JBL owners with aftermarket headunit via idatalink maestro
Discussion in 'Audio & Video' started by BlueBottle, Nov 19, 2017.
  1. Jul 24, 2019 at 5:54 PM
    #121
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Looks great!!
  2. Jul 24, 2019 at 7:04 PM
    #122
    bfd300
    bfd300 New Member
    I have non jbl but I have a factory amp. I went with a pioneer and a powered sub I put under the seat. Holy crap it’s way better, crisper and louder with the stock speakers and. Apple car play
  3. Aug 17, 2019 at 11:23 AM
    #123
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I am wiring up and testing out my equipment that I got from James (Kenwood DNX996XR, Maestro RR, T02 harness, sT02 adapter, uT02 adapter) to my 2018 Limited with JBL.
    I have 3 questions I hope you all can help out with. I'm tagging @james@tech12volts in case he happens to be available, but I know family time takes prority and he's busy with the move so I figured maybe someone else here knows...
    1) What is this wire/connector for? I know the white one is for the GPS antenna.
    2) Is there a way to have the factory AUX input work? I have the uT02 adapter for the USB connection, but wasn't sure how to get the AUX input wired up.
    3) Is there any way to get the factory microphone wired up? I don't mind tapping/splicing wires but I haven't found much info for this. If I can use the factory mic and rewire it to a 1/8" jack to plug into the kenwood headunit, then I would like to try that instead.
  4. Aug 17, 2019 at 11:55 AM
    #124
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    I have the DNX996XR as well. You will love it. There is a new firmware update for it that's easy to do and makes Carplay work even better.
    There are two black connectors I think. One is the factory USB and the other is Sat radio antenna. I think in your hand is the USB because the sat should be a single wire and not a bundle.
    For the GPS ST02 kit you need to use the green/grey one for Kenwood. Green/green is Pioneer. The sat radio antenna adapter you will need a tuner if you want to keep Sat radio.
    For the UT02 adapter, depending on your phone model is what USB you want on the back of the unit itself. Black is Apple and Grey is Android.
    Did you get a factory radio antenna adapter by Metra? You won't need the blue wire from it as the factory antenna isn't amped.
    I don't think you will be able to use the AUX after taking out factory radio. I searched for an adapter and even to make it a dual USB adapter to no avail. I ended up changing out a 12V socket to dual USB just to charge multiple phones.
    You can't use the factory bluetooth anymore either. You have to use the supplied antenna. It's easy to remove the overhead console, and I changed out the factory Mic with the Kenwood mic after a little trimimng and some double sided tape and kept it in the stock location for a clean look. The wire is long enough to run down drover's A-pillar under dash behind steering wheel and into radio from there. I did not use the ODBII connector.
    The videos below were lifesavers. I soldered my connections, but did not take the wiring harness apart like these guys did. I did use the tesa tape they used for the harness.
    https://www.youtube.com/watch?v=xw8YkG6EDH0
    https://www.youtube.com/watch?v=GhiMy1GPayE
    AGia15 and BlueBottle[OP] like this.
  5. Aug 17, 2019 at 1:51 PM
    #125
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    1) I tried the white connector and it didn’t work as a gps antenna. One is a gps antenna the other is for sat radio.
    2) I have same adaptor. Only works for usb.
    3) not that I have found.
  6. Aug 17, 2019 at 1:52 PM
    #126
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Also just use the supplied gps antenna. I think it works better.
  7. Aug 17, 2019 at 2:17 PM
    #127
    silverhack
    Sacramento, CA
    Thanks @captainnemojr and @BlueBottle !
    So from what I've gathered...
    #1 - that black connector is for the Satellite radio, which sounds like I would need a tuner if I wanted to use that (which I don't)
    #2 - (Updated) The factory AUX input goes through the harnesses and comes out of the T02 harness in the form of the 'Aux input' RCA connectors (red, white, yellow) and you can connect it to the AV-In jack on the kenwood using this: https://www.amazon.com/Kenwood-CA-C3AV-Cable-Video-Input/dp/B001LRPLQ4/
    #3 - sounds like there is a way to use the factory microphone, but it requires disconnecting the amplifier that is attached to the factory mic, and rewiring the mic wires to bypass the amp. I'll get around to that eventually, but for now I'll use the microphone that came with the kenwood. (For details, see here: https://www.tundratalk.net/forums/t...cussion/118605-adding-aftermarket-stereo.html )
    I've finished my install and everything is working well so far! I'll try the firmware update too.
    captainnemojr and BlueBottle[OP] like this.
  8. Aug 17, 2019 at 2:36 PM
    #128
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You that usb input port should work. I don’t use the aux input so I never bothered researching.
    Wow nice find on using the oem mic. But it looks like more trouble than just squeezing the Kenwood mic in there lol.
  9. Sep 1, 2019 at 10:00 AM
    #129
    silverhack
    Sacramento, CA
    Note - I updated post # 127 with this info on the Factory AUX input:
    I tested this out and confirmed it works.
    Only audio (red & white) goes through, the video does not.
    AGia15 likes this.
  10. Feb 16, 2020 at 2:02 AM
    #130
    AGia15
    AGia15 New Member
    2018 Tundra Limited CM
    what was the issue? I’m having issues with no sound after install
  11. Feb 16, 2020 at 11:17 AM
    #131
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Make sure you’re using the right RCA plugs for the amp
  12. Feb 18, 2020 at 8:14 AM
    #132
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    I am planning on getting a pioneer head unit. Will any of the pioneer NEX models support toyota factory functions such as door locks and lighting? What should I look for as far as which one will work? Also on a 2020 double cab SR model, how do I know if I have a factory amp or not (want to get the proper wire harness). Thanks in advance.
  13. Feb 22, 2020 at 6:18 AM
    #133
    JayCO
    JayCO New Member
    @BlueBottle i recently installed a kenwood HU with the idatalink maestro RR. I don’t get any tire pressure data on that screen. I thought maybe my tundra was too old (2017) and didn’t have the required TPMS to report actual data. But then I looked at your pics above and saw that you’re reporting pressures and yours is a 2016. Any ideas?
  14. Feb 22, 2020 at 7:09 PM
    #134
    JayCO
    JayCO New Member
    Well I got it all working. Just reset the maestro module. Came back up with tire pressures. Woohoo.
