Initial Development And Prototyping Of A 102 mm GM LS Throttle Body On A Supercharged Tundra
Discussion in 'Performance and Tuning' started by ViktorG, Oct 3, 2020.
  1. Nov 28, 2023 at 6:49 AM
    #91
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    If you find it, let me know. All I could find was a idle relearn, it's idling fine though.
  2. Nov 28, 2023 at 8:03 AM
    #92
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think you can tinker with the throttle tip in in your tune if it doesn't settle to something you're okay with.
    armyoffoo[QUOTED] likes this.
  3. Nov 28, 2023 at 9:16 AM
    #93
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Do you happen to know the area/section that is found? If not, no big deal, I can dig through my tune file. I was thinking this may require a follow-up tune...ProSpeed has my latest file, but I have an older revision I can look at and the base tune to compare. Latest logging shows that everything appears to be checking out voltage-wise and throttle commanded/actual are lining up, and no DTCs.
    snivilous likes this.
  4. Nov 28, 2023 at 9:26 AM
    #94
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Do a power drain and it should trigger a relearn. Disconnect battery and touch Positive and Negative terminals for 30 seconds or so. I also leave battery disconnected for about 20 minutes
  5. Nov 28, 2023 at 9:47 AM
    #95
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't recall off the top of my head, the only thing I can is that when you hover over the icon for the correct one, at the bottom of the window that give the definition, it say something like, "ALTER AT YOUR OWN RISK".:rofl:
  6. Nov 28, 2023 at 9:55 AM
    #96
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Already did that Sunday night, I think it's been relearning since it's gradually gotten better.
    I forgot I had a Foxwell scanner that can access special functions. I performed the "learned value reset" and "TCU reset" since I never did that after I got my IPT valve body installed way back in 2021. Going to drive it around a bit so it can relearn...again.
    M3Tundra-JK[QUOTED] likes this.
  7. Nov 28, 2023 at 10:00 AM
    #97
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    snivilous, Wynnded and M3Tundra-JK like this.
  8. Nov 29, 2023 at 5:56 AM
    #98
    armyoffoo
    armyoffoo Member
    Cypress, TX
    After performing the learned values reset yesterday, and 3 x 0-100% pedal pushes with key-on, it's running perfect today!
    I was able to feather the throttle to avoid the IPT shift harshness, shifts were smooth, response was spot-on and I swear it pulls harder off the line. It was a blast to drive today, got home with a smile on my face!
    I'm going to keep the unit installed, obviously, so if there are any issues I will report back.
    Mdl, reywcms, snivilous and 5 others like this.
  9. Nov 29, 2023 at 6:30 AM
    #99
    VWTim
    Corvallis, OR
    Dammit, that means it's time for me to spend some more money.
    What TB are you running?
    HulkSmurf14 and snivilous like this.
  10. Nov 29, 2023 at 6:33 AM
    #100
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Mdl and VWTim[QUOTED] like this.
  11. Nov 29, 2023 at 6:45 AM
    #101
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I wanted to clarify that any TB should work, now that this is working on the 90mm, there should be nothing preventing anyone from trying with a 102mm or 110mm, or a non-GM TB. Once I've run it a while, I plan on getting the Harrop FDFI snout that has the 110mm GM throttle body built-in with a custom 5" intake.
    Mdl, Wynnded, snivilous and 1 other person like this.
  12. Nov 29, 2023 at 7:01 AM
    #102
    VWTim
    Corvallis, OR
    Absolutely. I'm looking at using a takeoff LT4/LSA 87mm or similar.
    Wynnded and snivilous like this.
  13. Nov 29, 2023 at 7:13 AM
    #103
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes!!
    armyoffoo likes this.
  14. Nov 29, 2023 at 7:38 AM
    #104
    armyoffoo
    armyoffoo Member
    Cypress, TX
    They can make the harness with the Toyota connector on the engine harness-side, but if they don't have them, it's not hard to do. Get this https://www.amazon.com/gp/product/B078CK2R3C?ie=UTF8 and use the pinout below:
    Toyota Engine Harness / D2A engine connector
    Pin 1 (Green) / Brown
    Pin 2 (Red) / Yellow
    Pin 3 (Blue) / Black & White
    Pin 4 (Yellow-Black) / Purple
    Pin 5 (Yellow) / Blue
    Pin 6 (Yellow-Red) / Green
    Here is mine...pay no attention to the colors I used, the wires at the top are from the D2A harness, the wires at the bottom are the stock Tundra TB connector
    reywcms, Mdl, Wynnded and 2 others like this.
  15. Nov 30, 2023 at 6:21 PM
    #105
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Mdl, ZPhilip, snivilous and 4 others like this.
  16. Nov 30, 2023 at 6:24 PM
    #106
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Awesome, I’ll need to confirm if the Fast 103 is the same which I think it is
  17. Nov 30, 2023 at 6:35 PM
    #107
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    We are going to see a few RC F's going up for sale. I can see a 90 or 95 in the future! Thanks @armyoffoo !
    snivilous and armyoffoo like this.
  18. Nov 30, 2023 at 6:37 PM
    #108
    M3Tundra-JK
    Scott
    2005 GX470
    I'll take an RC F when one does!
    reywcms and Wynnded like this.
  19. Nov 30, 2023 at 6:54 PM
    #109
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Now that they have the values recorded from the RCF TB I was using previously, any TB should work. Whether it sends an analog signal like the one I bought (LS3), or a digital signal like the one I just linked (LT5).
    RE:LT5 TB digital signal vs. LS3 TB analog signal
    "Yes both signals are digitally encoded and transmitted on a single wire using the SENT protocol. Ford and GM both use this now, although the Ford data messages are in a somewhat different format.The D2A can decode such data into the respective TPS1 and TPS2 values.
    You should be able run almost any TB with the D2A."
  20. Nov 30, 2023 at 7:50 PM
    #110
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is the 90mm length, back to front, similar to the rcf?
  21. Nov 30, 2023 at 8:04 PM
    #111
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The RCF TB from mounting surface to where the silicone coupler sits is 1 7/8", the GM TB from mounting surface to where the silicone coupler sits is 2". The ProSpeed RCF TB adapter is 1/2", where Snivilous' GM TB adapter is 1" thick.
    So, I added 5/8" to my air intake length. I didn't have to modify anything on my intake.
    Wynnded, Mdl and snivilous like this.
  22. Nov 30, 2023 at 8:11 PM
    #112
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It should be noted the 1" I did was arbitrary and meant to try and subtly transition the diameters between the two sides. It could be made a lot thinner, but there was no thickness requirement.
    Wynnded, Mdl, armyoffoo and 1 other person like this.
  23. Nov 30, 2023 at 8:12 PM
    #113
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Like when we do the 102 to 103 lol
    Mdl, snivilous[QUOTED] and armyoffoo like this.
  24. Nov 30, 2023 at 8:23 PM
    #114
    snivilous
    SW UT
    Well we talked about how we thought the Whipple bolt pattern is inherently a GM pattern, so if that's the case at most I'd say like a .060" thin plate to smooth it out, probably be better to just sand it slightly larger for the transition though.
    Mdl and reywcms[QUOTED] like this.
  25. Nov 30, 2023 at 8:27 PM
    #115
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea I’ll have to see the pattern when I get the 103. Not much room for sanding but it’s not needed
    snivilous[QUOTED] and Mdl like this.
  26. Dec 1, 2023 at 4:20 PM
    #116
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I saw SCOL used to offer a TVS1900 snout for the GM 102mm TB. Was the snout opening on th GM TVS larger than the Tundra? A quick glance appears it could fit with a lot of porting. But is it too much over the 95mm for a stock motor? Read a few GM forums using 1900 with 102mm...
  27. Dec 1, 2023 at 4:37 PM
    #117
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Try searching for "magnuson 1900 ported ls2 snout"...it looks like there is a LS2 snout that might work, and can be opened up with porting. Double-check with SCOL or Magnuson on whether the snout will swap over (snout and housing line up, coupler engagement/clearance, pulley lines up). Harrop said their GM snout (linked below) on the 2650 will work on the 3UR 2650, essentially only the snout and intake plenum changes, so chances are good Mag has a similar setup.
    https://www.harrop.com.au/110mm-integrated-throttle-body-ls-engines
    Mdl and reywcms like this.
  28. Dec 2, 2023 at 5:55 PM
    #118
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What are some reputable shops to pickup a TB. Looking at a 102mm but may settle on 95mm.
  29. Dec 2, 2023 at 6:00 PM
    #119
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    so the one to have is the Nick Williams 103. Some of the 102s didn’t like boost so they changed the motors etc and updated it to the 103. This only applies to the 102-103
  30. Dec 2, 2023 at 6:23 PM
    #120
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks. I did look at those NW ones. Good and cheap...really don't go together.
    HulkSmurf14 and reywcms like this.
