Knock Sensors Plus
Discussion in '1st Gen Tundras (2000-2006)' started by Brad Majors, Apr 18, 2023.
  1. Apr 19, 2023 at 12:37 PM
    Both of your knock sensors are definitely bad?
  2. Apr 19, 2023 at 1:23 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    That doesn't sound right. Mine was $50 5 years ago and had 2 connectors for the sensors, and 1 for something I didn't have.
  3. Apr 19, 2023 at 1:26 PM
    Stealership may just be quoting him for the actual wire/conductor with the correct ends, for you to re-pin shit on his own. Lemme go look that part up...
  4. Apr 19, 2023 at 1:29 PM
    Here you go. Here's what they're trying to sell him, something he can make for about 90¢, but it's as I expected: It's got the harness-end pin, with a tail on it. They probably make this in different colors, where the color changes based on the last 3-4 digits. It looks like 82998-12790 he was quoted is white, 82998-12780 is red, etc. EDIT: But it's weatherproof (note the red boot), as whatever goes in there needs to be, which is important.
    bmf4069 likes this.
  5. Apr 19, 2023 at 1:44 PM
    Brad Majors
    Brad Majors [OP] Life is just a Tire Swing...
    The Swamp
    '05 Tundra Double Cab Limited, 2WD 4.7L w/Factory Tow Pkg
    Damn - @shifty` - you are more on top of things and I will ever be. What you showed the photo of looks correct. I feel like it's something I could make including the waterproof boot. Would heat shrink do the same thing?
  6. Apr 19, 2023 at 1:45 PM
    Brad Majors
    The Swamp
    @KNABORES - I no longer think the sensors themselves are bad. Based on what I'm pretty sure I saw, the wires have been chewed and the wire harness has been separated from the connector which is attached to the sensor itself. It's a safe bet the rodent didn't chew one and leave the other alone.
    KNABORES likes this.
  7. Apr 19, 2023 at 1:46 PM
    Brad Majors
    The Swamp
    @bmf4069 - I feel like I saw somewhere in this wandering trip down the rabbit hole somebody who had a wire harness or connectors with pigtails but I don't know where that was. What @Shifty shared is what they gave me the product number for. Everything under there looks pretty clean and dry so I may be OK as long as I can find the right connectors and do this correctly, but clearly Toyota feels they need to make their money.
  8. Apr 19, 2023 at 1:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It's close to what McGeorge Toyota wants....$18.00 ea
    If you do choose to go that way, see if they have the connector listed in the 2005 EWD's for knock sensor....90980-11875
    If you had a Pik-A-Part place in your area, I'd consider making a visit there.
  9. Apr 19, 2023 at 1:48 PM
    Brad Majors
    The Swamp
    @BubbaW - a U Pick is a great idea... Good chance I can find one not too far from here.
  10. Apr 19, 2023 at 1:53 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If you're fortunate to find a place like that, be cautious on removal....heard they can be difficult ??
    "Cheese-eaten Rat"
  11. Apr 19, 2023 at 1:59 PM
    We're all on top of it, we just want to help another bro out.
    No, heatshrink won't make that boot. But Bubba has a great point: You can hit a JY and if you can't find the right sensor harness, you can probably pull just about any water-resistant harness under the hood with 4+ wires and matching size pins, then de-pin and use those wires as he mentioned here:
    Also, @daveeasa also has the tools to make harnesses, and if you tell him the wiring colors, I reckon he can actually just make you a couple pigtails and give you directions on how to de-pin. Re-pin is as easy as orienting/clocking the terminal correctly, then clicking into the connector.
    FWIW, it looks like there's a Texan on fleaBay who also does just that: Hits JY, yoinks harnesses, de-pins, and sells similar length of wires in any color you want. But it's $10/2 wires. I can link him up if you want, but I'd lean on Dave first.
  12. Apr 19, 2023 at 3:08 PM
    daveeasa
    David
  13. Apr 19, 2023 at 6:21 PM
    Brad Majors
    The Swamp
    @shifty` - thanks for the pointer towards @daveeasa ... I also suspected it would be a no go on heatshrink.
    I never thought of just going and pulling any kind of harness and then repurposing the wires.
    I will try to get in there under the hood and work to determine colors.
    @daveeasa - do I need to order new connectors or can I use the one of which the wire has been severed from and just remove the pins? Or is that way more work than I should invest, and I should just buy two new connectors?
  14. Apr 19, 2023 at 6:24 PM
    Brad Majors
    The Swamp
    ...And, real quick like, I just have to put out a general thank you.
    I don't have this current matter resolved yet, but it feels waaaaay better venturing into the unknown with this community.
    shifty` likes this.
  15. Apr 19, 2023 at 6:35 PM
    daveeasa
    David
    Depends if you have adequate length on the existing wire or on some replacement harness with compatible terminals.
    I’d want to color match the wire so I’d just do something up clean with new parts. Unless the wire is long enough and it’s possible to crimp on new terminals and live with shorter total length.
    shifty` likes this.
  16. Apr 19, 2023 at 10:01 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I'm confused here
    Could you not just buy one of these and splice in with a heatshrink butt connector or similar?
    Link
    daveeasa likes this.
  17. Apr 20, 2023 at 4:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Whoa whoa whoa, there's no need to de-pin or anything like that. The harness I got literally plugs into the knock sensors and into a harness somewhere on the 05-06. I only had to splice mine because I didn't have that connection. I don't have the pics, but they're in my threat I linked.
  18. Apr 20, 2023 at 4:54 AM
    Brad Majors
    The Swamp
    @NickB_01TRD -if I understand correctly, heat shrink might not hold the connectors together or be watertight.
  19. Apr 20, 2023 at 4:55 AM
    #49
    Brad Majors
    The Swamp
    @bmf4069 - do you recall where you acquired your harnesses? Do you have a part number possibly?
    I need to be able to make the process idiot proof so I don't screw things up. 'Cause if I can, I will.
    bmf4069 and KNABORES like this.
  20. Apr 20, 2023 at 6:50 AM
    #50
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I got it from Street Toyota here in Amarillo. I just went up to the counter and said I need a knock sensor harness. I don't have the part number, but it should be around $50 or so.
  21. Apr 20, 2023 at 6:50 AM
    #51
    Absolutely. It's what I would do. Either use an insulated watertight butt splice to join to the OEM lead, or if you have a soldering iron, I'd slip a heatshrink tube over, then solder together with a proper mesh joint, apply dielectric grease to the joint (or liquid electric tape in a pinch) before slipping the heatshrink tube over and locking it down. 2m49s shows the proper way to make a mesh joint, I'm only including this b/c OP shared he may not be super savvy. Could be worthwhile to wrap all the connections under there in 1/8 wire loom also, so any future rodents would chew the loom before getting to the harness, but I dunno.
    https://www.youtube.com/watch?v=lopgp5Pt3hc#t=2m49s
    NickB_01TRD[QUOTED] likes this.
  22. Apr 20, 2023 at 9:11 AM
    #52
    Brad Majors
    The Swamp
    Doing a little bit of research, I came across this on scamazon:
    I haven't heard of the brand and I'm not even sure it would fit to begin with but wanted to hear from y'all.
    @shifty` I'm looking at that space how the rodents get through and I'm wondering if stuffing it with steel mesh would do the trick (not steel wool because of course that stuff rusts if you think about it.)
  23. Apr 20, 2023 at 10:20 AM
    #53
    Bronze and brass wool don't rust. I was thinking more like 'hardware cloth' for fencing (1/4" square), or even strainer mesh. Anything that would allow some breathability but too small for rodents to enter.
    And your link to scAmazon failed.
  24. Apr 20, 2023 at 10:22 AM
    #54
    Brad Majors
    The Swamp
  25. Apr 20, 2023 at 10:30 AM
    #55
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  26. Apr 20, 2023 at 10:36 AM
    #56
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  27. Apr 20, 2023 at 10:57 AM
    #57
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    @bmf4069 has done this, so he may be correct but notice this from that link....
  28. Apr 20, 2023 at 11:00 AM
    #58
    Brad Majors
    The Swamp
    @Bubba - I saw that. This is becoming a huge pain in the ass but I guess if it was easy everybody would do it.
    shoot...
  29. Apr 20, 2023 at 11:03 AM
    #59
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If you look in my thread, it looks like it should fit. The 00-04 didn't have a connector to hook into, it just splices in.
  30. Apr 20, 2023 at 11:05 AM
    #60
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
