JL Audio Build w/OEM HU
Discussion in 'Audio & Video' started by Kilos, Jan 2, 2017.
  1. Feb 25, 2017 at 3:32 PM
    Berettafan
    Berettafan New Member
    2017 CM
    Can anyone confirm center speaker is the one voice control comes through. Seems you wouldn't want to disconnect if so.
    Dustydirt19 likes this.
  2. Mar 28, 2017 at 11:24 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Anyone know what are good side dash speaker replacements? Or are most people disconnecting them if they go with components
  3. Mar 28, 2017 at 11:33 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Thanks @GNTundra that's kind of what I'm thinking cause I plan on putting my tweeters in the sails
    GNTundra likes this.
  4. Mar 28, 2017 at 11:40 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    If I'm correct though I wouldn't want to disconnect the center dash speaker cause that one also controls the voice command correct?
  5. Apr 8, 2017 at 3:06 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    No it doesn't. The center dash is wired in with the other two dash speakers. The installers just disconnected it when the installed my Amp.
    4Runner and GNTundra like this.
  6. Jan 3, 2018 at 7:42 AM
    Kartunes
    Kartunes New Member
    James
    To answer the dash speaker questions.
    They run off the head unit not on the factory amplifier. In Brett's build we left them on the factory head if you place components on the dash and the kids in the doors you will have a time alignment issue the tweet is too far from the mid at that point. Running the dash speakers off the factory head unit unless you run a good prossesor.
    purplenova likes this.
  7. Jan 3, 2018 at 10:44 AM
    Vegas17
    Vegas17 New Member
    Alex
    Las Vegas
    2017 Black Out Tundra SR5 TRD 4x4 CM
    3-4 lift,Procomp tires,Lrg wheels,Tonneau,Stereo,Alarm,grill wrap,Carr steps,K&N air intake,flowmaster mufflers
    Check out FoxBox. I have 17 Crewmax with ported FoxBox and 2 10" JL shallow mount. Incredible sound and construction for (180 box only)
  8. Jun 19, 2019 at 10:28 PM
    Drogon
    Drogon New Member
    Could you PM the cost???
    I've been quoted $4500-$7800 for audio upgrade here in the Atlanta area and I am very interested in you setup.
  9. Jun 20, 2019 at 8:36 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    If you are anywhere near Georgia, you need to hit up James Randy Taylor at Tech12Volts. He’s in Alma. He is the king of things Tundra audio. His pricing is unbeatable as well. He has installed hundreds of systems in our Trucks.
    AZTundra likes this.
  10. Jun 20, 2019 at 10:20 PM
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    I did a full jl system as well sounds amazing around 2k for parts tho also james is the man to talk to, 2 10tw3 subs 2 pair of jl c2650 2 pair of c1 tweeters for the dash jl xd 1000/5 v2 jl base knob and a buch of sound dampening 20190510_125449.jpg
    Luckydog and louscrw like this.
  11. Jun 21, 2019 at 4:11 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Did mine in JL as well and went with the c3 speakers all the way around.
    Like night and day
  12. Jun 21, 2019 at 5:34 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I've got that exact amp and subs (I'm running 2 as well)
    Beastmode1794[QUOTED] likes this.
  13. Feb 10, 2020 at 8:27 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood Amp Tech12volts JL Tweeters Dasaita G13 Head Unit Fumoto Oil Valve Driver Side Grab Handle
    Beast! - hows the door speakers sounding?
    I just added the JL c1 dash tweeters and was thinking on the C2650's for the doors.
  14. Feb 10, 2020 at 11:51 AM
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    Awesome build! I will have to check them out
  15. Feb 14, 2020 at 8:18 PM
    bthomas
    bthomas New Member
    Bennie
    2018 Crew Max
    New to the form. Looking to upgrade my 2018 Crew Max Tundra.
    Did you replace the tweeters in the dash and the middle speaker also ?
  16. Feb 15, 2020 at 1:00 PM
    IBJC
    IBJC New Member
    has anyone toyed with the idea of running a three way setup with tweeter in the sails and mids in the dash sides and running new wire to the mid
  17. Apr 20, 2022 at 6:32 PM
    James scheppelmann
    James scheppelmann New Member
    Scheppelmann
    2017 inferno crewmax
    7in bds, 35x12.5r20 compustar remote start, aftermarket auto lights , front and side view cameras , dashcam, ditch lights,
    I've a lot of 3way systems. But the best way to do them is with a dsp processor. Otherwise you will have odd time alignment issues.
  18. Apr 20, 2022 at 6:33 PM
    James scheppelmann
    Scheppelmann
    Thanks Brett. I still love this post.
  19. Apr 20, 2022 at 6:40 PM
    #49
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I went all JL....amp subs c2's for the door and c1 across the dash... I tried the dsr1 with factory head unit and eventually pulled that and went Kenwood echelon 1007. The sound is amazing....put multiple layers of sound deadening on the doors ...floor and back wall. Got most of my stuff from James @tech12volt.
  20. Apr 20, 2022 at 7:01 PM
    #50
    James scheppelmann
    Scheppelmann
    James and I friends. We have different options on some things. But we both know these trucks quite well.
