Intro
Discussion in 'New Member Introductions' started by snowcruiser, Jan 13, 2018.
  1. Jan 14, 2018 at 2:24 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    You got it
    I have the 8yr/125k warranty and the peace of mind is what justifies the cost for me.
    NewImprovedRon and ColoradoTJ like this.
  2. Jan 15, 2018 at 8:17 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Delaware!
  3. Jan 15, 2018 at 11:16 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO! While I don’t have @ColoradoTJ’s level of towing experience, I do have some with towing comparable weights between a 2013 RW Tundra and a 2012 3/4 ton Duramax from when I was farming. A few times the diesel was in the shop, I pulled 10-12,000 lb liquid fertilizer trailers behind the 2013 RW we had as a spare. Did it handle it ok? Sure it did. Was it smart to do? Definitely not. But I did make a point to start braking a lot sooner than I did while in the DM, and overall was a lot more attentive while pulling that kind of weight. The diesel was a great at pulling anything, I think the heaviest load I ever put behind that 3/4 ton was around 20,000 lbs, and it handled it without issue. If it were me, I’d follow Chris’ recommendation and keep your Duramax for the heavy stuff and let the Tundra handle DD and light towing duties.
    ToyotaTrucksRock and Toyotoholic like this.
  4. Jan 21, 2018 at 3:27 PM
    ToyotaTrucksRock
    ToyotaTrucksRock New Member
    2014 Black Tundra Ltd Dbl Cab
    Limo tint windows, RollnLock, Spray in liner, 3m
    Welcome! I have to agree with what ColoradoTJ & zcarpenter have said. I too have used my Tundra for towing whenever I wasn’t able to do it with my Duramax. Yes the Tundra it has the power to do so but that’s it, especially when comparing 1/2 ton to a 3/4 or 1 ton. I’m fortunate to be able to have the best of both worlds, my 14 DC Tundra is my daily driver and my 16 GMC Duramax 1 ton is for my trailers. I drive a fair bit 70/75k per year with almost a even split between the 2.
  5. Jan 23, 2018 at 8:37 AM
    Alkhalifa
    Alkhalifa New Member
    Welcome to the Forum
