Just bought my dream truck (in reality)...and need advice
Discussion in '1st Gen Tundras (2000-2006)' started by intellexualist, Jan 28, 2024.
  1. Feb 1, 2024 at 2:59 PM
    #61
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    You must not live in snow/ice/mud country, do ya? 2WD drivers I know are always late for dinner because they have to walk home.IMG_5854.jpg
    Elevatorguy likes this.
  2. Feb 1, 2024 at 3:03 PM
    #62
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    texas
  3. Feb 1, 2024 at 3:04 PM
    #63
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Yes sir, we eat them raw and I smoke them til they pop. That’s literally the only reason I kept my Weber charcoal kettle. Oysters are not going in my ceramics. Got my hand smacked before here for posting my back window of my truck. Hence the angle of the first pic and this one. IMG_0879.jpg
    ATBAV8[QUOTED] likes this.
  4. Feb 1, 2024 at 3:29 PM
    #64
    Elevatorguy
    James
    missed the type S question. We really like it, It’s the wife’s semi daily driver. I hardly ever drive it and it doesn’t leave the garage unless it’s sunny and dry. I did put over 2000 miles on it over the summer, Drove it to Florida and back. Nice car, quick enough for the wife. Next ride is my Supra. IMG_0208.jpg IMG_5624.jpg
    bmf4069 and ATBAV8[QUOTED] like this.
  5. Feb 1, 2024 at 5:18 PM
    #65
    jimf909
    Washington or Idaho
    Bring a 4WD to Idaho in winter, we don't want you to be late for dinner.
  6. Feb 1, 2024 at 6:00 PM
    #66
    FishNinja
    Lee
    06DC2wd
    mmmmk the CRV it is
  7. Feb 14, 2024 at 2:43 PM
    #67
    intellexualist
    intellexualist [OP] New Member
    Lex
    2000 Tundra AC V8 2WD
    I'm literally just going to be using it for hauling/pulling stuff. Not really stumps out of the ground like @shifty` says...although my truck is a lot less pretty on the outside paint job than his is; I probably SHOULD use & abuse it for the rougher stuff. My couple of acres doesn't even have one tree on it, thank god
    By the time I've gotten a fair bit of use out of it I'll probably have enough saved up to buy ANOTHER Tundra, this time a 2017/18 which'll have about the same amount of miles on it (used, ofc. I'm too poor for a huge-ass monthly car payment)
    FishNinja likes this.
  8. Feb 14, 2024 at 2:49 PM
    #68
    intellexualist
    Lex
    The gradual transmission fluid replacement method in my 2000 Tundra that I started the thread about, though...it seems to be going well (drain, replace with exact amount drained, drive 1,000 miles, repeat 4 or 5 times until I can safely assume all the tranny fluid has been replaced)
    It seems to be going okay, but after just going out there with a white paper towel and checking the fluid...it's ABOVE the "hot" line on the dipstick? Is this alright? I SWEAR I only put in the EXACT amount that I drained; how is it so full?
    I've read horror stories (on this and other forums) about TOO much tranny fluid in the truck being an issue, but wouldn't this...more or less help me in my aims to replace the tranny fluid gradually? I mean the more newer fluid there is, the more it can get in there and coax the older stuff out, right?
  9. Feb 14, 2024 at 2:50 PM
    #69
    You don’t add exactly what you took out. You add enough for the dipstick reading to be within spec. Doesn’t matter how much came out, only how much is in there.
  10. Feb 14, 2024 at 2:58 PM
    #70
    intellexualist
    Lex
    So since I just put the new stuff in, I should...drain it until it gets down to the recommended level on the dipstick?
  11. Feb 14, 2024 at 3:05 PM
    #71
    shifty` No Water in the Water Fountain
    ... and what the transmission temp is when you check it.
    KNABORES[QUOTED] likes this.
  12. Feb 14, 2024 at 3:07 PM
    #72
    intellexualist
    Lex
    Damn. I can’t believe I screwed even something THIS easy up. Lol
  13. Feb 14, 2024 at 3:19 PM
    #73
    And yes, you should check the fluid when it’s warm. Shift it through all the gears and then put it in park and leave it running. Check the dipstick then.
  14. Feb 15, 2024 at 1:40 AM
    #74
    Elevatorguy
    James
    it was a response to fish ninja, Not you.
