Leveled before and after pic
Discussion in '2.5 Gen Tundras (2014-2021)' started by cfred70, Dec 6, 2017.
  1. Dec 30, 2018 at 7:38 PM
    #61
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    The reason Toyota makes the front end lower is to match a car’s bumper height in case of a crash.
    https://www.iihs.org/iihs/news/desk...uld-apply-to-suvs-pickups-vans-and-cars-alike
    https://www.thetruthaboutcars.com/2010/12/iihs-calls-for-bumper-height-regulation/
  2. Dec 30, 2018 at 7:56 PM
    #62
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    How does having an unraked/leveled truck affect hauling in the bed or towing? Seems like it would have an adverse affect on what the vehicle was primarily built to do.
    Do suvs get leveled? I hadn’t really heard of this when I had my 4Runner leveling seems all the rage on the tundra forum.
    Rica25 likes this.
  3. Dec 30, 2018 at 8:02 PM
    #63
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Are your tires rubbing your inner front fenders? I’m on a 285/70r18 and getting a descent rub on front drivers side frontside inner fender.
  4. Dec 30, 2018 at 8:02 PM
    #64
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    Levelling vehicles is very common. It must be new to you for whatever reason. Look it up on the internet. Dead level is fine for hauling and towing. Just get air bags. I have almost an inch of rake and it's fine when I tow and haul. This stuff has been explained multiple times. Use the search function on this site or google
  5. Dec 30, 2018 at 8:34 PM
    #65
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Dec 30, 2018 at 8:34 PM
    #66
    csuviper
    Broomfield, CO
  7. Dec 30, 2018 at 9:12 PM
    #67
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
  8. Dec 30, 2018 at 11:15 PM
    #68
    georgiey22
    Bilstein 6112 set @ 1.9” in the front and no lift in the rear. I have some rub in the front most driver side inner fender and can’t find a way to stop it from rubbing. Prefer not to add any additional lift. Boo.
  9. Dec 30, 2018 at 11:17 PM
    #69
    Mikekoot
    Mikekoot New Member
    Canadia
    that's the sweet spot for a level. Looks great!
  10. Dec 31, 2018 at 5:48 AM
    #70
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Here is mine after 5100's on the middle setting.
  11. Dec 31, 2018 at 7:08 AM
    #71
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    What size tires were u able to fit with this level lift? I was thinking of keeping it simple like u with type of leveling with new shocks.
  12. Dec 31, 2018 at 7:12 AM
    #72
    1999cutiger
    Right now I have 275/55/20 tires.
    I plan on going up in size a little bit once these wear out.
  13. Dec 31, 2018 at 9:09 AM
    #73
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    Can't speak for Toyota's engineering teams, but they are generally trying to hit the middle of the distribution in terms of users, so they make trade-offs in all departments. One of those is obviously suspension, and while I agree the factory is probably fine, most of what you're seeing here is seen by some as an improvement (IE 5100, 6112, NOT spacers).
    In fact, I ordered an aftermarket Bilstein setup for my truck as I wanted the build of the Platinum features with the suspension similar to a pro. Not just for "height" but for performance offroad such as heat dissipation and improved fade during high speed whoops. I will run mine 1" or so above stock to try and keep driveshaft angles and longevity but have improved on and offroad performance.
    waynescaggs and Mikekoot like this.
  14. Dec 31, 2018 at 10:14 AM
    #74
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Readylift 3/1. Darker photo is before, the rest are after
    FowlhookDE likes this.
  15. Dec 31, 2018 at 2:20 PM
    #75
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    I can't be happier with the ride performance of the 6112s at 1.3" up front. IMO if you are spending the money (or time) to get have your front end ripped apart, and spending $100 to have it realigned, you might as well spend what amounts to a month of gas to upgrade the suspension more than just spacers. These are with BFG KO2 275/70R18s. It's a hair raked. Just looks and drives beautifully. No lift in the back. No regrets. A bit poorer, but a lot happier.
    If you are mechanically inclined, heres my DIY.
    https://www.tundras.com/threads/dont-be-very-afraid-to-build-bilstein-6112.35488/#post-892589
  16. Dec 31, 2018 at 3:14 PM
    #76
    cantle
    cantle New Member
    Durango, CO
    Thanks for posting this. This is the setup I am going to run. Looks factory, performs pro
  17. Dec 31, 2018 at 4:08 PM
    #77
    Mikekoot
    Mikekoot New Member
    Canadia
    I went with 5100 in the front. Middle setting which is 2inches. Gives almost an inch of rake and rides way better than stock. Plus they are cheap. I installed mine in a morning.
    Rica25, Boerseun and cantle[QUOTED] like this.
  18. Dec 31, 2018 at 4:13 PM
    #78
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    37/12.50R17
    After
    Before
    2.5” level
  19. Dec 31, 2018 at 4:57 PM
    #79
    bdpeelgren
    Round Rock, TX
    2.5in level and 37’s.. You’re insane
    Rica25 and BuckWallace like this.
  20. Dec 31, 2018 at 5:02 PM
    #80
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    :eek2: Do you just have to drive in a straight line all the time?!
  21. Dec 31, 2018 at 6:44 PM
    #81
    cantle
    cantle New Member
    Durango, CO
    are you happy with the ride?
    Rica25 likes this.
  22. Dec 31, 2018 at 7:44 PM
    #82
    Mikekoot
    Mikekoot New Member
    Canadia
    It's way better than stock. More composed in high speed back roads and moderate trails. Will get 5100s for the rears soon. I will keep as is for now.
    Rica25 and cantle[QUOTED] like this.
  23. Dec 31, 2018 at 7:48 PM
    #83
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Ah, what’s a C hair? :eek2::stirthepot:
    Tundyfundy and Silv333 like this.
  24. Dec 31, 2018 at 11:51 PM
    #84
    geno0506
    geno0506 New Member
    Michael
    Sorry, just saw the post!
    Zero issues after I pushed the front wheel well in neatly about 1/4"-1"!
    Travo60[QUOTED] likes this.
  25. Jan 1, 2019 at 4:20 AM
    #85
    Tundramoney
    Tundramoney Old school
    Earth
    Toyota does build them that way its called a TRDPRO
  26. Jan 1, 2019 at 7:32 AM
    #86
    :notsure:
    OR18TRD[QUOTED] and geno0506 like this.
  27. Jan 1, 2019 at 7:39 AM
    #87
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    5100's all the way around
    Mannishboy and Mikekoot like this.
  28. Jan 1, 2019 at 12:49 PM
    #88
    Bates5450
    Jacob Bates
    Dickinson, ND
    It’s so natural looking though
    BarcelonaSX likes this.
  29. Jan 1, 2019 at 12:49 PM
    #89
    geno0506
    geno0506 New Member
    Michael
  30. Jan 1, 2019 at 12:52 PM
    #90
    Bates5450
    Jacob Bates
    Dickinson, ND
    I can turn lock to lock just fine no rub at all really only in reverse at half lock and that’s only because I haven’t fully finished my BMC.
