Land Cruiser V35A Engine
Discussion in '3rd Gen Tundras (2022+)' started by Jowett, Jul 5, 2021.
  1. Jul 31, 2021 at 10:36 PM
    #61
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    My buddy had one of those way back in the day. It chewed up every cent he had but he loved it. It was more like having two inline v6 than a v12. Everything was doubled. Crazy design
    TK1979 likes this.
  2. Aug 1, 2021 at 11:10 AM
    #62
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    I truly thought a Turbo engine would get twice the mpg towing the same load at high altitude, or any load at high altitude actually. Not the case realworld, on par at best with the 5.7l. Same mpg with a bit more power doesn't get me all giddy about a complex twin turbo. We're always over 5300ft on the Colorado Plateau, YMMV of course.
    I'm always interested in a powertrain that maximizes both power and mpg. In my case a hybrid Sequoia could be the future.
    TK1979 likes this.
  3. Aug 1, 2021 at 11:52 AM
    #63
    JuicyJ
    JuicyJ New Member
    It takes a certain amount of power to tow heavy weights. The only trucks that can get "good" MPGs when towing are diesel trucks.
    Gas powered trucks with significant loads all guzzle gas at exactly the same rate, no matter what type of gas engine they have, and even if they are hybrid. Hybrid systems just can't generate the sustained high power levels needed to improve MPGs under load.
    The main differences for gas powered trucks are how they get better MPGs when unladen. The F-150 went on a weight diet. Other trucks use tall gearing, aggressive upshifting and cylinder deactivation. The 2 worst trucks for MPGs are the Titan and Tundra, because both use short final drives, somewhat normal shifting patterns, and drive like a "normal V8", meaning they feel much peppier because all cylinders are always on and the gearing is short. All of the MPG tricks, lighter weight, hybrid, cylinder deactivation, tall gearing, go out the window once significant weight/load is applied....all trucks need to start dumping lots of fuel and bypass their usual MPG tricks to keep up with a load.
    TK1979 and Acedude[QUOTED] like this.
  4. Aug 1, 2021 at 12:41 PM
    #64
    Wallygator
    You sold me! Wow thats great to know cuz the only thing I worry about is how fast I can tow up a mountain...SUPER IMPORTANTE! :blahblah:The fact the F150 beat my truck by 0.11 seconds up that mountain makes me want to sell my Tundra. :tumbleweed:
  5. Aug 1, 2021 at 4:14 PM
    #65
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Don’t forget the other trucks burned less fuel while pulling up the mountain faster.
    I expect the V35A-FTS is going to be a beast. If it sounded like I was suggesting you buy a Ford that was not the intent. I was demonstrating that 1.) Forced induction V6’s can out perform a naturally aspirated V8. As a bonus 2.) Said forced induction V6 can do it burning less fuel in the process.
    Tundra_power and TK1979 like this.
  6. Aug 1, 2021 at 4:17 PM
    #66
    Coal Dragger
    Kung Fu Dick
    The test only allows them to go the speed limit, so the EcoBoost would have been capable of accelerating “at any time” at that altitude according to the driver who had to back off so they weren’t speeding. In comparison the Tundra was giving all it had, and couldn’t do the speed limit.
    So we’re not talking about a little bit more power, we’re talking about a lot more power at altitude.
    Johnders2586 and TK1979 like this.
  7. Aug 1, 2021 at 9:09 PM
    #67
    Acedude
    Acedude New Member
    Colorado Plateau
    Extra power is fine with me but if the mpg's are not better that disappoints me. In my case, my case only, I don't need the extra power. I need mpg's towing from Denver to Durango and back every month of the year.
    Anyway, here's another article about the V35A in the LS500 Toyota V35A-FTS 3.5L Twin Turbo Engine Specs, Problems, Reliability, oil, LS 500 (motorreviewer.com)
    The debate is moot of course because if I want a new Sequoia to replace the 2019 it will have a TTV6. I do hope the new Seq will have a larger stock fuel tank. If the LC300 gets 29g's the new Seq hopefully gets 29+g's.
    TK1979 and Coal Dragger[QUOTED] like this.
  8. Aug 1, 2021 at 9:46 PM
    #68
    Coal Dragger
    Kung Fu Dick
    Unless a Diesel engine is an option or the hybrid proves to be good at improving towing efficiency, I don’t see the V35A-FTS saving tons of fuel towing in the mountains over the 3UR-FE. If you’re working the truck to make road speed you are going to have to make “X” amount of horsepower, and if that number is pretty close to full rated power there is no free lunch. It then comes down to the energy potential of the fuel, and diesel has more energy potential than gasoline and is able to be burned in a higher compression environment without detonation.
    The most significant way you can save fuel is by slowing down. Less air resistance, lower cruising RPM’s on everything means less friction and less rolling resistance. There’s a reason class 8 trucks are tooling along at 60 MPH on the highway even when it’s an owner operator with a big 600HP rig capable of cruising around with a load at or above the speed limit.
    Even diesel pickup truck owners can frequently be seen complaining that their trucks don’t get the same mileage they used to. Well no shit guys, 25 years ago a diesel 1 ton made 240HP and wanted to tow trailers at 55-60 MPH. You don’t get to make 475HP and 1000lb-ft of torque and tow the same trailer at 75 MPH and get the same mileage.
    What the new engine is going to offer is approximately equal fuel consumption towing to the 3UR-FE, significantly better mileage unladen, and significantly more power. The power difference will be even more noticeable for those of us 3000ft above sea level and up. That 3% power loss every 1000ft of altitude gain for naturally aspirated engines starts to stack up past that, and a turbocharger does a damn good job of compensating for that to keep you at or near full rated power.
    Figure pulling the grade to the Eisenhower tunnel at 11,000ft our 3UR-FE that makes 381HP at sea level is only cranking out 255HP up there! That’s only 239lb-ft of torque being made at 5600 RPM. Think about that: it’s less powerful at 11,000ft than a Tacoma with a 3.5L V6 at sea level!
    Everyone has different goals and needs, for me as long as it is safe and within my capabilities as a driver and the equipment, I will happily trade a bit of fuel consumption to make point A to point B take less time. Then again I don’t tow frequently, so the fuel costs I would save on the rest of the time more than make up for the fuel costs to do my infrequent towing. I just make sure I’m on fresh oil, premium fuel for cheap insurance against knock (maybe some octane booster too if it is a hot day), a full coolant reservoir, and inspect the tires and draft gear. Make sure I have tools with me, and off I go. I will slow down quite a bit compared to my normal pace though, I don’t trust most trailer tires any further than I can toss them, nor the wheel bearings. When you tow borrowed trailers, or rented trailers that is just how it is.
    careyrob likes this.
  9. Aug 2, 2021 at 3:42 AM
    #69
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    If you're towing heavy on steep grades you're also more likely to keep the transmission torque converter locked up (a good thing) if you just downshift and slow down.
    Keeping the torque converter locked up greatly improves both fuel efficiency and transmission fluid temps.
    I've put the hazard lights on and slowed to 35 mph towing on really steep grades before. It wasn't that I couldn't go faster. It was because holding 65-70 mph would only get me to my destination 1-2 minutes sooner while burning twice as much fuel.
  10. Aug 2, 2021 at 11:17 AM
    #70
    Wallygator
    I will keep my V8 thanks.
    TK1979 likes this.
  11. Aug 2, 2021 at 11:40 AM
    #71
    Coal Dragger
    Kung Fu Dick
    Unless my situation changes dramatically I’ll be keeping my two V8’s as well: one 3UR-FE and an LS3 will stay in the fleet for the foreseeable future.
    I will also be adding a truck, and unless Toyota royally screws up the next Tundra will probably be it. So I will have a TTV6 of some description around too, which will be my 3rd turbocharged engine in a vehicle I’ve owned.
    TK1979 likes this.
  12. Aug 2, 2021 at 9:35 PM
    #72
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Bullshit the Tundra doesn't have aggressive upshifting.
    Wallygator likes this.
  13. Aug 2, 2021 at 10:07 PM
    #73
    Coal Dragger
    Kung Fu Dick
    Gotta disagree, the Tundra transmission is alway willing and eager to use the tallest possible gear even when you don't want it to. Getting it to downshift is infuriating because even with your foot on the floor sometimes it just wants to not kick down and get with the program.
  14. Aug 3, 2021 at 4:15 AM
    #74
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I don't see where JuicyJ said anything about the Tundra having aggressive upshifting. He stated that "Other trucks use tall gearing, aggressive upshifting and cylinder deactivation." And, "The 2 worst trucks for MPGs are the Titan and Tundra, because both use short final drives, somewhat normal shifting patterns, and drive like a "normal V8"."
    szabo101, JuicyJ and Wallygator like this.
  15. Aug 3, 2021 at 6:51 AM
    #75
    JuicyJ
    JuicyJ New Member
    TF u talking about Willis?
  16. Aug 3, 2021 at 8:47 AM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Yeah, he said other trucks have aggressive upshifting. I'm saying I don't know or care what other trucks have but the Tundra definitely has aggressive upshifting.
  17. Aug 3, 2021 at 8:47 AM
    #77
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Does my truck really need to be in 6th gear at 10 mph because the car in front of me accelerated too slowly?
    BecauseRacecar likes this.
  18. Aug 3, 2021 at 9:03 AM
    #78
    hitech
    hitech New Member
    Blair
    SOMD
    Gotcha. your wording made it sound different, I see what you are saying tho.
    Cpl_Punishment likes this.
  19. Aug 3, 2021 at 9:26 AM
    #79
    JuicyJ
    JuicyJ New Member
    I try not to speak on current Tundra as I don't have one, nor have I driven one.
    I can commiserate though, I have an Infiniti with a 7AT that can be annoying in it's shift logic. The 5AT in my old Titan is the best automatic I've ever owned, so I don't get how the same manufacturer can go from excellence to shittiness
  20. Aug 3, 2021 at 9:48 AM
    #80
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    It’s called emissions. Lower RPM means slower and more complete combustion to the expense of everything else, including drivability and engine lifespan.
  21. Aug 3, 2021 at 9:55 AM
    #81
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    :sorry:
    If the new Tundra were to get a manual transmission (which I know it won't) and, say, 1700 lbs+ of payload, I'd trade in my current truck in a heartbeat.
  22. Aug 3, 2021 at 10:05 AM
    #82
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Heck yes! I wish Toyota were listening. It's a shame the newest truck you can get with a manual (that can actually pull things) is a 2018 RAM 2500. If half-tons are really the mall crawlers that the industry is starting to treat them as, then why not toss a manual in there again?
  23. Aug 3, 2021 at 12:17 PM
    #83
    JuicyJ
    JuicyJ New Member
    I'm going to take what you said and disregard it.
    Unless I see some credentials
  24. Aug 3, 2021 at 12:39 PM
    #84
    Acedude
    Acedude New Member
    Colorado Plateau
    Fuel mileage - judging by fuelly.com reports for the Ford 3.5l TTV6 - 2021 Ford F-150 MPG - Actual MPG from 60 2021 Ford F-150 owners (fuelly.com) shows the avg mpg for many is in the 18-20mpg range, if I'm reading it right. But there are also plenty in the 14-17mpg range.
    Time will tell what mpg folks get with the Toyota TTV6. I guess it will depend on how often you're in boost. Unladen maybe it gets you 20mpg.
    Power delivery at altitude is great, but you're in boost and drinking fuel at apx the same rate as the 3UR-FE. We can debate this forever and it's fun to do so, but the bottom line is if we want to move on to the next gen Sequoia or Tundra we'll be buying a TTV6 with maybe the 8-spd auto in lower trims and a 10-spd auto in higher trims. And no trans cooler.
  25. Aug 3, 2021 at 12:55 PM
    #85
    Coal Dragger
    Kung Fu Dick
    I’m not sure if the 10 speed has an air to liquid transmission cooler, no mention on the Land Cruiser 300 info so far. I think omitting that feature is a bad decision if they go that way.
    Although having expressed a personal desire for a trans cooler loop that exchanges heat with air, not engine coolant; the new direct shift 10 speed apparently stays in torque converter lockup in every gear except 1st and 2nd if I remember correctly. So that will reduce transmission heat quite a bit by working the fluid far less.
    I am sure the aftermarket will offer a solution if Toyota omits the transmission cooler. The GM and Ford 10 speeds also don’t have one, but the aftermarket offers them.
    Also as another plus the Land Cruiser version of the V35A-FTS uses a normal spin on oil filter, so it shouldn’t be too hard to add an oil cooler. Not a direct help to transmission fluid temps, but if the transmission is cooled by engine coolant the less heat the engine dumps into the coolant the more cooling the loop can provide to the transmission. Pulling more heat out of the oil helps cooling performance, and helps the oil maintain film strength and all the oil functions.
    Acedude likes this.
  26. Aug 3, 2021 at 1:01 PM
    #86
    Acedude
    Acedude New Member
    Colorado Plateau
    I'm leaning the same way. The V35A will probably be fine for longevity and low-maintenance, it's been in the LS500 for a few years and Toyota had enough confidence to put it in the LC300.
    We'll pile up some miles on this new to us '19 Sequoia with the old reliable 5.7 and 6-spd trans. We'll see what the future holds and maybe jump on a used next gen Seq in six or seven years.
    Wallygator[QUOTED] likes this.
  27. Aug 3, 2021 at 2:14 PM
    #87
    sd172
    sd172 New Member
    South Dakota
    TK1979 and Wallygator like this.
