Jackalope's RCSB Build
Discussion in '2nd Gen Builds (2007-2013)' started by Jackalope, May 9, 2017.
  1. Nov 24, 2019 at 12:49 PM
    #91
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Very nice!
    What was the process, and what fog lights are those?
  2. Nov 24, 2019 at 2:01 PM
    #92
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Dude! Looking killer!
    Jackalope[QUOTED][OP] likes this.
  3. Nov 24, 2019 at 2:02 PM
    #93
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Can’t wait for a pic of the whole truck
    Jackalope[OP] and Rex Kramer like this.
  4. Nov 24, 2019 at 2:55 PM
    #94
    Jackalope
    Jackalope [OP] New Member
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    Thanks guys! I’m getting pretty close to done with the exterior of the shell. Will get a good photo of it next time I see a good opportunity.
    Opening up the headlights was pretty straightforward.
    -Pull the headlights off the truck. 2 screws up top and one on the fender side underneath the trim pieces below the light.
    -Remove the torx screws from the back side of the headlight and the rubber seals from around the reflector bowls.
    -Bake headlights in the oven at 215* for about 10 minutes (or until golden brown). Make sure you preheat the oven and the element isn’t red when inserting the headlights. This should greatly reduce the risk of meltage.
    -Separate the lens from the housing. Using a flat head screwdriver to pry between the lens and housing will help get it started.
    -Bezel comes out with the lens and is held in by two more torx screws. The plastic reflector pieces just snap into the bezel.
    -if you want to paint the high beam bowl amber, you’ll need the “canary yellow” Krylon stained glass paint. Mask it off and shoot 4 or 5 really light coats.
    -The bezel needs to have the chrome removed before painting. I used a red scoth brite pad under the kitchen faucet. It goes pretty quick as it isn’t a super thick coating. I didn’t remove it completely from the fine detailed areas but I got pretty close.
    -Paint for the bezel is up to you. Whatever you decide, I recommend a couple good coats of adhesion promotor before spraying.
    -I would give the bezels a while to dry before reinstalling the reflectors. They’re easy to scratch if the paint isn’t fully cured. Klearz.com also sells clear and smoked replacement reflectors if you don’t like the orange.
    -Reassemble the bezels into the lenses and stick the lenses back on the housing.
    -Bake the lights again and press the lenses firmly into place until all the clips re-engage the lens. They don’t ever fit like they did originally but you should get close.
    -Reinstall the torx screws and reflector seals and you’re good to go.
    Hope that helps! It sounds much more complicated than it is. I definitely recommend giving it a shot though!
    -edit: Rex, Fogs are just el-cheapos off eBay. Actually pretty nice for the money.
    #94
    Rex Kramer and Mountun Goat like this.
  5. Nov 24, 2019 at 6:25 PM
    #95
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Those look great. Nice work!
  6. Nov 25, 2019 at 11:00 AM
    #96
    Rex Kramer
    Georgia
    Your older brother from another mother.
  7. Nov 27, 2019 at 2:47 PM
    #97
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
  8. Nov 29, 2019 at 9:50 AM
    #98
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    Great build, looking forward to seeing what you've done with the cap.
  9. Feb 15, 2020 at 9:43 PM
    #99
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    Finally got the side door refit and the window on the other side. Working on the rear doors now. Ready for spring!
    D16932-D2-6340-41-A7-AE24-D3-BD05-AB08-C_c57b2cd099287c13c798f1f94e3e4a93db8902b7.jpg
  10. Feb 25, 2020 at 2:11 PM
    #100
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    Quick little antenna delete in prep for the snorkel install :cool:
    C60-CDC26-E4-A3-472-F-8624-E8-F4-B0-AFB6_12e75f32c2137008d056e352bc2a4952e3a7aff8.jpg
    80939-E1-B-6554-43-CE-A7-A5-F24008-F29-A_ec281c183046820ac2365d28bb957d07eca6fe2a.jpg
    Mountun Goat likes this.
  11. Feb 25, 2020 at 3:47 PM
    #101
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    How’s the liner holding up? Any chips or anything yet?
  12. Feb 25, 2020 at 4:10 PM
    #102
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    Still 100%. Love the stuff.
    Mountun Goat[QUOTED] likes this.
  13. Feb 25, 2020 at 9:32 PM
    #103
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good to hear, truck is looking boss.
  14. Mar 7, 2020 at 4:21 PM
    #104
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    Got the land cruiser 200 snorkel installed. Fits pretty good, just need to finish plumbing it. Had to order some different intake tubing.
    17-A5-EBFC-DAB4-4-C2-C-AACD-8613-F27560-_a464a566d2c58746bfd5b050c3da32231537ee02.jpg
    94053-BA2-61-E8-4-D6-A-8-A56-8-DAA43665-_37a1fa84da745d30c23eab0bb24e9246bdc0f5f7.jpg
    4-BB66763-36-D6-4-DCD-B7-B6-CD0762-C7-FD_c2e8f21cc16fe366007a16558df6085681f391a5.jpg
  15. Mar 7, 2020 at 4:56 PM
    #105
    Kiddnapped Tundra
    Grand Island, NY
    2010 Tundra DC
    Looks great, what happened to the Antanna?
    Mountun Goat and Jackalope[OP] like this.
  16. Mar 7, 2020 at 4:58 PM
    #106
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    It needs to be removed to facilitate the snorkel. I use my telephone and Spotify anyway :thumbsup:.
  17. Mar 16, 2020 at 8:59 AM
    #107
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Looks so good. Could you post a shot from the front of the truck? I would like to see how closely the snorkel lines fit the body lines. Thanks!
    Rica25 likes this.
  18. Mar 16, 2020 at 11:06 AM
    #108
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    here you go. I added some weatherstrip to the snorkel to fill the small gaps. If you didn’t know it wasn’t made for it you could never tell.
    134-D46-FF-8-BE2-4577-A990-9-ACC4014-EF9_107dbe97f20cbaffe885205335be93f26a810794.jpg
    9-E44-AA5-A-A5-FC-4217-BB63-911120-A2130_09f9334f11779009d19ac69ef584cc941c39543c.jpg
    8-C5428-E1-46-D4-4068-AB61-95-D671-A91-C_d669e8776326b4f3727551a4d69b86dde0a6a004.jpg
  19. Mar 16, 2020 at 11:21 AM
    #109
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice! Thanks
    Rica25 and Jackalope[QUOTED][OP] like this.
  20. Mar 16, 2020 at 3:40 PM
    #110
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
  21. Mar 16, 2020 at 3:57 PM
    #111
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
  22. Apr 4, 2020 at 6:54 AM
    #112
    Olenewt
    Olenewt New Member
    Southwest Missouri
    2008 Toyota Tundra SR5 4x4
    3" leveling kit
    How much of a pain was it to sand and paint your truck? I got a crew cab and want to line mine too.
  23. Apr 4, 2020 at 8:13 AM
    #113
    Jackalope
    Flagstaff, AZ
    2007 RCSB 5.7 4x4
    The outside isn’t too bad but the door jambs are a pain in the dick. If you want to do it right, everything has to come apart. It probably takes as much time prepping one door jamb as it does the whole exterior of the truck...and you have four...
    Olenewt[QUOTED] likes this.
  24. Apr 11, 2021 at 7:00 AM
    #114
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Bump. Do you have more info on how you setup the camper body?
    There is a guy selling the same exact one locally but without the side access doors. I bought a cheap slide-in truck camper a few years back to fix up, but it's not fixable. Those things are just too prone to water damage. This would make a great little camper and keep water out better I think.
    How heavy is it? Is it a pain to remove from the truck?
  25. Oct 12, 2021 at 6:31 PM
    #115
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Nice build. :101010:
