Initial Development And Prototyping Of A 102 mm GM LS Throttle Body On A Supercharged Tundra
Discussion in 'Performance and Tuning' started by ViktorG, Oct 3, 2020.
  1. Jun 2, 2023 at 1:46 PM
    #61
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Wooo!
  2. Jun 7, 2023 at 12:52 PM
    #62
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Update: I'll have my Toyota connector, terminals and seals on Friday so I can re-pin the harness to suite a Tundra. Should be able to get everything tested this weekend, and get some measurements for a TB adapter.
    reywcms likes this.
  3. Jun 7, 2023 at 12:54 PM
    #63
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Sweet!!! How much did the harness run? If yours works out I may need to have you re pin mine etc aha
  4. Jun 7, 2023 at 1:03 PM
    #64
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The harness was $80, a bit overpriced for what it is, but saves time figuring out the wiring yourself. I plan to cut the 7 wires off at the GM connector, and re-pin to the layout below on the 6-pin Toyota connector.
    Toyota Connector pins / D2A harness wires
    1 - Green - Motor - / Brown
    2 - Red - Motor + / Yellow
    3 - Blue - Ground/Low Ref / Black and White wires
    4 - Yellow-Black - TPS2 / Purple
    5 - Yellow - 5v Ref / Blue
    6 - Red-Yellow - TPS1 / Green
    reywcms likes this.
  5. Jun 7, 2023 at 1:27 PM
    #65
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Trying to confirm the TB part number might be this SD103LTXB
  6. Jun 9, 2023 at 10:51 AM
    #66
    armyoffoo
    armyoffoo Member
    Cypress, TX
    chugs likes this.
  7. Jun 9, 2023 at 11:23 AM
    #67
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
  8. Jun 9, 2023 at 11:29 AM
    #68
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I may have a brand new rcf for sale asap if this pans out lol
  9. Jun 9, 2023 at 11:33 AM
    #69
    armyoffoo
    armyoffoo Member
    Cypress, TX
    yeah, and silicone reducer, and mounting adapter...I'm in the same boat, and once I get this tuned with the 90mm GM TB, I'm gonna turn around and start planning for the new Harrop snout with the 110mm.
    reywcms likes this.
  10. Jun 22, 2023 at 2:04 PM
    #70
    armyoffoo
    armyoffoo Member
    Cypress, TX
    chugs, reywcms and snivilous like this.
  11. Jun 22, 2023 at 3:47 PM
    #71
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Because I don’t know, when does the stock throttle body become a bottleneck? And what about the RCF one?
    Wynnded likes this.
  12. Jun 22, 2023 at 4:10 PM
    #72
    Saltyhero13
    Saltyhero13 Throbbing Member
    ZPhilip[QUOTED] and Wynnded like this.
  13. Jun 22, 2023 at 5:29 PM
    #73
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The throttle body doesn't become the issue with the MAF, it's the diameter of the intake tube that requires it to be rescaled. If you read that article, it actually says the last mod they did after the intake scaling was switching to the RCF throttle body for a gain of 30HP. A larger throttle body allows for more air flow through the mouth of the supercharger, which usually increases boost. This will only help boosted engines. Check out this article for details:
    https://www.motortrend.com/how-to/1306-boosting-your-horsepower-gettin-air/
  14. Jun 22, 2023 at 5:47 PM
    #74
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Richard holdner? I believe is his name but he has a ton of data and engine testing that you can see on the YouTube. His data shows you absolutely want the biggest TB and intake you can fit on a positive displacement blower. Bigger is better
    armyoffoo likes this.
  15. Jun 23, 2023 at 9:59 AM
    #75
    Saltyhero13
    Based on the Holdener article
    So am I misunderstanding something where you wouldn't want to upgrade TBs until you've reached and cleared other constraints first? If your current CFM capability sufficiently meets your HP needs folks would have little to gain from a larger TB upgrade.
    Article also eludes to other factors playing a role aside from diameter. I would expect such a big difference of diameter would offset any other negatives this throttle body may have.
  16. Jun 23, 2023 at 10:18 AM
    #76
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It allows more volume for the SC to compress and shove through the engine, reducing the amount the intake has to neck down to the TB and from the TB to the intake mouth.
    For instance, when I get the 90mm going, it will be a 4.5" intake to 4" TB to ~3.3" intake opening into the Harrop, rather than the 4.5" intake to 3" stock Tundra TB to ~3.3" intake opening.
    I wish I had a before and after with mine, because I installed the RCF at the same time as the Harrop and got 588whp on the stock 85mm pulley.
  17. Jun 23, 2023 at 12:39 PM
    #77
    Saltyhero13
    I'm essentially revisiting the question earlier of when a TB is beneficial.
    So this reads to me gains are to be had when the TB is "the" restriction and the manifold or other parts are not a restriction. How does one determine that?
    The only tests I've seen to determine this is by measuring pressure before and after the TB or dynos before and after air mods.
    Listening to a long form Holdener video on this and reading the shared Holdener article, draw throughs boost application can always benefit from a larger TB but up to a limit and as long as there aren't other restrictions.
    Sound like we are about to find out how much is left on the table with the 90 vs RCF vs Stock.
  18. Jun 23, 2023 at 12:53 PM
    #78
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I think it's beneficial as soon as you install the blower. I'd imagine the stock head becomes the restriction before the throttle body would, that would probably be the limiting factor for CFM. But that's just a guess.
  19. Jun 23, 2023 at 4:06 PM
    #79
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    And a 103. The inlet of the whipple is 102 so I’ll be going back to the 103 if it all works out
  20. Jun 24, 2023 at 6:30 AM
    #80
    Saltyhero13
    This changes the test parameters since @armyoffoo is running a Harrop unless you have the other TBs to test and compare. It will tell us if a restriction is removed but not when you hit the "limit"
    But you are answering the question from what I could find.
    Matching the TB size to the inlet as closely as possible seems to be the correct answer of "when do I benefit from a TB upgrade?" Too small and you may still have a restriction (though it may be minimal at small HP goals), too big and you potentially run into turbulence issues if the inlet isn't ported. This is assuming other restrictions have been removed first, starting with the filter and moving back to the TB.
  21. Sep 8, 2023 at 10:03 AM
    #81
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
  22. Sep 12, 2023 at 6:56 AM
    #82
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I hooked it all up for a test-fit, but it isn't configured out of the box, so it didn't work. I read the instructions and configured the converter to use the GM TB that they have pre-programmed, but still need to test it. If that doesn't work, I will have to use the converter to record the GM TB blade movements and apply those values and test again.
    If I stay home this weekend I should have time swap it all back and test it.
  23. Nov 25, 2023 at 1:44 PM
    #83
    armyoffoo
    armyoffoo Member
    Cypress, TX
    ***Update 11/29/2023***
    These were the steps required to get the unit working on my truck
    Manual firmware update
    --custom firmware provided by TorqueRush
    Configure Unit with steps outlined below
    Key-on, Reset "Learned Values" via Foxwell NT510elite, Key-off
    Key-on, 3 x 0-100% throttle pedal pushes, Key-off
    Start truck
    TorqueRush said they have Toyota connectors and can make harnesses ready to go, but you will need to contact them as they are not an option on the website. The throttle body I bought required the motor wires to be swapped on the D2A Harness GM Throttle Body connector.
    Controller and Harness: http://www.torquerush.com/d2a.html
    Throttle Body: https://www.summitracing.com/parts/ado-19420707
    Throttle Body Adapter: @snivilous
    Wiring:
    Unit's 12V needs to be 12V constant power with a 2 AMP fuse
    Toyota Engine Harness / D2A engine connector
    Pin 1 (Green) / Brown
    Pin 2 (Red) / Yellow
    Pin 3 (Blue) / Black & White
    Pin 4 (Yellow-Black) / Purple
    Pin 5 (Yellow) / Blue
    Pin 6 (Yellow-Red) / Green
    D2A Harness GM Throttle Body Connector (Yellow and Brown may need to be swapped, depending on TB)
    A - Yellow
    B - Brown
    C - White
    D - Grey
    E - Pink
    F - Orange
    Configuration steps:
    Program D2A
    Connect Unit to vehicle
    Key on
    connect to PC with USB
    Click Find Device
    Select 12V Constant check-box
    Set Mode A to A
    Set Emulation to Custom and enter the values below
    -TPS1 690 , 4060
    -TPS2 2250 , 6463
    Set TB Type to Record Direct
    Click Record and move the blade by hand from resting to fully closed and back to and HOLD at fully open
    Click Stop before releasing blade
    Click Program and wait for confirmation
    Disconnect PC, remove USB cable
    Key off, unplug unit for 30-60 seconds to clear any current faults in the vehicle ECU
    Plug unit back in
    key on/engine off to test throttle operation via the pedal
    Record TB log:
    Key on
    Click Find Device
    Click Save, name file
    Key off
    Manual Firmware Update:
    Remove Unit from Vehicle
    Click Find Device
    Click Update, Manual Update
    Browse to select File
    Click Update Module Firmware, wait for confirmation
    Connect unit to vehicle
    reywcms, VWTim, dhalsey and 5 others like this.
  24. Nov 25, 2023 at 2:01 PM
    #84
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Awesome!
  25. Nov 27, 2023 at 8:12 AM
    #85
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Awesome work! I’ll have to keep an eye out for reliability long term.
  26. Nov 27, 2023 at 8:15 AM
    #86
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, still working out the kinks like I said. I actually drove it to an exhaust shop this morning with the GM throttle body installed, it wasn't fun...need to get more logs to the TorqueRush guy. I imagine once he gets it working on mine, it should be fairly easy for everyone else.
  27. Nov 27, 2023 at 8:22 AM
    #87
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I miss the old days of cable driven TB’s lol
    M3Tundra-JK, Mdl and armyoffoo like this.
  28. Nov 27, 2023 at 11:11 PM
    #88
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not to detract but I always wondered if Joe Drifter ever got that 5.7 with the cable operated 90mm TB on the 1900 going...
  29. Nov 28, 2023 at 5:57 AM
    #89
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Update:
    I drove the truck to drop off the kids this morning and it's behaving better...still not like before, but easier to manage the low throttle take offs. I was able to do a nice throttle pull. It felt great! I'm going to give it a few more driving cycles to "relearn".
    I'm not sure if there is a Tundra-specific throttle relearning procedure, I couldn't find one, but I did key-on 0-100% pedal pushes 3 times, then started it up. Maybe this is why it was a little smoother this morning, or maybe it was just the driving I did yesterday on the way back from getting my exhaust fixed up.
  30. Nov 28, 2023 at 6:47 AM
    #90
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I believe there is a throttle relearn. I saw it somewhere but you’re not far off I think
    armyoffoo[QUOTED] likes this.
