Key Fob Replacement 2002 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Peterv, Oct 29, 2019.
  1. Apr 7, 2023 at 2:43 PM
    #241
    daveeasa
    David
    My Tacoma re-locks if no door opened in time. Lemme check my Tundra. I forget.
    Yeah, looks like it auto locks if you don’t open a door in time. I had forgotten.
    perhaps a spare key in a hitch safe or something? I wish I got to use my truck for real work.
  2. Apr 7, 2023 at 2:59 PM
    #242
  3. Apr 25, 2023 at 3:13 PM
    #243
    ToyotaSimp
    ToyotaSimp New Member
    02 SR5 3.4l Rwd AT
    Bone Stock.
    [​IMG] Bump this thread got my 02 sr5's rs3000 setup. Got a oem fob new at the local dealer and matched the FCC to the unit in my dash.
    It's a new to me truck and I had a feeling it had a system based on the quality of the door locks. Made an account just to say thanks.
    Edit: One question tho.
    One button does lock/unlock. The other lights up the bulb on the fob but the truck doesn't react. What would or could that be for? My truck is a pretty basic sr5 so I wouldn't be surprised if it's a feature I'm missing? Maybe I have to program that button?
    shifty` likes this.
  4. Apr 25, 2023 at 10:07 PM
    #244
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Something to do with programming the bottom button for another Toyota vehicle. I have 2 Toyotas with the same RS system but I've never messed with it. I have no source for that but I swear I've read it.
  5. Oct 12, 2023 at 7:47 PM
    #245
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I figure this might be the best thread to post this up on, but i’m trying to figure out if i have keyless entry on my 2004 Access cab. I think i do?...but there were no key fobs included when i bought the truck. I looked up my build sheet and it shows “VP SR5 Extra Value Package”. I believe that remote keyless entry is part of that package.
    So if indeed i do have keyless entry, what do i need to buy or so to get it all hooked up and working?
    EA6989A9-8817-47A6-9451-84C3CB35EDA6.jpg 18B7C578-20C5-4B69-8106-FE0F75D53CCD.jpg A11D38C0-956C-48EB-990C-BCD0572B5765.jpg CF454591-96E0-450C-80EA-32F031DC5B69.jpg F4B8C780-53C0-4960-972E-376FF0CE8009.jpg
  6. Oct 12, 2023 at 8:15 PM
    #246
    Purple label is the RS3200 system/ECU. Looks like all you’d need is a compatible key fob and to program it. Easy peasy. You need the part number to hunt for? I would recommend used OEM off fleaBay but you do you.
    FCC ID for RS3200 is BAB237131-056
    If you search on that FCC ID you can find them. If you want the actual Toyota p/n, I can fetch that real quick.
    whodatschrome likes this.
  7. Oct 12, 2023 at 8:24 PM
    #247
    whodatschrome
    lots of dents
    I would much appreciate a toyota part number as well.
  8. Oct 12, 2023 at 9:09 PM
    #248
    08191-00922.
    Other compatibles for part numbers since discontinued are 08191-00921, 08191-00920
    Try removing the hyphen if the part number doesn't pull anything for you.
    Anyone reading this later: The part numbers are only good for RS3200 systems for later models (2003+ I think?) and not earlier models like the 2002 this thread is originally about.
    whodatschrome[QUOTED] likes this.
  9. Oct 13, 2023 at 1:56 AM
    #249
    daveeasa
    David
    And nobody with an ‘02 or older has converted to the RS3200, right? I will say that RS3000 really doesn’t feel satisfying to me compared to modern keyless and the fob behavior and options are kinda lame too. But it sure beats manual locks.
    At some point I will attempt something in my ‘05 Tacoma for keyless entry.
  10. Oct 13, 2023 at 5:33 AM
    #250
    whodatschrome
    lots of dents
    What’s the difference between the 3000 and the 3200?
  11. Oct 13, 2023 at 5:37 AM
    #251
    daveeasa
    David
    Fobs, FCCID’s, etc. I’m not sure I’ve ever used the RS3200 hence the interest in hearing more about it. The RS3000 stuff is kinda weak overall. But at least it works.
  12. Oct 13, 2023 at 7:17 AM
    #252
    I'm not sure about the differences. But it could be interesting to get the pinout of both, if for nothing more than figuring out if they're transposable. Maybe something to Google out on later for me, just because curiosity is ringing in my brain. Wouldn't it be nice if the system is integrated and the harnesses matched, so upgrading was plug n play? But I'm guessing the chances of that are super low.
  13. Oct 13, 2023 at 2:45 PM
    #253
    daveeasa
    David
    Pretty safe bet.
  14. Oct 13, 2023 at 4:47 PM
    #254
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Interesting thread on that other site suggests that upgrading from rs3000 to rs3200 is relatively easy...caveat emptor!
    shifty` likes this.
  15. Oct 14, 2023 at 6:07 PM
    #255
    Galladanb
    Galladanb New Member
    Southeastern Tennessee
    2002 AC Sr5
    After having read through all 254 posts in this thread, yikes!
    Honestly, this guys solution to adding fob’s to his taco may well be a good gamble to try on our first gen tundra’s…????
    https://youtu.be/tCApTmkOzK8?si=ca95WS0W8yZrPvEI
  16. Oct 28, 2023 at 8:51 PM
    #256
    whodatschrome
    lots of dents
    Thank you sir for the part number to fit my RS3200 box! Fedex delivered my key fob arrived this afternoon. I found a video on youtube on how to program it. It was super quick and easy. I’m super stoked to have a keyless entry in my truck!
    Here’s the video that i watched to program my fob. And FYI, this is for the 2004+ tundra.
    shifty`[QUOTED] likes this.
  17. Oct 29, 2023 at 5:44 AM
    #257
    Awesome, hopefully it didn’t cost an arm and a leg. Note: there are some custom features you can program in. If you go to the mega-info-dump thread, there’s a link to RS3200 programming instructions that will work for all AC/RC trucks, and let you customize stuff like … auto-lock after shutoff/departure, auto-lock when you start the truck, unlock all doors vs only driver, etc (IIRC)
  18. Oct 29, 2023 at 5:52 AM
    #258
    daveeasa
    David
    One thing I wonder about between RS3000 and RS3200 is signal strength. I have particularly poor signal with my nonstandard flip fobs. Might compare with the OEM chain fob sometime. I have to be super close to get it to fire. Still better than a key in the door though.
  19. Oct 29, 2023 at 9:53 PM
    #259
    NickB_01TRD
    Nick
    KY
    My rs3000 on original remote is garbage when it comes to range as well. I have to be pretty close, better than nothing though.
  20. Oct 30, 2023 at 1:25 AM
    #260
    w666
    Maryland
    I know i sounds weird, but hold the fob against your cheek bone when you press it...it will double the range!
  21. Oct 30, 2023 at 1:53 AM
    #261
    NickB_01TRD
    Nick
    KY
    I've heard that but I haven't tried it
  22. Jan 14, 2025 at 9:00 AM
    #262
    theleeb
    theleeb New Member
    Tom
    Upper Marlboro, MD
    2002 Tundra Access-cab SR5 4x4 4.7L; 2016 Tundra Crew Cab - Limited
    This thread is very informative. In my case I removed the kick plate and duct and have access to the ECU. After swapping the connectors and turning the key to the ON position, I was pretty excited to finally arrive at the final step of programming the fob. All I had to do is push the green button shown in the picture for three seconds and wrap it up. Welp, after all that....the green button does not push in. Tried a pen, small phillips, doesn't matter. A bit depressing (no pun intended). Did some research and I see that a couple others had the same issue but no solution. Anyone here run into this show-stopper? If so, any suggestions?ECU - push button.png
  23. Jan 14, 2025 at 9:13 AM
    #263
    Pic is too blurry, so I can't tell what type of button it is. If it's a microswitch, is it possible the button is just stuck from age? Maybe you could take a punch, and give a light tap with a hammer to un-jam it?
  24. Jan 15, 2025 at 5:54 AM
    #264
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    Where exactly would I find that module? My 2006 has what I believe a port installed keyless entry, so maybe this is how I can finally program my new FOB.
    If I can find it, does that green button pair it to the FOB?
    thx
  25. Jan 15, 2025 at 6:05 AM
    #265
    You won't have that module. What's pictured is the RS3000 system, which was installed in 2000-2002 year trucks.
    And trust me, you don't want it.
    Programming instructions for your truck are in the 'Electrical stuff ... and keys' section of the community megathread. You have a DC, and system is a port, so the instructions will be one of the two known for DC, most likely. Note that the timing in the steps is crucial to entering programming mode. Try to space the sequence steps at 1-second intervals.
  26. Jan 15, 2025 at 6:10 AM
    #266
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    Thx for the heads up. I wont go tearing apart only to be disappointed :)
  27. Feb 3, 2025 at 8:59 PM
    #267
    theleeb
    theleeb New Member
    Tom
    Upper Marlboro, MD
    As a follow up, someone mentioned to check the fuses for the ECU (for RS3000 system) as they believed the push-button might be powered electronically. I was hoping that would be the issue...there are two fuses on the fuse chart labeled "ECU"...checked both and they are good. I think I've gone as far as I can go without having to take it to a dealer.
  28. Feb 24, 2025 at 2:10 PM
    #268
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    JFC this is a pain! . I have the -056 fccid per my owners manual. I'm just looking for the guts from a factory fob and all the used ones on eBay either say hyx....or whatever on the fob photo. Should the number on the back of the factory fob match what's in the owners manual? Sorts corn-fused.
    The fobs I have now have both broke.at the ring problem is I bought the AJT case but the aftermarket fobs I have are just enough different that the circuit or the gasket or both don't fit in it without setting off the fucking panic button. Guy @AJT said to modify the case cuz it's the aftermarket stuff that's causing it to not fit right. Didn't say what to modify though. I'd rather find a used factory fob just for the guts..
