Hi lift jack
Discussion in 'Recovery & Gear' started by joonbug, Feb 19, 2017.
  1. Feb 23, 2017 at 12:54 PM
    #61
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don't lose stuff anymore. I discovered a trick. Anytime I lend anything out, especially at work, I'll take a picture of the person holding whatever I lend them. Then erase the pic when I get it back. Been doing it for a couple of years now and haven't noticed anything missing since.
    aperezsh and ColoradoTJ like this.
  2. Feb 23, 2017 at 1:41 PM
    #62
    I just don't lend it out. If someone can't afford to buy what they are borrowing, they also can't afford to replace it when it breaks.
    joonbug[OP] and NewImprovedRon like this.
  3. Feb 23, 2017 at 1:46 PM
    #63
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    When I loan books, I write inside the cover,"stolen from Ray on-------" with the date about 6 months earlier. Usually embarrassing enough to assure swift return! lol
    joonbug[OP] likes this.
  4. Feb 24, 2017 at 8:24 AM
    #64
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Whats a book?
    Jackalope and gosolo[QUOTED] like this.
  5. Feb 24, 2017 at 12:34 PM
    #65
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My jack mount is just a couple of zip ties cause all the weight is up on top of the Decked Drawers. Second picture is the base pad for sand or mud, just a piece of 3/4" ply. Last is the small strap I use to pick a wheel. Also carry a 5t bottle jack and sometimes the floor jack if I expect to put on chains
    equin and joonbug[OP] like this.
  6. Feb 26, 2017 at 11:19 PM
    #66
    Mudduc
    Mudduc New Member
    Longview tx
    Here is my mounts. Little DIY work but saved me a lot of jack! No but really, it rides great and uses the wasted space over my fenders nicely. Also protected (somewhat) from thiefs inside my ARE. Yes the shovel is new. My other one broke! Hope this helps!
    gosolo and joonbug[OP] like this.
  7. Apr 10, 2017 at 9:15 AM
    #67
    BigCountry
    BigCountry New Member
    Garrett
    Edmond, ok. (Arkadelphia, Arkansas, school)
    2009 5.7L flex fuel, 4wd, sr5.
    Leveling kit, 20" hostage fuel rims, mangmum flow dual pipe, and bull guard.
    Made this for my high lift jack, if anyone what's more details let me know, I'd be happy to share them.
    equin, CJ21, gosolo and 2 others like this.
  8. Apr 10, 2017 at 1:45 PM
    #68
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh, I never posted what I ended up doing. Just mounted it on the floor of the bed with one bolt going through the bed. It's very stable and out of the way.
  9. Apr 10, 2017 at 3:04 PM
    #69
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    That's slick!
  10. Apr 10, 2017 at 3:25 PM
    #70
    Jesus
    Jesus New Member
    Jesus
    2014 TRD TUNDRA
    Stock just got it
    Any shots of how u did the jerry can base
  11. Apr 10, 2017 at 3:30 PM
    #71
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I have the same one as @Hattori. Actually he told me about them. :) Just drilled 4 holes and bolted through. Also added the small rubber feet to stop the can from rattling when empty.
    aperezsh likes this.
  12. Apr 10, 2017 at 5:41 PM
    #72
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    ^^^^yeppers!
  13. Apr 10, 2017 at 5:43 PM
    #73
    BigCountry
    Garrett
    That's kick ass, I want one!
  14. Dec 19, 2017 at 5:23 PM
    #74
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    More Details Please......:popcorn:
  15. Feb 14, 2018 at 9:49 AM
    #75
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Another hi-lift is in use on the trail. This is Lake Havasu to Alamo Lake.
    equin and zcarpenter92 like this.
  16. Jun 4, 2018 at 7:08 PM
    #76
    counselor
    counselor New Member
    2017 Cement Tundra TRD Pro
    Hi-Lift makes an attachment for the jack that attaches to the wheel and gives you 4 more attachment points. Nice thing is it lifts the wheel so the suspension does not have to be extended before the wheel is lifted. Great accessory.
    equin likes this.
  17. Sep 26, 2020 at 9:00 AM
    #77
    Riptyd64
    Riptyd64 New Member
    Rick
    2020 Tundra 4x4
    I don’t have sliders. What are you all using as jacking points with your tundras? Does the curved bumper mount work on the Tundra and are the bumpers strong enough to lift from?
  18. Sep 26, 2020 at 10:33 AM
    #78
    Sunnier
    Sunny
    San Diego, CA
    No. If you don’t have sliders, get a bottle jack.
  19. Jan 1, 2021 at 11:16 AM
    #79
    2mchfun
    Just keep in mind, you can use a highlift as a winch substitute also. Plus there might be another person in need somewhere in your travels. Nothing wrong with being prepared.
  20. Jan 1, 2021 at 11:53 AM
    #80
    2mchfun
    One more fact about lifting a Tundra with the highlift, use a chain, strap, or this wheel lift sling designed exclusively for this.Screenshot_2021-01-01-13-34-52.jpg
    equin likes this.
  21. Jan 1, 2021 at 12:38 PM
    #81
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    I was thinking about putting mine in cheap foam-lined gun case and keeping it in he bed up against the forward bed wall -- I will getting a tonneau so it will remain out of sight.
  22. Jan 1, 2021 at 12:40 PM
    #82
    IBeam
    IBeam New Member
    Southeast Texas
    I have that wheel sling. I find it works well.
