Idatalink Maestro Info
Discussion in 'Audio & Video' started by smooosh, Jan 12, 2018.
  1. Mar 5, 2019 at 8:05 PM
    #121
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    You matched up the plug colors from the harness to the connectors on the module?
  2. Mar 5, 2019 at 8:06 PM
    #122
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Yes but I think I have the black one in the wrong slot. I get 2 flashing red lights on the device.
    When I spoke idatalink they said it could be 1 of 2 things:
    1. The serial number was incorrect from the receiver.
    2. The harnesses were plugged in incorrectly.
  3. Mar 5, 2019 at 8:14 PM
    #123
    GiantsFanDan
    If I recall correctly I plugged the main harness with the black connector into the side that has the power connection and the idatalink connection. Mine also blinked red 2 times till the head unit was fully booted up.
  4. Mar 5, 2019 at 8:16 PM
    #124
    GiantsFanDan
    Here’s the only photo I took while testing everything before putting everything in place. You can see the mmr on the left side
  5. Mar 6, 2019 at 5:20 AM
    #125
    Icuhackn
    Icuhackn New Member
    Joe
    @pschiller86 ... I am waiting on a couple of cables to complete my install. On my testing, I had issues with flashing red light and no steering controls, rolled back to factory for the time being. I came across this on http://www.12voltdata.com/viewtopic.php?t=13246. I had the idatalink plugged into the wrong side of the maestro. Make sure its plugged in next to the USB port that you programmed it with, per details below.
  6. Mar 6, 2019 at 6:45 AM
    #126
    pschiller86
    Paul
    Temecula, CA
    Thank you sir.
    Icuhackn[QUOTED] likes this.
  7. Mar 15, 2019 at 5:30 AM
    #127
    Icuhackn
    Icuhackn New Member
    Joe
    upload_2019-3-15_8-20-48.pngupload_2019-3-15_8-21-16.pngupload_2019-3-15_8-22-5.pngupload_2019-3-15_8-22-35.png
    So, I have a 2017 CM. I bought it all through Crutchfield because the HU was on sale. I maintained steering wheel controls and backup camera. You need the Maestro, other Maestro adapters for GPS antenna, USB/Aux connection, and satellite. These adapters connect to the factory connections. Then, the wiring harness. I payed for Crutchfield to build the wiring harness too. The TPS monitoring and other gauges are fed from the ODBII connector that comes with it too. You can configure others as well. If you spec it on Crutchfield, they will show you everything you need. Then, if you have any install issues, they help over the phone and have an app to look through your smartphone and camera to view what you are viewing. Hope that helps. The issues I already outlined in this thread were with the maestro flashing red lights due to the data cable being on the wrong slot. In addition, because its not documented, the factory JBL amp gets the sound from two RCA cables that have to be connected across ... Other than that, Its been about a week since I finished it. Sounds so much better than the factory HU. If anyone is in the market, I have the factory unit available.
    Lux749, Sephon and ninjajay like this.
  8. Jun 17, 2019 at 3:12 AM
    #128
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    Is anyone able to change radio presets via the steering wheel controls with their Maestro? If yes, which option is it when programming the steering wheel controls? I was only able to choose Seek+ or Seek- when programming the steering wheel, so I have to manually select the radio preset from the HU itself.
  9. Aug 18, 2019 at 6:16 AM
    #129
    bootleg_flyer
    bootleg_flyer New Member
    I just installed a Kenwood DDX9906XR in my new truck (w/ JBL amp) complete with the proper harness (wired by Crutchfield) and the Maestro unit. I'm finding that, utilizing the JBL amp with the Kenwood HU, the low end is extremely weak to nonexistent. In fact, I don't think the subwoofer is working at all. I messed around with the audio outs on the back of the Kenwood to no avail and reflashed the maestro - same results. Does anyone have any ideas? With a new HU, is it a problem to install a new amp? Thanks!
  10. Aug 19, 2019 at 2:08 PM
    #130
    Magnetic15
    Magnetic15 Steel City Member
    Eric
    2015 Platinum Crewmax
    2019 TRD Pro Black LED Headlights, 2019 TRD pro grill. Color matched door handles. Diamondback Tonneau cover.
    Subwoofer has an on/off setting in your headunit. Check that, make sure it's on.
  11. Aug 19, 2019 at 2:33 PM
    #131
    bootleg_flyer
    Thanks, is that option separate from subwoofer level in the EQ screen?
  12. Aug 19, 2019 at 4:04 PM
    #132
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Did you flash the maestro unit? Make sure that JBL amp is checked on the flash programming.
    Pudge likes this.
  13. Aug 19, 2019 at 4:15 PM
    #133
    bootleg_flyer
    I did ... Reflashed as well to ensure it was done properly. I think there was a slider for retain factory amp.
  14. Aug 20, 2019 at 8:26 AM
    #134
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Did you ever figure this out? I want to know the same thing.
  15. Aug 20, 2019 at 8:37 AM
    #135
    bootleg_flyer
    No .. Can't figure it out. All I can say is that, for whatever reason, it's only reproducing part of the frequency spectrum (above 120hz maybe?). I don't know if it's a miscommunication with the maestro module or a power supply issue or a preamp out miscommunication. I'm a little disappointed because it sounds noticably worse than the stock system - of course those components were designed to work with each other. Anywho, bit the bullet on a 5 channel amp, new speakers, wiring, etc. I'm just going to redo the whole thing. Only downside (and I was assured it wasn't really a downside) is that the dash speakers will now be useless.
  16. Aug 20, 2019 at 8:38 AM
    #136
    bootleg_flyer
    Oh sorry, just realized you were asking a different question.
  17. Aug 20, 2019 at 9:12 AM
    #137
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Lots of people say once you add an amp and component speakers that you won't miss the dash speakers. I for one, had already paid for good dash speakers (infinity reference 3.5 corners and dual JL C1 tweeters with custom bracket in the center) so I wanted them to work just to get my money's worth. I wired the center channel speaker to my kenwood "front speakers" wire outputs and the corner speakers to the "rear speakers outs". They work and sound great. All my other speakers are powered by my JL amp. I ran speaker wire from the head unit directly to all the dash speakers, it wasn't too hard to snake the wires through the dash since it's such a short run.
  18. Aug 20, 2019 at 9:25 AM
    #138
    bootleg_flyer
    Thanks, I really like that idea. How do you go about doing this? I'll have all 6 preamp outs running directly to the amp. Do you splice into the front and rear outs at the HU?
  19. Aug 20, 2019 at 9:38 AM
    #139
    Pudge
    CT
    My kenwood is about 5 years old. It has 3 preamp (RCA) outputs but also has 2 sets speaker wire outputs (front and rear). I wired my dash speakers to the speaker outputs, and ran 2 sets of RCAs to my amp, which is only a 4 channel amp so I had to wire the amp to run all the door speakers on the front channels left and right, and bridged both the rear channels to run my subwoofer.
    Does your headunit have speaker wire outputs? I hear that some newer units do not, and even if they do, once you connect to any of the RCA outputs that the head units internal amp shuts off and will not power speakers via the speaker wires. My head unit puts out 50w x 4 speaker level so it's enough for my dash speakers
  20. Aug 20, 2019 at 9:50 AM
    #140
    bootleg_flyer
    Oh I gotcha, no I only have 6 RCA outs. I'll see how it sounds without dash speakers and go from there.
  21. Aug 20, 2019 at 9:57 AM
    #141
    Pudge
    CT
    Ugh yeah that seems to be how lost of the stereos are now. Mine is old but works okay for me, some day I'll upgrade and have to figure out this same issue.
  22. Aug 20, 2019 at 12:27 PM
    #142
    Magnetic15
    Eric
    Actually I'm not sure, I know that several manufacturers ship their radios with the sub off, so that's the first thing I check when troubleshooting.
  23. Sep 8, 2019 at 9:07 PM
    #143
    joltman
    joltman New Member
    Castle Rock, CO
    I've got a 2017 Sequoia Limited that had the JBL Premium HU and amp. I had the HU replaced with an Alpine ILX-F309 unit. The place that did it added aTO harness and the adapter for the USB port as well as the Maestro RR unit
    I like the HU, except I'm getting a hiss from the speakers like the amp is turned all the way up. There are volume controls for several types of audio in the HU, however these don't help as much as I think they should. Music volume goes from 0 to something over 22. However, I can't turn up the volume more than a 6 as it's so loud. Is there something that wasn't installed correctly that allows the amp to adjust it's volume? Or am I stuck with this? Thanks!
  24. Sep 8, 2019 at 9:13 PM
    #144
    Pudge
    CT
    I'm not an expert in the audio department but I think you need to turn the gain on your amp way down. I'm sure it could be one of several things but I'd start by turning the amp gain down.
    On my JL amp I have the gains around 1/4 , I need to go lower cuz I still have some hiss
    Magnetic15 likes this.
  25. Sep 9, 2019 at 4:50 AM
    #145
    joltman
    joltman New Member
    Castle Rock, CO
    I agree. However, I was under the impression that the factory amp had no such knob. That's why I'm here. Is that a thing on the factory JBL amp? If so, where is the amp located? Thanks!
  26. Sep 9, 2019 at 5:16 AM
    #146
    Magnetic15
    Eric
    This was a shop that did this correct? If you are able to take it back, I would. If they did the install, they should fix whatever issue is cropping up now. IIRC there is no gain adjustment on the stock amplifier.
  27. Sep 9, 2019 at 5:45 AM
    #147
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    I don't have one, but this thread has several replies stating gain is adjusted through the Maestro.
    https://www.tundras.com/threads/2018-jbl-premium-sound-upgrade.18423/page-5#post-565118
  28. Sep 9, 2019 at 5:50 AM
    #148
    Pudge
    CT
    I'm sorry, I didnt realize you kept the stock amp. I was thinking you got an aftermarket amp.
    There may be a way to adjust it via the maestro.
  29. Sep 9, 2019 at 3:35 PM
    #149
    joltman
    joltman New Member
    Castle Rock, CO
    Magnetic15 and NoRcptn[QUOTED] like this.
  30. Sep 29, 2019 at 2:11 PM
    #150
    joltman
    joltman New Member
    Castle Rock, CO
    Just to follow up. I took the truck into the original installer. I told them that the audio in the truck sounded like the gain on the amp was turned up all the way. I told them I know that the iDataLink Maestro unit can be flashed to have the stock amp at any gain level. They said they always flash it at the same level for all Toyotas. Ok. They took a look at it. About 30 minutes later, they came back and said it was fixed. The issue was that the original installer used the "high lines" (Their verbiage. Obviously, the internally amplified speaker output) and plugged that into the stock amp as opposed to the "low lines" (Again, their verbiage. Obviously line level out). I got into the truck and messed around and sure enough, the issue was gone. So that's done. Now I just need to get the dashcam installed.
    Pudge and Magnetic15 like this.
