Is an AUTO LSD button a common option?
Discussion in '1st Gen Tundras (2000-2006)' started by Grumpy74, Feb 3, 2022.
  1. Apr 17, 2024 at 1:28 PM
    #91
    Bed Tundy
    Bed Tundy like changing a tire, the 1st time you're careful
    Spokane
    2005 Gold A/C 4.7 2wd, 2005 White A/C 4.7 4x4
    Light bar, ARE topper
    Oh yeah it doesn’t show up until you hit 25-30 mph. They’re off every time I start up.
    The maintenance rec light is to remind me to change the oil in 200 miles since I added 7oz seafoam to help disperse whatever gunk is built up. @Shifty I read your whole engine sludge ordeal and am going to run a short 3k OCI with cheap Dino 5w30 and auto-rx +, is that still a good protocol for a gentle clean without pulling valve covers?
  2. Apr 17, 2024 at 2:23 PM
    #92
    shifty` call-response overturns conviction every time
    I haven't used Auto-RX, I know everyone has their thing. I like BG products and Seafoam products. I know @The Black Mamba also likes BG products. I prefer Seafoam in the crankcase, it seems to be pretty gentle overall, and slowly works away at stuff. Don't want anything getting in there and busting stuff loose. In your case though, I wouldn't bother unless you know your heads are varnished up like mine were.
  3. Apr 17, 2024 at 8:54 PM
    #93
    Bed Tundy
    Spokane
    https://youtu.be/gdTIJYaIo8U?feature=shared
    Pulled fuses, disconnect and reconnect plugs with dialectical grease and checked wheel speed sensors today. Everything is connected that I can see, at least on the front 2 brakes. Going to try a zero point calibration tomorrow and I think that may fix this, but I guess it can be finicky when lifted.
    However once I do fix my vsc and trac- I may want to wire up a little switch just like this video and put it in one of my spare button holes on the dash so I can disable the system when I want. Skip to the end for his solution.
    shifty` likes this.
  4. Apr 18, 2024 at 3:22 AM
    #94
    That’s a cool video, wondering why you can’t simply have a dummy plug (resistor-based, maybe?) on the end of that that harness emulates a brake MC being attached.
    I don’t fully remember because it doesn’t apply to me; but I want to say the VSC trucks have a body roll sensor in them, somewhere under the center console, and that’s what detects your pitch or angle and triggers/engages VSC, and it flakes out? The part is NLA, and was spendy anyway. I wonder if the other solution may be NOP’ing out that little bastard?
    Bed Tundy[QUOTED] likes this.
  5. Apr 23, 2024 at 10:33 PM
    #95
    Bed Tundy
    Spokane
    I will have to look into that, so far Ive had no issues like the guy in the video with it function when unwanted. I do have two little yellow sensors in the front on either side of the radiator that my 2wd doesn’t have so I know it’s some kind of vsc magic.
