How to add bed tie downs with no rail system?
Discussion in 'General Tundra Discussion' started by IowaGuy, Apr 2, 2022.
  1. Apr 30, 2022 at 8:56 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Bro...this is the easiest one I have seen and probably the most economical. No need to have anything more fancy as these points are more than enough when moving any items. There are 6 (4 added/2 standard) to choose from on each side...more than plenty to anchor for almost anything you need. The screw size is a M6-1.00. x 16mm. Add a washer and your in business. Although a Torx head might be better I would think? but may not be necessary.
    BTW I found some 12 pack D ring Tie down anchors on Amazon for $15 bucks with 1500lbs WLL and 3000lbs break strength - https://www.amazon.com/dp/B08HYH42GV?smid=A29D5JAUP1YACR&ref_=chk_typ_imgToDp&th=1
    IowaGuy[OP] likes this.
  2. Apr 30, 2022 at 9:11 PM
    Terndrerrr
    Terndrerrr 928000 miles to go
    Music City
    6UR-FE
    Exactly what I was talking about in post #2 and #6, except I prefer fixed D-loops. I had some like these at first, but all that jingling was really annoying with the rear window down.
  3. May 18, 2022 at 6:52 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I tried these same movable type hooks but they rattle and echo in the bed a lot.
    Terndrerrr[QUOTED] likes this.
  4. May 18, 2022 at 6:55 AM
    IowaGuy
    In Process
    Welp, I ended up going with these fixed loop type hooks. They are made for the bed but I put them in using the side rail holes. They don't rattle and are good enough for me to get a ratchet hook onto them.
    Hotwire and Terndrerrr like this.
  5. May 18, 2022 at 8:16 AM
    Taco-Spike
    Two Trucks
    Welded a tie down bar and bolted on
    It has a removable rear piece for the tailgate portion.
    Hotwire and IowaGuy[OP] like this.
  6. Nov 14, 2024 at 3:48 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Old thread..where did you get these?
  7. Nov 14, 2024 at 5:21 PM
    2mchfun
    Search Naceture motorcycle tie down on Amazon not exact but similar
    saybng[QUOTED] likes this.
