LBJ failure - Public Service Announcement
Discussion in '1st Gen Tundras (2000-2006)' started by G_unit3000, Feb 2, 2025.
  1. Feb 3, 2025 at 7:05 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I didn't know this. Why did they make them worse in 01? The crazy thing is that even the bigger ones them came out with in 04 fail. Someone did a tally in the LBJ failure thread and found more failures for those than the older ones. Now that doesn't mean they actually fail more. It's all the data we have.
  2. Feb 3, 2025 at 7:08 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    They may, they may not. Very often they don't. I know a lot of this stuff gets buried the ball joint thread, 'what have you done' thread or lunch table thread, but we talk about it a lot. Waiting for a sign is the wrong strategy. They're just as likely to fail 'out of the blue' as they are to show any sign of failure. Replace every 100,000 miles, no matter if every check you do on them says they're "fine".
  3. Feb 3, 2025 at 7:11 AM
    Aftermath pics show some with bolts that failed, some with ball popped out of socket failure and some where the ball snapped right off the post. Due to the variety of failure of all aspects of the joint, this one concludes the joint is under tremendous stress by design. When the joint begins to fail and doesn’t move smoothly in the socket the stress gets increased on all the components.
  4. Feb 3, 2025 at 7:23 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Glad you're okay. Same situation when mine went- two minutes prior we were doing 75mph on the highway. Pulled into a parking lot, boom.
    We have very safe trucks- but I can't say for sure if I would be typing this if the ball joint went at 75. Really glad that it decided to go in a parking lot.
  5. Feb 3, 2025 at 8:10 AM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Like many things, the lifetime of any individual ball joint is going to be on a bell curve. Unlike many things, you would not want to bet on the peak of the bell curve.
    Hence why we see some ball joints last 200k plus, loads last 150k and of course some last less.
  6. Feb 3, 2025 at 11:03 AM
    Nola
    Nola New Member
    2002 AC 4wd ltd
    Well, that answers my question……mine were done in 2006……time to do them again
  7. Feb 6, 2025 at 1:49 PM
    CMPtundra
    CMPtundra Wandering Tundra Owner
    Alabama
    05' 'New To Me' DC Limited
    Recall replacement in 2007 by previous owner. I called the dealership the truck was serviced at, but they couldn't provide the mileage of the truck at the time the work was done, just month and year. I bought the recall kit myself recently and they're waiting to be installed. I'm just trying to decide if I should replace the LCA's at the same time now or let them go and attempt bushing down the road. Currently, my LBJs do not show any signs of degradation and seem stiff with the pry bar test, but I'm at 130k miles and my best guess is the recall was done close to around 20-30k miles so I am right at that 100,000 mile mark.
    G_unit3000[OP] likes this.
  8. Feb 6, 2025 at 1:51 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Make sure you got a hold of the new bolts for those.
  9. Feb 6, 2025 at 1:51 PM
    CMPtundra
    Alabama
    all eight of em, and red loctite to boot
  10. Feb 7, 2025 at 9:14 PM
    _Spencer_
    _Spencer_ New Member
    2002 Tundra AC 4x4
    My truck had the recall performed around 67K, it's at 229K now and body damage evidence shows it may have had one fail at one point. I have new OEM LBJs I planned on installing tomorrow. What is the "recall kit" you mention? And why new bolts?
    EDIT: Disregard the bolts, I read up on it. Now to find new bolts...
  11. Feb 7, 2025 at 11:49 PM
    CMPtundra
    Alabama
    There's another thread that helped me. This is the "recall kit" and part number. Comes with two joints and new cotter pins. The part number is different from the typical OEM LBJ number. The parts guy at the dealership I ordered from asked me how did I find out about this part number since it is a recall specific item that is typically not available for retail customers. Of course as always, do your part to confirm fitment for your vehicle
  12. Feb 8, 2025 at 5:59 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yeah trying to stick it to Nam was no good but Civil rights are nifty (and being undone now)....
  13. Feb 8, 2025 at 6:00 AM
    Johnsonman
    Austin
    Sequoia
    Yotas black bolts are best (and can take 1 or 2 re-tightens) yet need the rock sleeves due to their length.
  14. Feb 8, 2025 at 7:22 AM
    _Spencer_
    2002 Tundra AC 4x4
    Any reason to go with the kit over the individuals? I assume it’s the same parts just packaged differently? The ones I ordered both came with castle nuts and cotter pins.
  15. Feb 8, 2025 at 7:30 AM
    G_unit3000
    G_unit3000 [OP] New Member
    Gman
    North East
    2005 Tundra DC 4x4
    It is just a little cheaper going with the kit.
    Make certain that you are replacing all 8 bolts when changing your LBJs. There are also a couple PDFs with torque specs that you've probably seen with your research. I'll attach them here. I gave these to the shop that did my install.
  16. Feb 8, 2025 at 10:41 AM
    CMPtundra
    Alabama
    The bolts and part number the dealership sent me for LBJ replacement for my 05'
    G_unit3000[OP] and FrenchToasty like this.
  17. Feb 8, 2025 at 10:43 AM
    CMPtundra
    Alabama
    thats the only difference. recall kit does not include castle nut, just the cotter pins.
    FrenchToasty likes this.
  18. Feb 9, 2025 at 12:28 PM
    splicnfiber
    splicnfiber New Member
    Kevin
    OKC
    2003 AC 4.7 2wd SR5
    Time for me to start thinking about this also. 90k on mine since the recall
  19. Feb 10, 2025 at 4:50 AM
    #49
    NickB_01TRD
    Nick
    KY
    For the big ball joint style only, which are different from the earlier style.
  20. Feb 10, 2025 at 5:24 AM
    #50
    CMPtundra
    Alabama
    Didn't realize they were different. I edited my post.
  21. Feb 10, 2025 at 5:37 AM
    #51
    NickB_01TRD
    Nick
    KY
  22. Feb 10, 2025 at 6:58 AM
    #52
    CMPtundra
    Alabama
    NickB_01TRD[QUOTED] likes this.
  23. Feb 10, 2025 at 7:02 AM
    #53
    Fragman
    Fragman New Member
    TX
    Sometimes getting the right LBJ part is trickier if you're not careful than actually installing them! Got to read the mega thread and use that https://toyota-usa.epc-data.com link.
    ETA - Full disclosure. I ordered the wrong bolts when I got my LBJ's. Even though the autoparts.xxx.toyota site said it matched my VIN. So I shoulda used the epc-data link too!
