Leveling 22 Platinum with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by 2bak, Dec 22, 2021.
  1. Feb 21, 2023 at 2:39 PM
    #361
    Hella Krusty
    Hella Krusty New Member
    I would guess that the inner fender liner needs to be pinned back so it doesn’t rub. On my 2012 I used a heat gun, warmed it up and then pushed it towards the front ( with gloves on ) and held it until it cooled. Then it stayed pushed in. Zero rub. I know people that push them in and blow a rivet or a screw with a a washer thru it
  2. Feb 21, 2023 at 5:18 PM
    #362
    Dakota3645
    Dakota3645 New Member
    Dakota
    2022 Tundra SR5 - Army Green
    A long 3 day weekend called for lift kit installation and new wheels & tires for my Tundra with air ride so I wanted to post here as well! I installed the @ICON suspension Stage 4 kit paired with ReadyLift 2" lift kit for AVS/rear airbag trucks (they don't sell just the rear end components but thats all I used) for a solid lift while improving ride quality! I wasnt super fond of compensating lift with by only adjusting the ride height lever. Havingthe spacer seemed way better in my mind. Wheels are the new Method 318 in 18x9 +18 paired with Toyo's new Open Country R/T Trail in 35x12.5r18!!
    I'm absolutely thrilled with how she turned out! Ask any questions you may have! Here's a few pics!
    20230221_110037.jpg 20230221_110055.jpg 20230221_110315.jpg 20230219_235649.jpg 20230219_235658.jpg
    Shooter8571, dan81, TheSS712 and 2 others like this.
  3. Feb 21, 2023 at 6:11 PM
    #363
    Hella Krusty
    Truck looks great. Not my taste but looks good. Each to their own I guess
  4. Feb 21, 2023 at 6:37 PM
    #364
    Quick_23TundraPlat
    Quick_23TundraPlat New Member
    2023 Tundra Platinum MGM
    Westcott Lift AVS/Rear Air, 35/12.5/18 Toyo Open Country AT3, Method 305 NV 18x9 (+18 Offset), Extang Solidfold 2.0 Tonneau
    Sure - here is the Westcott link… check out their YouTube channel for a lot of helpful content.
  5. Feb 23, 2023 at 8:24 AM
    #365
    Proven21
    Proven21 New Member
    VA
    2023 Tundra Platinum w/ AVS & Air Ride
    KING 2.5 suspension all around w/ Westcott rear arms. 35” Toyo Open Country AT3 Method 18” 305NV Black on Black ICON Billet UCA’s TRD Filters Diode Dynamics SS6 Amber Fog Lights
    so I went to my local Offroad Shop to get a quote on installation for the Westcott Kit and to see if they could get a better price on the wheels/tires etc. They are trying to talk me into ICON Billet UCA's stating that if I dont get the new UCA's the geometry etc will be all out of whack and ill cause damage. They also told me that the Westcott Preload Collar Kit is not going to give me a good ride at all. Any body have thoughts on all this mumbo jumbo. Im thinking they are just trying to get some more money out of me. I dont intend to Baja race this truck but would like to know the ride quality and capabilities of doing some light trail runs is there with the Westcott kit.
  6. Feb 23, 2023 at 9:36 AM
    #366
    Quick_23TundraPlat
    If they are talking about updating your entire suspension system (something like ICON, KINGS or FOX... then yes, that would be better than the Westcott lift (overall and in ride quality).... and yes, any 'Suspension lift' where there are new shocks, struts and UCAs will always be a better quality than a 'puck lift' or even the 'pre cuff lift from Westcott' that I installed. That is all true. The challenge with us (Our Platinum with AVS and air ride) is that I wanted to keep my AVS system functioning and I wanted to keep my stock air ride in the back (for future trade-in and Toyota warranty purposes).... and if I had ripped everything out and done an new suspension in the front and even new air ride in the back ... the OEM AVS would have ceased functioning and my guess is that it would have impacted the warranty... which in these trucks you need for sure.
    As for a 'downgrade' as I mentioned, yes, the Westcott is slightly tighter than stock (which doesn't bother me as its all personal preference) but if you are hoping to never feel a pebble in the road... this isn't the vehicle you should be driving anyhow :) A complete suspension lift upgrade would be a higher-quality and also more expensive... it just would have not worked with what I wanted to maintain (with AVS, warranty and stock rear air). For me Westcott was a better overall solution and I'm happy with the quality.
  7. Feb 23, 2023 at 9:45 AM
    #367
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    So you went with the westcott front level and rear arms on your platinum? I am considering the same for my 1794. What is the difference between the westcott front level and say the rough country front level, do you happen to know?
  8. Feb 23, 2023 at 9:54 AM
    #368
    Proven21
    Proven21 New Member
    VA
    Correct me if Im wrong here but the Westcott is a Collar Preload kit the Rough Country is a spacer kit. One moves the position the other adjusts the preload/height.
  9. Feb 23, 2023 at 2:37 PM
    #369
    JMitch
    JMitch New Member
    James
    2023 Tundra Limited 4x4 Hybrid
    So in the rear did you use only the ReadyLift components? Sorry if I'm ignorant on how it works. I'm new to this and want to add a lift to my '23 Limited with Air Ride and AVS. Was thinking of just doing the Readylift to start, then upgrading the front if desired.
  10. Feb 23, 2023 at 5:10 PM
    #370
    Quick_23TundraPlat
    the rough country front level is a basic puck front level and the Westcott lift is a preload collar lift … they are similar however I’ve had vehicles with both types and prefer the preload collar lift.
    also I got the full Westcott lift kit for the AVS/rear air trucks… front lift and replacement arms for the rear air (all in one package)…. Just to clarify
  11. Feb 23, 2023 at 5:46 PM
    #371
    ziznack
    ziznack New Member
    Texas Y'all
    Yeah I knew what you meant on the westcott, I was looking at the same one but didn't know what the difference is between preload collar and puck lift. What makes you prefer the preload?
  12. Feb 23, 2023 at 5:51 PM
    #372
    Quick_23TundraPlat
    the slight increase in ride quality —puck levels can rattle your teeth a bit … and I prefer the Westcott preload collar lift for ride quality…. Neither will ever be as good as a full suspension upgrade - we just have so few options available if we want to maintain AVS and the original air ride.
  13. Feb 23, 2023 at 5:54 PM
    #373
    ziznack
    ziznack New Member
    Texas Y'all
    Thanks.
  14. Feb 23, 2023 at 7:44 PM
    #374
    Dakota3645
    Dakota
    Yes that's correct! I ordered the stage 4 Icon kit, so up front was all icon. Rear was icon shocks and all the Readylift rear parts! You could very easily do just the readylift kit to start and upgrade down the road!
  15. Feb 23, 2023 at 8:54 PM
    #375
    Quick_23TundraPlat
    With the Icon 4 installed the AVS controls no longer function, correct?
  16. Feb 24, 2023 at 7:22 PM
    #376
    fastarget
    fastarget New Member
    Need some guidance. Went by the TSB and adjusted the sensor bracket, checked it for a couple of days and readjusted for what the TSB recommends 35-45 mm, they were at 44 passenger 42 driver. Went for a 50 mile drive, came back home, and they are at 50mm maybe more. anyone know what is going on, and will this cause issues? That 50 mile drive was the nicest smoothest drive of any truck we have had.
  17. Feb 24, 2023 at 7:35 PM
    #377
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    There is a reset sequence that westcott outlines in their video. It will calibrate the ride height before travel. Check out their airbag arm video.
  18. Feb 25, 2023 at 6:33 AM
    Hella Krusty
    Is this factory arm you are adjusting? If so mine is different every time I turn the truck off by 1/4 to 1/2 inch. I finally just decided to roll with it. Ride is smooth and no one will notice 1/4” from side to side. Hell a tank of fuel will do that
    glozanoff likes this.
  19. Feb 25, 2023 at 6:39 AM
    #379
    fastarget
    yes sir factory, not so concerned with the ride height or side to side, as much as having it set properly so as not to potentially cause damage or overextend the shocks, or am I overthinking it?
  20. Feb 25, 2023 at 9:46 AM
    #380
    bigblue14
    Craig
    Measure the difference up to the max height. That's what you have to play with.
  21. Feb 25, 2023 at 9:55 AM
    #381
    fastarget
    small adjustments seem to make a big difference at a point. just drove it, adjusted it, reset the system, drove and checked. It is in the recommended range again. will drive more and re-check.
  22. Feb 25, 2023 at 5:46 PM
    #382
    Hella Krusty
    I fly home tomorrow. Truck has been sitting all of Feb so will do some measurements Monday
    for me, my truck was squated in the back so a good bump on the road the suspension would bottom out. So I raised it so it was more less level with the front to add over an inch from the bump stops to the axle in the rear I only got to drive it twice before I took off for some sunshine but it road way better.
    My truck is….and will stay 100% stock this time. Moving on from the lifts and big tires, but I will say, some of these 2022+ trucks that have leveled/ wheels and tires look awesome. I just don’t want another 10 years of crabby wife. I am going to pimp out the surf boat and buy a full suspension e-bike.
    Hecteasy likes this.
  23. Feb 25, 2023 at 6:33 PM
    #383
    fastarget
    Drove the truck on all kinds of roads and speeds playing taxi and remeasured it from the time last adjusted and reset. It has a bit of rake, and the bump stops are 43mm drivers side, 48mm passenger side or so. It has gone back to that on its own, the ride is greatly improved, smooth as a lexus on the highway. Put on some weathertech mud flaps while I was under and around it(perfect fit), it has been real muddy around here and lots of it ends up on the power steps.
  24. Feb 27, 2023 at 1:56 PM
    #384
    ziznack
    ziznack New Member
    Texas Y'all
  25. Feb 27, 2023 at 1:58 PM
    #385
    Quick_23TundraPlat
  26. Feb 27, 2023 at 4:13 PM
    #386
    Hella Krusty
    So it was wet here today so I did not crawl under it. I measured ground to bottom of wheel well. Make sure the measuring tape sits infront of the centre cap of the wheel. I am 38.5" driver side, 38.25 passenger. its always those 2 measurements, but you never know what side you will get it on LOL
  27. Feb 27, 2023 at 5:45 PM
    #387
    fastarget
    Great info thanks, ok, 38" drivers, 38 3/16 passenger , tires set at 36 psi. Looks pretty good then. Ride is quite good.
  28. Feb 27, 2023 at 5:47 PM
    #388
    ziznack
    ziznack New Member
    Texas Y'all
    Hey, do you have the before and after measurements from center of wheel to fender? If not, do you have your current center of wheel to fender?
  29. Feb 27, 2023 at 6:38 PM
    #389
    Hella Krusty
    somewhere deep in this thread the dudes like Me that didn't want lift for tires and just get off the bump stops and better ride ..... 38" was the number. What I went with. Where I will leave it LOL
    fastarget[QUOTED] likes this.
  30. Feb 27, 2023 at 6:55 PM
    #390
    Quick_23TundraPlat
    No pre numbers. However - next decent day I’ll measure for ya. Stay tuned.
