Has anyone pulled a U-Haul Trailer?
Discussion in 'Towing & Hauling' started by FirstGenVol, Mar 25, 2019.
  1. Apr 5, 2019 at 8:00 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I rented two of these last year. The hydraulic brakes worked fine on both. Also I backed up both without doing anything, so I don't know about this "pin thing"..
  2. Apr 5, 2019 at 8:05 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    ive towed both the enclosed and open trailers of theirs and theyve both had that braking system on the tongue. you can actually feel the trailer brakes when you start to apply your brakes. very easy to tow...
    towing forward is not that hard as long as you make wide turns and plan accordingly. reverse is best left for the pros. i have a very good handle on backing trailers and 9 out of 10 times i can put it in a spot without having to go forward and lining up again.
    takes lots of practice.
    go to an empty parking lot and practice putting the trailer in any space. then do laps around the lot in reverse in both directions.
    i was taught like that in the army. i never drove forward except when pulling out of the parking space then they would line me up and i would drive in reverse for hours around the motor pool in both directions, once i mastered that then we went forward and understanding that it happens almost immediately because you respect whats behind you.
  3. Apr 5, 2019 at 8:25 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    FYI, I was looking at options of moving inlaws from Ohio to SC. I ended up spending about $500 extra over rental options and buying used 14' enclosed off Craigslist, ended up going again a month later so paid off.
  4. May 21, 2019 at 1:10 PM
    osteome
    osteome New Member
    What drop did you use for the hitch? The U-Haul store was not that helpful and I am slated to tow the same trailer next week from TN to NH with my stock 2017 1794. Thanks!
  5. May 21, 2019 at 2:46 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Towed a 6x12 stock height on my DC 4x4 trd. Used the uhaul brand 2 1/4” drop, was level. Went with that one cause it was the same price as everyone else and it’s rated to 7500 lbs I believe. All most others are 5500-6500 lbs on a 2” ball
  6. May 21, 2019 at 3:07 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I had it set at the 3 inch drop, but I have a 6 inch lift and 35”s. Yours will probably be different.
  7. May 21, 2019 at 4:40 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Pulled a car carrier with an xterra on the back and was one of the smoothest I ever pulled.
    This was a new one though. The straps were clean.
  8. Jan 23, 2020 at 5:10 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Will be towing the 6x12 soon. Will the 2 1/4” drop hitch work with a 2” level in the front and 33”s?
  9. Jan 23, 2020 at 5:42 PM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Pulled one of these with my old 2010 4 banger Tacoma 5 speed. Loaded full of heavy furniture for several hour mostly highway. I think ur tundra will be fine..
    It was my first time ever towing. An I couldnt believe how confident I felt. Even with no power an a small truck fully loaded . But use your head.
  10. Jan 23, 2020 at 7:03 PM
    oldboy
    oldboy New Member
    Be sure to check for good tires when picking the trailer up. Don’t be shy asking for a different trailer it the tires are near bald. Check the tire pressures. Take pictures of any existing trailer damage when you pick it up.
    Also, uhaul has a “what trailers can my vehicle tow? tool. Enter your truck info and see if this trailer is on the list. If it is, your truck will have no problem towing it. They will hook it up for u when you pick it up and unhook it when you drop it off.
  11. Jan 23, 2020 at 7:41 PM
    mugzy
    mugzy New Member
    Utah
    2014 Platinum
    TRD CAI, TRD Front and Rear Sway Bars, TransferFlow 46 Gallon Fuel Tank, LED lighting
    Some good advice above. I’ve pulled the 6x12 a couple times. First was from Vegas to Salt Lake City. The Tundra makes pulling this easy. It was also my first time towing. This trailer uses the 4-pin connector and the trailer brake is integrated with the trailer. A trailer brake controller is not required for them. I’ve also rented for short trips around town.
    I rented a 33 foot RV a couple summers ago. At 7400 pounds it was the heaviest I’ve pulled and was some white-knuckled driving pulling across state lines through canyons and cross winds. Much respect for those pulling much larger loads.
    Be cautious, don’t do anything you’re not comfortable with and respect the limits of your equipment.
  12. Feb 10, 2020 at 5:47 PM
    tightywhitey
    New Orleans, LA
    Th U-Haul folks hooked up my trailer so well that it came off a few miles down the road. Fortunately it was while backing it into the driveway. After it was hooked up properly, the Tundra towed it like boss...except for the 10 mpgs.
