Install complete on additional transmission cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Krohsis, Apr 15, 2017.
  1. Jul 14, 2017 at 5:21 AM
    #61
    Krohsis
    Krohsis [OP] New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    A little cross posting as there are several threads on the topic of transmission temps.
    "We just got back from a 3500 mile trip in the Western US. We saw high ambient temps as high as 106* and numerous climbs of 7+%. This is the first pull with the trailer, 6500lbs with an auxillary transmission cooler in series with the stock cooler. I can report that this set up, two coolers and the thermostat pinned open, is the mack daddy for keeping this tranny cool. The highest torque converter temp I saw was 222*, and the highest pan temp was 194*. Most of the time, on the steepest long climbs the TC temps would just break over 200* and the pan temps never got out of the 180s. On the flat and level, at about 90* ambient, temps were running about 160-164*. I pull at 60mph and I'm in S-4 while towing. Steeper climbs I will drop down to S-3. I now can say that the Tundra is a good tow vehicle."
  2. Aug 17, 2017 at 2:07 AM
    #62
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    It looks like Toyota stopped installing the auxiliary transmission cooler and not just the temperature gauge. My truck had this installed from the factory:
    It's a shame that Toyota did away with these two items on a "tow package" though I do wish that the factory transmission temperature meter had some numbers on it.
  3. Aug 17, 2017 at 5:06 AM
    #63
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    what PIDs are you using to monitor trans temps? I have a BAFX Products 34t5 Bluetooth OBDII from Amazon and I'm using Torque Pro, but the PIDs I'm using for trans temps are not showing accurate temps. Possibly the OBD reader I have isn't reading correctly. I'm not sure
  4. Aug 17, 2017 at 5:17 AM
    #64
    Krohsis
    The Tundra comes with a tranny cooler in Gen 3s. It is the top 7 or so passes of the a/c condenser. True there is no gauge, but really using an OBD reader type of gauge system like scan gauge is better. The stock cooler is inadequate, and the thermostat for the tranny opens too late. Those are the issues. All very fixable, just disappointing to have too on this truck. Other issues Toyota messed up with their "wonderful towing package", is the brake controller.....doesn't work. And it doesn't come with tow mirrors......I think the Japanese have difficulty understanding what Americans expect out of a tow rig.....
    ColoradoTJ likes this.
  5. Aug 17, 2017 at 5:32 AM
    #65
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I don't agree with you that there are issues with transmission cooling. Tundras are not blowing transmissions left and right because of inadequate cooling. I think you guys are trying to fix something that isn't broke and doing a whole lot of arm chair engineering.
  6. Aug 17, 2017 at 9:12 AM
    #66
    Krohsis
    That's fine to disagree, but the data doesn't support you. Feel free to produce data to support your opinion, or move along......
    Jerry311SD likes this.
  7. Aug 17, 2017 at 9:13 AM
    #67
    osidepunker
    Alex
    2013 Tundra DC 4x4
    huh? You provide data that transmissions are failing since you are inferring that transmission can fail
    Rider0120 likes this.
  8. Aug 17, 2017 at 9:41 AM
    #68
    Krohsis
    I don't need to provide more than I have. These trannys run excessively hot when towing....with some mods, mine now runs where it should. Given only a fraction of Tundra owners tow in the upper 75% of the rated capabilities, the amount of failures would be a fraction as well. Then when you remove those towing live and tow in the flat lands of the US, the fraction is even smaller. Given several on this forum discovered their fluid was burnt, as in other forums, is indicative of a problem.
    You get on here making a claim about the lack of failures of these trannies with no data what the actual failure rate is......I'm sure if your point is important to you YOU can spend YOUR time to prove your point. I'm certainly not going to waste my time on your point, as I have already proven mine. So tell us what the actual failure rate is, and compare that to the number of owners that tow heavy and live/tow in mountainous areas. When you come back with that data we can talk. But drive-by opinions are just weak.....and you know what they say about opinions, especially those not supported by facts...
  9. Aug 17, 2017 at 9:59 AM
    #69
    osidepunker
    Alex
    2013 Tundra DC 4x4
    So let me get this straight. You say the temps get too high, fluid gets burnt, and its indicative of a problem.
    I say the transmission cooling works fine. But I am the one who is supposed to prove that transmissions aren't failing???
    whatever homie. I have been driving tundras since 2011. One time I towed 12k from AR to CA. I am frequently crossing hundreds of miles at a time in the desert in 100+ temps mashing throttle in 4wd with 35" tires or climbing mountains in the same kind of heat. I have run with dozens of tundras in similar conditions. I have never heard of a transmission failure from anyone I know or anyone I have run across at meets. I am thoroughly convinced that there is nothing wrong with the transmission cooling. I am convinced that the temperatures that you are observing are within toyota spec. If you see burnt fluid, change your oil. If you want to waste time logging temps and adding additional coolers, do your thing. I'm not going to worry about it. I'm just going to enjoy my truck
  10. Aug 17, 2017 at 10:28 AM
    #70
    My worthless .02: If someone wants to try and improve (whether it's necessary or not) something that Toyota has designed- it's their money, and their truck. I wouldn't lose any sleep over it.
  11. Aug 17, 2017 at 10:46 AM
    #71
    osidepunker
    Alex
    2013 Tundra DC 4x4
    HAHA! Trust me, I'm not losing sleep over it.
    I just don't want guys to read this thread and think their transmission is going to blow up because its overheating.
    I just want to provide an alternative opinion. Please don't ban me
    fishmando likes this.
  12. Aug 17, 2017 at 10:54 AM
    #72
    Why would I ban you?
  13. Aug 17, 2017 at 10:56 AM
    #73
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Because the last time I provided an alternative opinion you banned me. So now I am gun shy around you
  14. Aug 17, 2017 at 10:57 AM
    #74
    That's a different story ;-)
  15. Aug 17, 2017 at 11:00 AM
    #75
    osidepunker
    Alex
    2013 Tundra DC 4x4
    See you're just trying to bait me into talking about that thread again, which is just going to get me banned.
    I'm not falling for it.
    Newm and dragos28 like this.
  16. Aug 17, 2017 at 11:01 AM
    #76
  17. Aug 17, 2017 at 11:08 AM
    #77
    n2deep
    n2deep Pavement Princess
    Says the guy who has no Tow hitch on his Tundra - LOL
  18. Aug 17, 2017 at 11:13 AM
    #78
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    He pushes his trailers
  19. Aug 17, 2017 at 11:17 AM
    #79
    n2deep
    just drags everything with the winch
  20. Aug 17, 2017 at 11:18 AM
    #80
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Maybe I should install an aux cooler on the winch
  21. Aug 17, 2017 at 11:20 AM
    #81
    n2deep
    Not needed - cause there are not winch failures
  22. Aug 17, 2017 at 11:21 AM
    #82
    osidepunker
    Alex
    2013 Tundra DC 4x4
    prove it
  23. Aug 17, 2017 at 11:21 AM
    #83
    n2deep
    The only transmission failure I know was on a Gen3 and died because it overheated due to it being caked/packed with heavy mud from being used on a farm daily.
  24. Aug 17, 2017 at 11:22 AM
    #84
    n2deep
    Nawww I read it on the internet so I don't need to prove it.
    T-Rex266 likes this.
  25. Aug 17, 2017 at 11:24 AM
    #85
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Obviously he wasn't paying attention to his trans temps
  26. Aug 17, 2017 at 11:25 AM
    #86
    n2deep
    Nope - he had work to do. Can't stop for some silly light on the dash.
  27. Aug 17, 2017 at 11:27 AM
    #87
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Its too late once the light comes on. I read that on the internet
  28. Aug 17, 2017 at 11:31 AM
    #88
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds like a blind date gone really bad.
    Sumo91, Newm and osidepunker[QUOTED] like this.
  29. Aug 17, 2017 at 11:35 AM
    #89
  30. Aug 17, 2017 at 2:59 PM
    #90
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nope, not a single tundra trans failure that I've heard of. I'm sure they're out there, just pretty rare.
    Also, I have to believe, maybe even a majority of tundra owners tow. I see literally dozens of small contractors pulling their work trailers and most of the rest of us got the tundra to pull a boat or camper. This is my worthless.02
    Edit: I've lived my entire adult life in AZ and adding oil coolers to engines and transmissions is always a good idea I've added em to Chevys, Harley's, and Volkswagens.
    aperezsh likes this.
