab Super White Long Bed
    Hmmm, a blank canvas...what color should I paint em'?
  5. Dec 8, 2020 at 7:29 PM
    Red Sonja
    Red Sonja Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    Just used anthracite grey
    SteyrM40A1, donellyd and Dalandshark like this.
  6. Dec 12, 2020 at 7:41 AM
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    Here's the black sapphire metallic I posted about planning on using when it warmed up. Guess I forgot to circle back. Used it for a chrome delete on wheels and emblems. Happy with the product from www.dipyourcar.com.IMG_20200630_153932499.jpg IMG_20200809_175444290.jpg IMG_20201119_090641119.jpg
    Red Sonja likes this.
  7. Feb 11, 2021 at 7:03 PM
    MgmSR5
    MgmSR5 New Member
    Ryan
    2016 CM Limited 5.7 Mica Sunset Bronze
    Can I see some more pics of your whole truck with this paint on the wheels? That looks great and I’m thinking about doing the same design as yours!
  8. Feb 12, 2021 at 7:50 AM
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    That looks like a great option. I originally thought about the vinyl sticker option, then plasti dip. Is this paint permanent or is it like plasti dip? Yours look very nice.
  9. Feb 12, 2021 at 8:28 AM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    Thank you. Permanent paint. Depending on proper prep work.
    dblizzo[QUOTED] likes this.
  10. Feb 12, 2021 at 9:26 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I would go powder coat before paint and paint before plastidip.
    If you live in a high trafficked high pollution area I would avoid Plasti Dip. Plasti Dip is sensitive to petroleum based chemicals and will diminish the durability and appearance of the dip over time. Even with proper care, I wouldn't expect dip to last more than 12 to 18 months in this situation. Yes you can touch it up and spray on additional layers but it looks like crap over time, you are better off peeling it off and applying fresh coats.
  11. Feb 12, 2021 at 10:05 AM
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    Just plasti dipped my factory 17s this week to see if I like the black wheel look. I think I do.
    I think I'm about $12 all in? If it lasts a year I'll be very impressed.
    donellyd likes this.
  12. Feb 12, 2021 at 6:12 PM
    donellyd
    donellyd Member
    Eastern PA
    Looks great! If you put enough coats, 1 thin and 4 or more wet, it'll last the year, or so, until it's time to replace the tires. I did get some small scratches when my wheels were rotated, too.
    DVCNick likes this.
  13. Feb 12, 2021 at 6:28 PM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Here are mine. Gonna redo them when the weather breaks with the new hyper dip gloss black. Looks really good.
  14. Feb 13, 2021 at 1:14 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    My son dipped his wheels and so did a friend of his. 6 months later and their wheels look like crap.
    I recommend:
    - Powerwash the wheels
    - Wipe with alcohol
    - Paint with your Rustoleum or your favorite rattle can
    Don't Dip. It's just a rubber coating. Fine for your emblems but not for your wheels.
    Saltyhero13 likes this.
  15. Feb 13, 2021 at 2:45 PM
    DVCNick
    DVCNick New Member
    I think of it more as a way to basically test drive a look for almost free before committing to a more permanent solution.
  16. Feb 13, 2021 at 4:40 PM
    donellyd
    donellyd Member
    Eastern PA
    If they're prepped correctly, and sufficient (5-7) coats of a quality product are applied, there's no way you wouldn't get at least a year out of the dip so long as your not rotating or replacing tires. Mine are nearly a year and now have a few scuffs on the lugs from a recent rotation. In PA, the wheels get pulled during inspection so there's no way around it. Once cleaned, it's easy to touch up the lugs and apply another coat of dip armor. Btw, can only use certain tire dressing products or you'll melt/smear the dip. I think I use mcguire's and there's no problems. Check out www.dipyourcar.com, and the FB forum, for endless ideas and support.
    SteyrM40A1 likes this.
  17. Feb 14, 2021 at 4:34 AM
    SteyrM40A1
    Gregg
    Thats really strange. My wheels looked great even after a year. My son has had his wheels dipped for over a year slso, and they look like new. My guess is that the didnt prep the wheels properly. They have to be clean, and you have to apply enough coats. At least 7 good coats, more coats at are always better.
  18. Feb 14, 2021 at 4:38 AM
    SteyrM40A1
    Gregg
    Yes! It should be noted not to use strong wheel cleaners on them also. I just use car wash soap (chemical guys) and a soft brush or microfiber rag. No harsh scrubbing. Also I only use water based tire dressing on my tires also. Oil based dressing can degrade the dip over time.
    donellyd[QUOTED] likes this.
  19. Feb 14, 2021 at 4:40 AM
    #49
    SteyrM40A1
    Gregg
    Any chance you could post a pic of the side of your truck from far enough away as to see both wheels? Or just DM it to me? Thanks! Looks great!
    I_Am_Thee_Walrus likes this.
  20. Feb 14, 2021 at 5:33 AM
    #50
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    They came out pretty well, and the custom center cap works.
    donellyd and SteyrM40A1 like this.
  21. Feb 14, 2021 at 5:43 AM
    #51
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    Same, really debating between this and the black on my super white Tundra.
    SteyrM40A1[QUOTED] likes this.
  22. Feb 14, 2021 at 1:15 PM
    #52
    thomasbus337
    2020 TRD Sport DC
    0F39AB0A-FD04-42D7-A11F-707FE1BD5883.jpg 23A5B788-E327-464B-B092-DD2F3341F538.jpg
  23. Feb 14, 2021 at 9:52 PM
    #53
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Did you use the copper or gold plastidip? What did you end up doing with the lug nuts and the screws for the ring? Looks killer BTW!!
  24. Feb 15, 2021 at 9:32 AM
    #54
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    Thanks! I used bronze. Had to order if because they didn’t stock it at my local OReillys. I removed 95% of the trim ring screws (and blew through 6x torx bits in the process) and the ones that absolutely would not come out, I used masking tape and a surgical knife to tape them off before paint.
    usaf.2012[QUOTED] likes this.
