LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. Jun 12, 2019 at 8:04 PM
    #151
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Absolutely not
  2. Jun 13, 2019 at 3:42 AM
    #152
    Professional Hand Model
    Hand Protectors
    I’ve read on the Big Gurl from Brasil reviewers stating they have had your same problem.
  3. Jun 13, 2019 at 12:41 PM
    #153
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I've been reading up and others have had this same problem. Seems like I'm going to have to order ferrite coils?
  4. Jun 18, 2019 at 7:16 AM
    #154
    WhiskeyWaldo
    WhiskeyWaldo New Member
    Austin
    Augusta, GA
    2018 Magnetic Gray Tundra TSS Off-road 4x4 Crewmax
    Nilight flood ditch lights
    Do these bulbs affect the adjustment wheel in the dash?
  5. Jun 18, 2019 at 7:57 AM
    #155
    TundraTSS19
    San Antonio, TX
    No. They're just bulbs. The light housing isn't altered that had the adjustment motor You can still aim them up and down inside the dash.
    WhiskeyWaldo[QUOTED] likes this.
  6. Jun 25, 2019 at 5:09 PM
    #156
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    just ordered the aux beam today for my headlights
  7. Jul 8, 2019 at 6:12 AM
    #157
    Mamalona
    Mamalona New Member
    Tom
    2019 Tundra Custom
    I've been reading all through the Lighting section...My question is how can the Auxbeams be comparable to the Morimotos 2Stroke for a fraction of the price ($32 vs $120)??? Even looking at the Specs the Auxbeam crushes the Lumen output of the Morimoto....I guess I'm going with Auxbeam...
  8. Jul 20, 2019 at 11:58 AM
    #158
    hillbillytoyo
    Daniel
    WV
    I tried the ferrite coils and they didnt help. I had to remove the Auxbeam headlights. I still have the fogs installed so now I'm driving around with LED fogs and stock headlights. Looking for other options.
  9. Aug 9, 2019 at 7:25 PM
    #159
    b183
    b183 New Member
    South MS
    2019 Tundra Barcelona Red TSS
    Bed Step, Driver pull Handle, Camlocker LP Toolbox, Bed Rails, Rubber Bed Mat TRD rear sway bar, front camera AVS window deflectors window tint
    Installed the Auxbeams and initially was disappointed as low beams let a lot to be desired. I read on Amazon review that the Auxbeam
    label on both bulbs should face the driver side. Wrong. They should both face passenger side. After swap and very pleased with them.
    Have the H/L adjustment set to zero. Now I am searching for fog lights as my 2019 SR did not come with them.
    Yota100 likes this.
  10. Nov 15, 2019 at 3:59 PM
    #160
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Just got the Auxbeams installed. Thank you everyone for the videos and addition info. Special thanks to @TundraTSS19!
    WILLINH likes this.
  11. Nov 25, 2019 at 11:49 AM
    #161
    BoerboelTundra
    BoerboelTundra New Member
    2020 Tundra Super White SR5
    Wondering if the grill needs to be removed to install new led bulbs (Aux Beam) on the 2020 SR5? The manual says that you only have to remove the inside wheel fenders to access the headlights and fog lights.
  12. Nov 25, 2019 at 12:40 PM
    #162
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Yes the grill needs to be removed to install the LED bulbs. Just did it last weekend. It’s easier than it seems. Plenty of YouTube videos.
    kbark and BoerboelTundra like this.
  13. Nov 25, 2019 at 12:57 PM
    #163
    BoerboelTundra
    Ok, it just seems weird to me that you tube videos tell you to take apart the front of the truck but the owners manual states that bulbs can be changed from just removing the inside fender. Has anyone tried changing the bulbs by just removing the inside fender?
  14. Nov 25, 2019 at 6:29 PM
    #164
    BoerboelTundra
    Got the Aux Beam Headlights installed. Tried installing the fog lights and they don’t work! Very disappointing!
  15. Jan 14, 2020 at 1:01 PM
    #165
    TundraMax12
    TundraMax12 New Member
    Dom
    2013 TSS Crewmax
    I have read through this entire thread and am somewhat confused on which headlight bulb to get from Auxbeam. I see people saying they got an H4 but I have heard of people getting an H11.
    I have a second gen 2013 tundra. Any suggestion on which size is correct?
  16. Jan 14, 2020 at 3:39 PM
    #166
    Tn.223
    Tn.223 New Member
    2014 1794 Crewmax
    The H4 for headlights, I think the h11 is for fog lights. I have a 2014 and installed the Auxbeams in November and love them. You won't be disappointed.
  17. Jan 14, 2020 at 3:50 PM
    #167
    Dylan7194x4
    Dylan7194x4 New Member
    Dylan
    2013 red cm rw
    I ordered these they are bright and work well. Only had then on for about 150 miles but I dont drive my truck much.
    Alla Lighting H10 LED Fog Light Bulb, 9145 9140 9040 9045 ETI 56-SMD 3800 Lumens Extremely Super Bright Cars Trucks 9145 CANBUS LED Lights, 3000K Amber Yellow https://www.amazon.com/dp/B07GTFW5QC/ref=cm_sw_r_cp_apa_i_PoLhEbN0E8R2G
  18. Jan 14, 2020 at 4:55 PM
    #168
    TundraMax12
    Dom
    2013 TSS Crewmax
    I think the headlight bulb size may have changed for the 3rd gens (2014 and up) because on multiple automotive bulb and light websites they are saying for a 2013 Tundra to get an H11 bulb size for the low beam headlights. Where as for a 2014 and up they say to get an H4 bulb.
  19. Jan 14, 2020 at 4:59 PM
    #169
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    What about reliable backup bulbs?
  20. Jan 30, 2020 at 9:08 PM
    #170
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Sorry but what bulbs are these. They look killer
  21. Jan 30, 2020 at 9:18 PM
    #171
    Trdwillie14
    Billy
    2014 trd off road
    Sorry to do this but just wanted to confirm is this is the right one
    kbark likes this.
  22. Aug 22, 2020 at 1:43 PM
    #172
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Looks like the S1- H11 is no longer available on Amazon. Is there any other options from Auxbeam for Foglights, without the fan?
  23. Aug 25, 2020 at 5:01 PM
    #173
    TundraTSS19
    San Antonio, TX
  24. Aug 25, 2020 at 5:09 PM
    #174
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Thx TSS19- those will work perfect
    TundraTSS19 likes this.
  25. Aug 28, 2020 at 6:27 AM
    #175
    slider_buck
    slider_buck New Member
    Surprised i havent seen anyone using the Phillips X-treme Ultinon LEDs. I just installed a set last night in my 2016 and love them. True plug and play. No fighting them at all. The heat sink unscrews so you can put the rubber boot on very easily. Light output is perfect and so is the pattern. Sorry no pics right now but you def wouldnt be disappointed buying these. They are a bit pricey compared to others but you typically get what you pay for. I found mine on ebay for $115.
  26. Sep 10, 2020 at 1:02 PM
    #176
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    Did you have to use the anti flicker wire harness...Auxbeam H4 9003 HB2 P43T LED Headlight Canbus Decoder Error Free Anti Flicker Wiring Harness Adapter Opens in a new tab
    Also, the Wonder Wizard of Amazon tells me these will not fit my 2020 Tundra. Can anyone confirm or say BS to that? They do have a link to other similar bulbs that it says will fit. Is it possible I need the anti flicker to make it compatible?
  27. Sep 11, 2020 at 9:44 AM
    #177
    TundraTSS19
    San Antonio, TX
    Didn't use antiflicker at all. It will fit a 2020 because nothing has change. Uses the same bulb.
  28. Sep 24, 2020 at 7:15 PM
    #178
    Shaff777
    Justin
    Boise
    2020 cement SR5
  29. Sep 26, 2020 at 2:58 PM
    #179
    Shaff777
    Justin
    Boise
    2020 cement SR5
    just installed both the headlights and fogs. The entire process took about 1 hour to make it happen. This included going slowly the entire time to make sure not to break the tabs on the grille during removal.
    Following the directions listed, made the process a breeze.
    The fogs were actually removed through the front of the bumper, as the process for us was much easier.
    Light output and color look perfect, I don’t see any reason to purchase the OEM LEDs at this point.
    WILLINH likes this.
  30. Dec 11, 2020 at 1:13 PM
    #180
    gb_beringei
    gb_beringei New Member
    Central Maine
    2019 SR5 SX Double Cab
    I ordered these. They should arrive tomorrow. I’ll let you know how they perform.
