Kenwood eXcelon Reference DMX1057XR
Discussion in 'Audio & Video' started by BamaMan44, Sep 29, 2020.
  1. Feb 19, 2021 at 8:10 PM
    #211
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Is it easy removing that piece
    619Tundra likes this.
  2. Feb 20, 2021 at 7:20 AM
    #212
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Yes,
    Remove the business card holder, then the surrounding part around the card holder (they both remove with clips, takes a little bit or force). There are 2 torx screws there and two in the sunglass pocket. It comes right down. The sunglass pocket screws you have to come in at a slight angle, but not bad.
  3. Feb 20, 2021 at 8:33 AM
    #213
    xnaron
    xnaron New Member
    I read in the thread that people had issues with using the stock gps antenna. Anyone else have feedback for this and what adapter do I need to buy to connect it?
    Thanks!
  4. Feb 20, 2021 at 9:18 PM
    #214
    Danimal86
    Daniel
    Sacramento, CA
  5. Feb 21, 2021 at 2:55 PM
    #215
    BamaMan44
    BamaMan44 [OP] Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I had this issue with the adapter and used the GPS antenna that came with the radio. Mounted it in the center speaker area.
    Desolate and 619Tundra like this.
  6. Feb 22, 2021 at 9:14 AM
    #216
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    No I have not. Maybe other can chime in that have it working.
    -Mike
  7. Feb 22, 2021 at 9:17 AM
    #217
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Have you updated the stereo software?
  8. Feb 23, 2021 at 3:33 PM
    #218
    Danimal86
    Daniel
    Sacramento, CA
    Anyone able to get screen mirroring to work with a pixel phone?
  9. Feb 25, 2021 at 12:47 PM
    #219
    xnaron
    xnaron New Member
  10. Feb 26, 2021 at 4:52 AM
    #220
    BamaMan44
    Andre
    Tucson
  11. Feb 26, 2021 at 7:02 AM
    #221
    Danimal86
    Daniel
    Sacramento, CA
    in case anyone is wondering, screen mirroring only works on Samsung phones, i got this response from Kenwood:
    "I understand you are inquiring about the DMX1037S. With the mirroing casting feature I'm sorry to say that NONE of the Google Pixel phones offer that feature. That feature is only on the Samsung S 8, 9, 10 phones and the Samsung Note 8, 9, 10 phones. Not all phones offer that feature. "
  12. Feb 26, 2021 at 2:03 PM
    #222
    xnaron
    xnaron New Member
    Did anyone bypass the stock amp? I'm looking at the specs for the stock amp compared to the dmx1057xr and I think it would probably sound better with the dmx1057xr amp. If so I am interested in if there is a bypass cable available or if you had to make one?
  13. Mar 2, 2021 at 4:01 PM
    #223
    xnaron
    xnaron New Member
    Crutchfield suggests the 3.5mm RCA cable pictured above for the install. The idatalink wiring harness has an AV input to connect it to and it connects to the connector on the back of the radio outlined with the red arrow above. I'm not sure if this will activate the aux in or not?
  14. Mar 2, 2021 at 5:02 PM
    #224
    Mrwes
    Mrwes New Member
    That is the only audio input on the headunit. It's in audio/video input, you just have to make sure that whatever 3.5 you use has the audio contacts in the correct order. Not all will work.
    Watch this.
    https://youtu.be/ul-RvOCrwUU
  15. Mar 2, 2021 at 5:11 PM
    #225
    xnaron
    xnaron New Member
    Another thing I noticed is that the setup for my RR2 didn't give any option for climate controls. Is that normal to not have them on the Tundra (limited with lcd climate readouts)
  16. Mar 2, 2021 at 5:32 PM
    #226
    Mrwes
    Mrwes New Member
    No climate controls available for Tundra's.
  17. Mar 2, 2021 at 7:42 PM
    #227
    xnaron
    xnaron New Member
    thanks
  18. Mar 2, 2021 at 7:47 PM
    #228
    xnaron
    xnaron New Member
    I did build an amp bypass connector to bypass the stock non jbl amp. I have to say the sound quality is incredible even with the stock speakers. I will probably still upgrade them but will be more than happy with it until I do.
  19. Mar 3, 2021 at 11:11 AM
    #229
    xnaron
    xnaron New Member
    I am having one issue. I programmed my steering wheel controls for volume+ and volume- on single press and hold. When I hold the volume down button the volume will run down normally. However if I hold the volume up it only works from 0 to 15 volume level. It stops when it hits 15 and I can only single press to increase the volume higher. Am I missing something?
  20. Mar 3, 2021 at 11:34 AM
    #230
    AZBoatHauler
    So.Arizona
    That’s the HU. Pretty sure it’s a safety feature so you don’t accidentally blow your speakers or ear drums.
  21. Mar 3, 2021 at 11:36 AM
    #231
    xnaron
    xnaron New Member
    Good to know. Thanks!
  22. Mar 3, 2021 at 11:49 AM
    #232
    xnaron
    xnaron New Member
    I located my mic at the top console where the factory mic was. I am using android auto to make calls and I had one person say they had a hard time understanding me. I called a friend and he said it sounded ok. I left myself a voicemail so I could hear it for myself and it definitely wasn't the best quality I have heard from a handsfree phone. It sounded washed out and hollow. I see there are some mic adjustments in the menus. I'll try and see if I can make it sound better. Anyone else experience this? Maybe I should reposition my mic. It is pointing straight down into the slits on the console.
  23. Mar 3, 2021 at 11:53 AM
    #233
    Desolate
    Desolate New Member
    2019 White Crewmax Off Road
    I bought the plug and play amp harness from autoharness on Amazon. Worked great and sounds much better without the factory amp. This is a must if replacing the door speakers with components as the factory amp has built in crossovers
  24. Mar 3, 2021 at 11:55 AM
    #234
    Desolate
    Desolate New Member
    I just called the wife while driving on the freeway and messed with the settings until she said it sounded better. I still haven't heard myself, but everyone seems to think it sounds fine now.
  25. Mar 3, 2021 at 11:57 AM
    #235
    Danimal86
    Daniel
    Sacramento, CA
    anyone remember if there's an option on the maestro RR if there's an option for when you hold down the volume up button if it will continuously increase the volume? I didn't enable anything for holding volume up, and i miss just being able to hold the up button and letting it rip.
  26. Mar 3, 2021 at 12:09 PM
    #236
    xnaron
    xnaron New Member
    Were you calling using the phone dialer built into the kenwood or using carplay or android auto? I didn't see any settings I could tweak in android auto.
  27. Mar 3, 2021 at 12:21 PM
    #237
    Desolate
    Desolate New Member
    I can't remember but I believe it doesn't make a difference if you just click settings when in Android Auto you still should be able to adjust all settings
  28. Mar 3, 2021 at 12:26 PM
    #238
    xnaron
    xnaron New Member
    Ok I'll check it out and see if I can find something to adjust. The other thing I can try is temporarily removing the mic from the console to see if that makes a difference.
  29. Mar 3, 2021 at 12:27 PM
    #239
    xnaron
    xnaron New Member
    It is a limitation of the Kenwood units (safety don't blow speakers or ears). Not adjustable with Maestro (I asked them directly before reading the response I got here)
  30. Mar 3, 2021 at 12:35 PM
    #240
    xnaron
    xnaron New Member
    Switching from BT to Speakerphone in android auto sounds better but it is using the mic on the phone not the kenwood one. It's very possible my mic placement isn't good.
