Kenwood eXcelon Reference DMX1057XR
Discussion in 'Audio & Video' started by BamaMan44, Sep 29, 2020.
  1. Jan 7, 2021 at 11:55 PM
    #121
    BamaMan44
    BamaMan44 [OP] Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I mounted it in the stock location. It was a pain to get it there.
    619Tundra likes this.
  2. Jan 8, 2021 at 3:52 AM
    #122
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Do you have pictures?
    BamaMan44[QUOTED][OP] likes this.
  3. Jan 8, 2021 at 2:24 PM
    #123
    BamaMan44
    Andre
    Tucson
    Unfortunately, I don't.
  4. Jan 10, 2021 at 12:26 PM
    #124
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Has anyone done this after already upgrading speakers...sub and amp? Did upgrade a while back with a dsr1 and stock HU and doesn't quite get it done.
  5. Jan 10, 2021 at 12:28 PM
    #125
    619Tundra
    Speakers?
  6. Jan 10, 2021 at 12:33 PM
    #126
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I did JL C1's on dash C2's on doors and JL 10 inch dual subs in back....r900 JL amp. I'd like to just swap the HU and bypass the dsr1 if I can.
  7. Jan 10, 2021 at 12:34 PM
    #127
    619Tundra
    Buy a new HU and get rid of DSR1.
  8. Jan 10, 2021 at 12:35 PM
    #128
    dkrou
    dkrou New Member
    dan
    2019 tundra
    That is the plan
  9. Jan 10, 2021 at 12:42 PM
    #129
    619Tundra
    I got a new unit if you need one.
  10. Jan 10, 2021 at 1:01 PM
    #130
    dkrou
    dkrou New Member
    dan
    2019 tundra
    So it looks like if you have stock nav and sat radio you need the sirius tuner...AND the antenna adapter that supports factory gps AND sirius antenna? I guess I did not realize the factory GPS was going to show up for anything on the Kenwood screen?
    BamaMan44[OP] likes this.
  11. Jan 11, 2021 at 7:36 AM
    #131
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Is anyone as confused as I am????I guess you can buy the adapter from crutchfield that connects to both factory gps and factory sat antenna....the issue is this unit does not have any gps capability built in. Only if you connect wirelessly through apple car play....if you upgrade to DNR 1007XR that antenna adapter will pop up on the purchase list for crutchfield. If you hook all this up and are having GPS issues it is probably more due to your phone not the antenna...Most people that want live traffic don't spend the money on 1007XR since that is an app that goes through your phone just like WAZE. Guys I would love to be wrong on all this....
  12. Jan 11, 2021 at 7:43 AM
    #132
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I just use wayz on mine it always connects through apple CarPlay automatically and there’s a split screen so I can watch it and see what I’m listening to.
  13. Jan 11, 2021 at 5:02 PM
    #133
    BamaMan44
    Andre
    Tucson
    I bought the adapter to use the stock GPS antenna but it wouldn't get a signal. Ended up using the antenna that came with the head unit. No issues since.
    Tundraction and 619Tundra like this.
  14. Jan 11, 2021 at 6:01 PM
    #134
    dkrou
    dkrou New Member
    dan
    2019 tundra
    this headunit has no gps function so I don't get it...when u say you have no issues what are you have no issues with...waze or something else???
  15. Jan 11, 2021 at 7:09 PM
    #135
    Elduder
    Elduder New Member
    The DMX1057xr comes with a GPS antenna. GPS isnt software per say, rather hardware that in interfaced with software. The units have software that is used in coincidence with a GPS antenna. You can either use the ACC-SAT-TO2 and utilize the stock Toyota GPS unit or in the case of this Kenwood it comes with its own GPS antenna.
    Its the small black box lying under the yellow video inputs.
    panicman, TK1979 and BamaMan44[OP] like this.
  16. Jan 11, 2021 at 7:20 PM
    #136
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I see all that but what software app is it supporting in the ken Wood HU? It doesn’t come with navigation...if you are using Waze it’s connected through CarPlay on your phone it has no connectivity I believe through a hardwired antenna.
  17. Jan 11, 2021 at 7:25 PM
    #137
    BamaMan44
    Andre
    Tucson
    If you want to use Wireless CarPlay, then you have to have a GPS signal. I know it doesn't have GPS in the head unit.
  18. Jan 11, 2021 at 7:25 PM
    #138
    Elduder
    Elduder New Member
    GPS is hardware. Apps may need GPS to function, or may function via connection to your phone, that has a GPS in it. To know where you are you need a form of GPS. Kenwood supports apps, like Waze and carplay that both use the GPS in your phone to function, or may use the GPS in your vehicle.
    The DNX units are Kenwoods units with built in nav. You can add nav to a DMX by purchasing the nav unit with the stored maps, but running Waze or apple maps is much cheaper and works just as well, if not better.
    AZBoatHauler and BamaMan44[OP] like this.
  19. Jan 11, 2021 at 7:26 PM
    #139
    BamaMan44
    Andre
    Tucson
    I used the adapter and couldn't get it to work with the stock GPS Antenna. Had to use the one that came with the head unit.
    619Tundra and Elduder[QUOTED] like this.
  20. Jan 11, 2021 at 7:27 PM
    #140
    Elduder
    Elduder New Member
    Its not uncommon. I was lucky, my DMX906s worked with the SAT adapter. Actually worked better wireless than my other unit, the DDX7706s with wired carplay.
  21. Jan 11, 2021 at 7:37 PM
    #141
    BamaMan44
    Andre
    Tucson
    Yeah, I tried several times to get it to work. I got it to work once or twice but it would drop off after a couple of minutes.
  22. Jan 11, 2021 at 7:46 PM
    #142
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Waze is connected to yr phone it doesn’t I believe have any connectivity to the gps
    Waze works through yr phone not through a gps antenna in the unit
  23. Jan 11, 2021 at 7:48 PM
    #143
    BamaMan44
    Andre
    Tucson
    Yes, I know this.
    But if you want Wireless CarPlay to work with Apple Maps, Google Maps, Waze or whatever navigation app you want to use, you have to have a good GPS antenna signal. period.
    619Tundra and AZBoatHauler like this.
  24. Jan 11, 2021 at 7:56 PM
    #144
    dkrou
    dkrou New Member
    dan
    2019 tundra
    So you are saying the gps antenna supports blue tooth enabled CarPlay nav apps? Wow news to me thanks
  25. Jan 11, 2021 at 7:59 PM
    #145
    BamaMan44
    Andre
    Tucson
    Yep, I was surprised by this as well.
  26. Jan 11, 2021 at 8:29 PM
    #146
    Mrwes
    Mrwes New Member
    Using a GPS antenna helps with accuracy. Gets rid of any lag there maybe in direction prompts, vehicle location, and any other features, when connected wirelessly.
  27. Jan 11, 2021 at 8:57 PM
    #147
    619Tundra
    In order for CarPlay and Android Auto to work on the new units, you have to use the GPS antenna provided. Watch 5 star Car Stereo on YouTube about New 10" Touch Screen Radios. Learn the stuff.
    TxLock21 and BamaMan44[OP] like this.
  28. Jan 12, 2021 at 6:27 AM
    #148
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I’m assuming the ACC-SAT-TOT2 Adapter Cables crutchfield sells for the oem antennas will work too?
  29. Jan 12, 2021 at 7:22 AM
    #149
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I just got off the phone with Cruchtfield and they said if you have a Tundra that has both the Nav and sat radio now that adapter cable set will work with the 57 kenwood headunit with the factory antennas
  30. Jan 12, 2021 at 8:20 AM
    #150
    619Tundra
    So I guess the Kenwood provided antenna won't work? Is this what your saying?
