Leather/heated seat (front and rear) installation write up
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlmightyCrash, Dec 8, 2018.
  1. Mar 12, 2019 at 12:01 PM
    #91
    tubal
    tubal New Member
    SLC, UT
  2. Jun 12, 2019 at 8:34 AM
    #92
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Almightycrash- thank you for posting this thread. I got my kit last weekend and installed it over the last few nights. I relied on your pics and descriptions quite a bit, along with Patch999’s. Together they were about all I need to get it done. Thanks!!
  3. Apr 20, 2020 at 7:56 AM
    #93
    AlmightyCrash
    AlmightyCrash [OP] Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Just thought I’d give an update. it’s been over a year, and the seats still look like the day I installed them.
    I did have a problem with one of the rear heaters not coming on, but it turned out my puppy unplugged one of the harnesses...so it only took half a second to fix.
    Everything else is great. The material is thick and durable, even holding up to a large active puppy with no scratches or tears. They are comfortable and look so much better than the cloth seats.
  4. Apr 27, 2020 at 9:09 PM
    #94
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    @AlmightyCrash could you measure the switch? I would like to replace it with one of my cigarette lighters on my dash. I'd like to make it look are factory as possible. 4F396792-F14F-425E-A9EA-52BE834A7BE0.jpg
    Edit: also how did you hook up all 4 wires. Ground, Positive, ACC & Illumination?
  5. Apr 28, 2020 at 2:55 AM
    #95
    AlmightyCrash
    Crash
    San Leon, TX
    That switch is 1.5” in diameter.
    If I remember correctly, I connected all 3 positives to an ignition controlled fuse circuit with an “add a fuse” connector, as I didn’t want it on when the truck isn’t on. It is grounded to the body under the carpet.
  6. Apr 28, 2020 at 8:33 AM
    #96
    Damie Street
    Edsel
    South Carolina
    Thank you. I also don't want the heated seats on when the vehicle isn't on as well. I've read that others where taping into the 12V power from the cigarette lighter. Do you think this is a good idea? I don't really have that much electrical skills but I think I can handle this project. Just want to have a game plan for wiring it up before I start the project.
    Thanks
    Edsel
  7. Apr 28, 2020 at 10:44 AM
    #97
    AlmightyCrash
    Crash
    San Leon, TX
    that should be fine. I didn’t because I had already made my cig lighter ports constant power.
  8. Apr 28, 2020 at 3:29 PM
    #98
    Damie Street
    Edsel
    South Carolina
    Cool. Thank you. I'm probably just going to go that route then. Seems a little easier for me as I'm actually replacing the cigarette lighter with the switch anyways.
  9. Sep 5, 2020 at 6:21 PM
    #99
    1_thirsty_tundra
    1_thirsty_tundra The Thirsty Tundra
    Jay
    Alberta Canada
    2019 SR5 Off-Road Crew Max
    Spintech custom exhaust Bilstein 6112 / 5100 Coachbuilder shackles / shims Vled LED interior Winjet tails Pacer high 5 cab lights Fuel Contra 20x10-18 wheels Wireless Apple Carplay/ Android auto Custom Pioneer stereo system Custom Crewmax underseat storage
    Can anyone help with a rear armrest question ..... does this plastic cup holder part pop off or do you cut a big hole in the leather and tuck it under ? Feels like its going to break when I try to pop it off. Thanks
  10. Sep 6, 2020 at 8:25 AM
    #100
    TexasVol1794
    TexasVol1794 New Member
    Austin, TX
    2016 Inferno Orange Limited CrewMax
    Someone needs to do @AlmightyCrash a solid and consolidate his instructions into one PDF :D
    I have a Limited with leather and heated front seats already. This write up and everyone’s enthusiasm makes me want to install leather and heaters for someone else. The positivity is contagious.
    JoelThor26 likes this.
  11. Sep 6, 2020 at 8:45 AM
    #101
    AlmightyCrash
    Crash
    San Leon, TX
    Check the back side. I think I remember there being screws, but it’s been a long time.
  12. Sep 6, 2020 at 9:07 AM
    #102
    panicman
    Eric
    From another install thread, first post-this should help, big thanks to @Patch999:
    https://www.tundras.com/threads/diy-katzkins-with-seat-warmers.31828/
  13. Sep 6, 2020 at 10:12 AM
    #103
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Thanks Eric. It was a fun project.
  14. Sep 7, 2020 at 5:51 AM
    #104
    1_thirsty_tundra
    Jay
    Alberta Canada
    Thanks.... I got it all done. Took me 11 hours total.
    F5ED82CC-F77C-44C7-88F4-CB61E10397F2.jpg 30A9CD75-B586-4A3F-B0EB-6815DBC141E3.jpg
    gkelm, panicman, TRDFerguson and 2 others like this.
  15. May 18, 2022 at 7:28 AM
    #105
    Bradyboyy88
    Bradyboyy88 New Member
    Shaun
    even though these are the switches those seat heaters pads came with can you use different ones or are they prewires to that switch hence would need splicing or something.
  16. May 26, 2022 at 8:58 AM
    #106
    AlmightyCrash
    Crash
    San Leon, TX
    They have little harnesses.
  17. Sep 28, 2023 at 10:42 AM
    #107
    Apexcrazed
    Apexcrazed New Member
    2016 Black Tundra Crewmax
    Thanks for the write up, I was having tremendous difficulty with removing the recline lever when I get home tonight Im going to try your method. I was going to run power through the console lighter wires but I think I want to tap into the interior fuse box that has a heated seat 20amp fuse.
  18. Sep 28, 2023 at 7:47 PM
    #108
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just a quick tip for the head rests. Use a vacuum cleaner or central vac to suck the headrests down. Put a thin bag over the headrest then insert the headrest rod into the vacuum and wrap the bag for a good seal. Turn the vacuum on and it will suck the headrest down and the covers will slip on easily. I just did the Katzkin on my Frontier and going to get a set for my Tundra.
    Sean492 and Terndrerrr like this.
