Hi-jack mounting options
Discussion in 'Recovery & Gear' started by Fiestee23, Aug 6, 2019.
  1. Aug 6, 2019 at 5:44 PM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Of course it will.
    Sunnier[QUOTED] likes this.
  2. Aug 6, 2019 at 6:38 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Make sure you mount you jack where you can access it and not have to unload all your gear while on your trips. Saves a lot headache while you're out on the trail if the jack is in your bed.
    jewsNbrews and Fiestee23[OP] like this.
  3. Aug 6, 2019 at 10:28 PM
    Vizsla
    Vizsla 2 = 2.5
    Sorry if off topic, but I really need a jack that can do a wide range of tasks, while occupying no space.:confused: Latest least worst solution. Allows a wide range of lift heights and 3 different contact point options. Downside is 8” lift range on the jack, but I keep a farm jack in @joonbug truck.:rolleyes:
    831Tun, Casper421, Sunnier and 4 others like this.
  4. Aug 6, 2019 at 11:18 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    After having a Hi-Lift come loose and break my back window, I'd encourage you to mount it parallel to the cab, not perpendicular. :anonymous:
    831Tun, Vizsla, GiantsFanDan and 2 others like this.
  5. Aug 6, 2019 at 11:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. I bet you I can get my jack out from the bed faster than you can get yours off your rack.
    831Tun, Vizsla and TRD15559 like this.
  6. Aug 7, 2019 at 4:15 PM
    GiantsFanDan
    Correct and the OP was asking about mounting a jack and not a spare tire.
  7. Aug 7, 2019 at 4:22 PM
    GiantsFanDan
    o_O My post had nothing to do about the speed of removing the jack. You can time yourself all you want. My suggestion was to mount the jack somewhere that doesn't mean you have to unpack your gear :thumbsup:
  8. Aug 7, 2019 at 4:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah. My jack is off to one side and I don't have to unpack anything to get it out. Last time I pulled it off for Warren it took me less than a minute. And that included me going into my cooler and downing a soda too. My point, mounting it in the bed is better than mounting it on the rack. All that weight on your rack will eventually give you problems. As you saw with your tire.
    831Tun and Vizsla like this.
  9. Aug 7, 2019 at 4:31 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    A few T-Nuts, washers and eye bolts. Throw in a padlock for security.
  10. Aug 7, 2019 at 4:36 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Have u used that safe jack? I was reading a couple reviews that trucks don’t seem to hold up on those
    831Tun likes this.
  11. Aug 7, 2019 at 4:52 PM
    Vizsla
    Vizsla 2 = 2.5
    Tried it out, no field use yet. Did not buy the Safe Jack bottle jack, as there were mixed reviews on it, just the lift pieces. They are solid, rated way more than other jacking options(6 ton), and very nice imo..
    831Tun, Sunnier and joonbug like this.
  12. Aug 7, 2019 at 4:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Are you planning to lift from your sliders?
    831Tun and Vizsla[QUOTED] like this.
  13. Aug 7, 2019 at 5:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Fiestee23 where about are you in socal? I have a mount I never used, in the box. I'll have to track it down but I'll let it go for $20 if you aren't far.
    I wouldn't mount it on the hood or on a bed cover or anything like that. I would mount it to the floor of the bed, or the inner sidewall of the bed. Those things are heavy.
    This one, I was gonna mount mine in my bed but went a different direction.
    https://www.4wheelparts.com/p/hi-lift-jack-4xrac-mount-kit-4x400/_/R-BJDH-4X400
  14. Aug 7, 2019 at 5:10 PM
    Vizsla
    Vizsla 2 = 2.5
    With our farm jack?, only if I have to. :rofl: Not sure this is bad, but my truck has too much travel for the 8” lift range of the jack with 37” tires via sliders. Have to jack up by frame etc..
    831Tun, Sunnier and joonbug[QUOTED] like this.
  15. Aug 7, 2019 at 5:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just go by the axle if you can. If it's a front tire then hope you have a black truck, they have enough power to do wheelies all the way home.
    :muscleflexing:
    831Tun, Sunnier and Pinay like this.
  16. Aug 8, 2019 at 2:30 PM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I removed the bed rail from the front bedside, since it was useless with my tool box, and cut it to length to mount on my tool box. I used the largest hardware I could to mount and some reinforcement plates inside the tool box to hold the weight. I used the rail mounting plates from @Victory4x4 and made props out of a carriage bolt to hold the plates rigid against the box.
  17. Aug 8, 2019 at 3:58 PM
    RBDTx
    RBDTx New Member
    2019 Tundra TRD Pro White
    I mounted mine to the front bed wall (similar to MSU Tundra above - hope that is Mississippi State University) using a 4XRAC mount from Hilift (suggested by Darkness above). My wife helped me with the bolts through the wall. It fits well, is mostly out of the way, and i have not had to use it yet. I had a similar mount on the right side of my previous F150 and the same jack ripped the mount down and out of the bed wall, so yes, they are heavy. I put this mount on the front bed wall, hoping for a little less bouncing and stress on the jack mount. Hilift jacks are best when used in odd ways, like breaking frozen/corroded wheels off of a vehicle, lifting a deer blind, pulling t posts, or .....
    dadanman, MSU Tundra and Sunnier like this.
  18. Aug 9, 2019 at 7:49 AM
    MSU Tundra
    Mississippi
    Hail State indeed. :thumbsup:
    RBDTx[QUOTED] and dadanman like this.
  19. Aug 9, 2019 at 8:18 AM
    #49
    dadanman
    dadanman New Member
    Danny
    2015 Silver Tundra SR5 Crewmax
    Hail State!
    MSU Tundra[QUOTED] and RBDTx like this.
  20. Aug 9, 2019 at 10:20 AM
    #50
    Fiestee23
    Fiestee23 [OP] A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    I'm.in Corona. How about u?
  21. Aug 9, 2019 at 10:34 AM
    #51
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Moorpark but I pass through Corona on the 15 every other weekend. If you're interested I'll find out which weekend I'm going and maybe meet up so you can check it out.
    Sunnier and Casper421 like this.
  22. Aug 9, 2019 at 10:38 AM
    #52
    Fiestee23
    SOCAL
    White sr5 4wd
    Um.. Yes! Lol.
    Sunnier likes this.
  23. Nov 12, 2019 at 2:30 PM
    #53
    Mr. Seven
    Mr. Seven New Member
    Rolla, MO
    07 DC 4x4 4.7
    Eibach Lift Level 8 MK6 18x9 ET12 295/70R18's 4.88's Auburn JBA exhaust
    3 month revival in the spirit of thread conservation.20191002_182914.jpg 20191030_103108.jpg
  24. Nov 25, 2019 at 11:50 AM
    #54
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    great location to mount it...
    FWIW... a Hi-Lift should not be used for changing tires, its an extraction, clamping, and spreading tool... I would also get a safe jack for tire changing/general service and a good base that will fir both the hi-lift and the bottle jack you use.
    I carry both off road (60" hi-lift) and a safe jack. Along with enough gear to use the Hi-lift as a winch if needed.
    I prefer to carry the Hi-Lift on the rear standing straight up as close to the centerline of the truck as possible in a sturdy mount, and will be doing the same on the Tundra. or as you have it above attached to the Bedside or floor.
    Mr. Seven likes this.
