Katzkin Leather Heated/Cooled seats
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mattp81, Jan 23, 2019.
  1. Apr 19, 2019 at 2:24 PM
    Talkdirttome
    Talkdirttome Dad
    Jon
    So Cal
    2018 Silver Tundra CM 4x4
    Ventilated seats are a total game changer. Nothing like cooling off "the boys" on a hot day!
    mtucker likes this.
  2. May 24, 2019 at 6:50 AM
    pitrow
    pitrow New Member
    Has anyone had these for a bit and been able to compare comfort and heating/cooling function vs Platinum seats? The only reason I'm really thinking to bump up to a Platinum is bc of the seat comfort and the ventilation.
    I like the SR5 with TRD Sport package and would actually save some $$$ too if I went that route and added these, but haven't found a way to see how they feel in person.
  3. May 24, 2019 at 7:01 AM
    sgrounds22
    sgrounds22 New Member
    2018 Tundra Limited
    Are they vented or cooled? Do they use the AC or is it just a fan that blows air?
  4. May 24, 2019 at 7:16 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Seats look very nice and comfy. Where do you get them installed, or do you do the work yourself?
  5. May 24, 2019 at 7:25 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Do you have a link on how you did this and a parts list? Looks great!
    huntsonora likes this.
  6. May 24, 2019 at 7:26 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    This is interesting, I have the perforated Katskins. I want to see the tech for cooling, I assume you are not using the truck's system, how is it ducted? You Tube here I come.
    EDIT- NEVER MIND, WOW.
  7. May 24, 2019 at 7:37 AM
    alpinepro4
    Pat
    Your skull shifter is sick! Matches the leather seats nicely.
    TomC843[QUOTED] likes this.
  8. May 24, 2019 at 10:56 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    On the Platinum they are just a fan that blows air. On my '11 I couldn't ever tell they were working in Florida with black leather so I don't miss them on my '16 SR5.
    They are not like other vehicles i.e. Ford, etc. whereby those are actually A/C seats.
  9. Jun 5, 2019 at 4:42 PM
    tdollrsign
    tdollrsign New Member
    Has anyone had a chance to do a side by side comparison of the Katzkinz "air conditioned" ventilation system with a true factory installed ventilation/AC system? The only other ventilated seats I have experienced were in a 2008 range rover, and they were PHENOMENAL. Instantaneous cold air on a 105 degree day after it had been sitting in the sun for 2 hours. This was in 2017, so the truck was almost a decade old at the time with over 100k miles.
    As far as Katzkinz, literally EVERY piece of information I have seen about Katzkinz DegreeZ online states that they offer a "state-of-the-art heating and cooling system that provides 3-levels of heat and 3-levels of air conditioned comfort, you’ll find these innovative options offered exclusively from Katzkin."
    However, it does NOT feel like its air conditioned at all AND I can only feel it on the seat bottoms, not the seat backs, and it takes anywhere between 5 and 10 minutes to feel a difference. Doesn't seem normal to me, but I don't have anything to compare it to directly. For the amount of money, it SHOULD outperform various OEM ventilation systems, and it sure does not feel close. Maybe the installation techs forgot to unwrap the ventilation pads? Or they didn't run it into the AC?
    Before I bought the upgrade I confirmed with both the dealership I purchased the vehicle from, new, and the installation technicians that perform the upgrade for Katzkinz, that it was a true air conditioned seat. There was no talk of recirculated ambient air from the cabin, which would have stopped me from spending an extra grand. I live in the SF bay area, it gets hot, but its not the desert.
    Am I tripping? Or is this unacceptable?
    TIA!
    Skew12 likes this.
  10. Jun 9, 2019 at 3:50 PM
    sgrounds22
    2018 Tundra Limited
    Definitely should be A/C for the $.
  11. Jun 9, 2019 at 6:38 PM
    TXTundra2722
    2015 Black Tundra
    It's 100% NOT a/c. Think about it, you'd either have to run plumbing for your a/c to the vents for this or you'd need a separate a/c system to work this. This might be an expensive kit, but it would be extremely expensive if it was run from your a/c plumbing. Your a/c would also have to be running to even get anything from the system
  12. Jun 9, 2019 at 8:40 PM
    TomC843
    Tom
    Charleston, SC
    Watch the you tube install video. Its the same tech as the 12 volt plug in coolers. It also has exhaust port blowing into the cab.
  13. Jun 10, 2019 at 4:24 PM
    Touch-Ups
    Touch-Ups New Member
    Toby
    Jonesboro, AR
    The Katzkin degreez system is really the actual system used on F-150's. It's main component is called a TED (thermo electric device). It raises or lowers the cabin air by around 15 degrees and then a fan blows it through the holes of the seat cover. You do have to have the special reticulating foam added to your seat covers. Perforation alone will not allow it to function properly.
    TuFerLife likes this.
  14. Jun 10, 2019 at 5:04 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    This man knows what he’s talking about. They didn’t want to listen to me about reticulating foam.
  15. Jun 10, 2019 at 10:13 PM
    TXTundra2722
    2015 Black Tundra
    That's reticulous:)
  16. Jun 11, 2019 at 1:17 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    :rofl::rofl:
  17. Jun 11, 2019 at 4:26 AM
    War Machine
    War Machine SSEM # 5 3MW
    Which shop in Houston did you use?
  18. Apr 10, 2022 at 1:24 PM
    WiddleWadder
    WiddleWadder New Member
    2020 limited CM OR
    cap, drawers, organizers, roof racks
    How are these holding up after a few years? I'm thinking of getting them installed.
  19. Apr 10, 2022 at 1:57 PM
    #49
    TuFerLife
    Taylor
    Chattanooga, TN
    Mine are holding up well. The only problems I’m having is the suede k sweet I did on the sides are wearing down. It’s only on the driver side, but slightly annoying.
  20. Apr 20, 2022 at 5:14 AM
    #50
    Bradyboyy88
    Bradyboyy88 New Member
    Shaun
    Curious if anyone has a better placement for the switches. I’ve seen people put the heated seat circle switches by the cup holder and looks good. Just feel like these switch types don’t look stock and I love me an oem look.
  21. Apr 20, 2022 at 6:09 AM
    #51
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Put mine here
  22. Apr 20, 2022 at 6:18 AM
    #52
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Your seats look amazing. This is the mod I keep telling myself I need to work toward. I hit a dead end looking for an installer however I need to revive that search. Enjoy the heating and cooling!
  23. Apr 20, 2022 at 6:43 AM
    #53
    Bradyboyy88
    Shaun
    Not feeling those switches lol. I wonder if they could be swapped with something cleaner.
  24. Apr 20, 2022 at 6:46 AM
    #54
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Put them in yourself. Practice on one seat then do the rest. I didn't even have hog ring pliers and did mine relatively quickly.
    Sean492[QUOTED] likes this.
  25. Apr 20, 2022 at 6:49 AM
    #55
    Bradyboyy88
    Shaun
    you were able to install the cooling elements yourself?
  26. Apr 20, 2022 at 6:52 AM
    #56
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No I don't have those. I just did the seats. I'd put all of that in myself though. For what installers charge these days, yeah I DIY everything I can.
    TOYOTARIG likes this.
  27. Aug 9, 2022 at 11:47 PM
    #57
    pv355
    pv355 New Member
    Peter
    2018 CM SR5 5.7L 4x4 in Gray
    Installed: TRD Rear sway bar HIKARI Ultra LED H4 & HIKARI LED H11 Power tailgate lock JBL Stadium 5 + JBL GTO609c Kicker 43TCWRT102 in passive radiator box Waiting on install: Wishlist: Component speakers Leather seats + vented/heated Puddle lights Illuminated ignition ring ESP Rear seat storage Chrome grille delete Parking sensors
    I bought a set of katzkins have have been installing them myself. I've installed the backseats so far. Before I install the front seats, I am considering getting katzkin's heat/cooled seat kit.
    Do you need to have perforated leather for the cooling to work? My seats are not perforated.
    I really only want the cooling part. Is there any other kits besides katzkins?
  28. Aug 10, 2022 at 5:36 AM
    #58
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    Yes
  29. Oct 14, 2023 at 10:37 AM
    #59
    JohnWhicker
    JohnWhicker New Member
    Did you ever get your answer? Which shop in Houston? I am interested as well
    HoustonCoMo likes this.
  30. Apr 22, 2025 at 1:43 PM
    #60
    HoustonCoMo
    HoustonCoMo New Member
    Tuesday
    2020 Tundra SR5 Sport
    @Mattp81 Where in Houston did you get yours done? Im in Houston and looking to do the same
