Headlight Restoration
Discussion in 'Detailing' started by Fundra02, Jan 6, 2019.
  1. Jan 8, 2019 at 8:55 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Yup. Yup! Consumer Reports rated #1(headlight restoration kit)...just like our Tundras! The trick is the UV clear coat. You don't recoat them, you'll be polishing them again in a few months.
    B
  2. Jan 8, 2019 at 10:39 AM
    War Machine
    War Machine SSEM # 5 3MW
    I can vouch for Jim’s process. It worked great on some I did a few months ago.
  3. Jan 15, 2019 at 9:17 AM
    Fundra02
    Fundra02 [OP] New Member
    Harper
    2002 White Toyota Tundra SR5 V8 2WD
    I used the ultimate compound and it worked amazingly. I also used it on my fenders and all the chrome on my truck. Seeing my truck in the daylight doesn’t even seem like it’s my truck...
  4. Jan 15, 2019 at 9:24 AM
    Glad to hear it worked out for you and yes it's a great paint correction compound also.
  5. Jan 15, 2019 at 9:52 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  6. Jan 15, 2019 at 9:56 AM
    TundrAZ
    TundrAZ New Member
    Joe
    AZ
    2018 Black Tundra Limited 4x4
    Icon Rebound 17” wheels Titanium finish, 285 75 17 BFG KO2’s, Billstein 5100 front/back, leveled, Westin Protraxx 4” oval step bar, Dirty Deeds standard 8” system, Viper remote start, color match door handles and mirror caps, JDM ASTAR led interior lights, center console organizer tray, VViViD vinyl wrap carbon fiber interior trim, AJT Designs vent covers, stubby antennae
    The spray is the protectant.
  7. Jan 16, 2019 at 7:55 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Does this polish out scratches as well. Scratched my headlights today doing something dumb. :facepalm:
  8. Jun 11, 2020 at 6:53 AM
    owb2gp
    owb2gp New Member
    ID
  9. Jun 11, 2020 at 7:54 AM
    Trooper2
    JR
    owb2gp[QUOTED] likes this.
  10. Jun 11, 2020 at 11:49 AM
    War Machine
    I’ve used 3M Finesse It with success. I’ve also used sandpaper, so I can’t imagine it’ll hurt anything.*
    *War Machine Worldwide Global Universal Megacorp LLC assumes no liability if he’s wrong.
    owb2gp[QUOTED] and ToyoMafia like this.
  11. Jun 11, 2020 at 11:56 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    C9CB0255-2099-4A24-8FC4-B48BE66577BC.jpg E1D44415-B0DC-414A-9F62-6332DAC42558.jpg 7BF9FF29-0A32-46B3-988B-4B730EB86C68.jpg 1BBD85AB-1027-4859-B391-0870F561A551.jpg This was the sylvania light restoration kit off Amazon. Like $14, comes w everything you need.
    owb2gp likes this.
  12. Jun 11, 2020 at 12:09 PM
    G10dra
    G10dra Not a New Member
    Just FYI, this guy does a very good job comparing different products.
  13. Jun 11, 2020 at 12:45 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I take mine to a body/paint shop, they buff-clean sparkly clear then spray clear coat to keep them that way a long time....
  14. Jun 11, 2020 at 1:57 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    FYI, I just tried SprayMax headlight restore kit that has primer/2 part clear coat for UV protection so I didn’t have to restore/buff headlights every 2 months and it worked awesome. You still have to remove oxidation with a restoration kit/sandpaper first. But the headlights came out crystal clear.
    I did this in conjunction with projector retrofit.
    edit: forgot to mention the the SprayMax kit is pricy at $30, but it’s enough to cover 3-4 sets of lights even with 1 coat or primer and 2 coats of clear. The kit has a shelf life of 16 hours because the clear has an activator added prior to spraying and will only last 16 hours.
    JMB likes this.
  15. Jun 14, 2020 at 11:39 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I read somewhere else on this forum so I used some Bug Off with a high DEET percentage and it worked pretty good with very little effort. I read there are risks in using it. I figured why not since they were pretty bad and I really felt I don't have much to lose. They look way better than they did before. Toyota must use some crap plastic in their headlights. I had the same issue with a Camry before. I'm not having any head light issues with my other non Toyotas that are much older and sit outdoors.
