Leveling 22 Platinum with AVS/Air
Discussion in '3rd Gen Tundras (2022+)' started by 2bak, Dec 22, 2021.
  1. Jul 11, 2023 at 8:18 AM
    #481
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I mean the AFE or Westcott arms. I have the AFE arms installed.
    Proven21[QUOTED] likes this.
  2. Jul 11, 2023 at 8:20 AM
    #482
    Proven21
    Proven21 New Member
    VA
    2023 Tundra Platinum w/ AVS & Air Ride
    KING 2.5 suspension all around w/ Westcott rear arms. 35” Toyo Open Country AT3 Method 18” 305NV Black on Black ICON Billet UCA’s TRD Filters Diode Dynamics SS6 Amber Fog Lights
    Im getting ready to order an ICON full setup. Wanting to go with the CDEV solution as I will still be able to electronically control the dampening. Big investment so need to get this right. I believe I am only going to need the ICON Setup and continue to use my Westcott rear arms and I should be fine. The ICON kit comes with a diff drop kit but I could go with the TRD CV's if I want. Anything else I am missing here. Dont think so... I have looked at your build multiple times. I think Ive got it down.
  3. Jul 11, 2023 at 8:25 AM
    #483
    bigblue14
    Craig
    I'm not familiar with the ICON set up. I'll have to check it out.
  4. Jul 11, 2023 at 8:27 AM
    #484
    Proven21
    Proven21 New Member
    VA
    bigblue14[QUOTED] likes this.
  5. Jul 11, 2023 at 8:47 AM
    #485
    Proven21
    Proven21 New Member
    VA
  6. Jul 11, 2023 at 2:50 PM
    #486
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Proven21 likes this.
  7. Jul 11, 2023 at 2:51 PM
    #487
    Proven21
    Proven21 New Member
    VA
    Maharisc[QUOTED] likes this.
  8. Jul 11, 2023 at 4:55 PM
    #488
    bigblue14
    Craig
    Those parts are the shock mounts from an SR5. The TRD lift is not meant for trucks with AVS and/or rear airbags. I can't remember which way it went but one or other other combinations were keyed. The TRD shock wouldn't fit in the AVS shock mount. It needs parts from a lower trim level.
  9. Jul 11, 2023 at 4:57 PM
    #489
    Proven21
    Proven21 New Member
    VA
    Makes a lot of sense. I was thinking along those lines. Wanted to be sure. Thanks! Making my order this week. Pretty stoked to see how this build comes out and share my experience with the group.
  10. Jul 11, 2023 at 4:57 PM
    #490
    bigblue14
    Craig
    Happy to help!
  11. Jul 22, 2023 at 4:02 PM
    #491
    CarJon
    CarJon New Member
    2022 CrewMax Blueprint Platinum Tundra 4x4 (5.5 ft bed)
    1.75 in front level / Nitto Recon Grappler A/T - 295/60R20 on stock wheels.
  12. Jul 22, 2023 at 5:15 PM
    #492
    JMitch
    JMitch New Member
    James
    2023 Tundra Limited 4x4 Hybrid
    Kspegar likes this.
  13. Jul 28, 2023 at 12:32 PM
    #493
    Proven21
    Proven21 New Member
    VA
    Spoke to ICON last week. They are in the final stages of verifying fitment of their kits with the AVS & Air Ride vehicles. They mentioned their last step is pertaining to the rear air ride height adjustment brackets, etc. Hopefully something soon that is fully validated and ready to ship!
    Kspegar likes this.
  14. Jul 28, 2023 at 10:06 PM
    #494
    Kspegar
    Kspegar New Member
    Kalei
    Bigisland, Hawaii
    Only got the 6” RC with icon billet UCA. Rides way better then stock
  15. Aug 1, 2023 at 10:49 AM
    #495
    Tundra22SC
    Tundra22SC New Member
    New to this site but I’ve studied this thread pretty thoroughly. I want to do a simple RC leveling kit on my 1794 with the AVS/rear air bags. I’ve read a couple of time there is special shims that are required. I notice the RC site still says that the leveling pucks aren’t compatible with AVS but I’ve heard of a number of people that say they are. Is there a final consensus on the compatibility of the RC puck leveling kit on AVS equipped tundras?
  16. Aug 1, 2023 at 11:41 AM
    #496
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    I have been rounds with several of the companies, including RC and AFE. None of them have tested it on the AVS so they aren't willing to take the liability. My issue was that even though several people here have used them both on the AVS, no one in my area will install them for me if the manufacturer says it doesn't fit. That leaves us with using either Westcott leveling pucks (or with the rear arm) or Deadlift 2" lift. Personally I'm going with the readylift because I like how they raise the bags versus just pumping more air into them to lift the back.
  17. Aug 1, 2023 at 1:02 PM
    #497
    Breathing Borla
    Northern Illinois
    not really sure why you want a leveling kit anyway, the AVS bagged trucks are pretty much level from the factory, ride awesome, etc.
    this is stock suspension, if the front was raised at all it would be higher than the rear
    Kap1 likes this.
  18. Aug 1, 2023 at 1:35 PM
    #498
    Tundra22SC
    That looks great! What tires did you go with?
    I’m not looking to get much higher than stock. I’d like to be able to fit 275/65/20 BFgoodrich AT on it and don’t want them to look too cramped. Definitely don’t want the squat look!
  19. Aug 1, 2023 at 1:39 PM
    #499
    ziznack
    ziznack New Member
    Texas Y'all
    Not if you adjust the stock rear arms all the way then it would be level with a leveling kit.
  20. Aug 1, 2023 at 2:02 PM
    #500
    Breathing Borla
    Northern Illinois
    you don't need them all the way, the pic you see is after the TSB and near the top of the spec at 40-42 mm, spec is 35-45mm.
    its level as you see it
  21. Aug 1, 2023 at 2:03 PM
    #501
    Breathing Borla
    Northern Illinois
    Cooper AT3 4S (275/60/20) 33" p-rated, made in usa , 65K warranty ride and look awesome. a little bigger than stock but only a few lbs more
  22. Aug 1, 2023 at 4:08 PM
    #502
    ziznack
    ziznack New Member
    Texas Y'all
    Interesting. I have mine all the way and there is a definite rake, in that a 1.75" leveling kit would make it sit level.
    Blufin and Tundra22SC like this.
  23. Aug 1, 2023 at 4:29 PM
    #503
    Breathing Borla
    Northern Illinois
    Your probably over the top spec perhaps?
  24. Aug 1, 2023 at 4:44 PM
    #504
    ziznack
    ziznack New Member
    Texas Y'all
    Yeah, cause if at spec or slightly above it bottoms out on the bump stops, unless I read the tab wrong. I read it as 35-45mm space between the bump stops and the frame.
  25. Aug 1, 2023 at 7:51 PM
    #505
    dodgemaniac
    dodgemaniac New Member
    I noticed this as well. When I first got my truck the back was lower then it should have been, like many on here. I raised it up to within spec and where rear is 1/2" higher then front, but it still bottomed out some and was harsh when doing so. I wanted to keep the truck level without lifting the front for now so I installed the Icon rear bump stop kit. Now it still hits the bump stops on large bumps but is much softer and smoother when doing so. I did also add 1/2" to the Icon setup to match factory engagement point.
    ziznack[QUOTED] likes this.
  26. Aug 2, 2023 at 2:44 PM
    #506
    Tundra22SC
    As someone previously mentioned. These trucks are relatively low to the ground compared to the previous generation as well as their competitors. I’m not looking to make it into a monster truck but would appreciate a couple more inches of height. Ideally I’d like to fit 275/65/20 AT tires on it without looking too crowded. If someone has a picture of that on stock suspension I would love to see it. I’m leaning towards a RC kit in the front then possibly adding afe arms to keep a rake if raising my stock air bag arms doesn’t get it high enough.
    Does adding a RC 1.75 to the front on a 1794 hybrid with AVS require any special shimming or extra parts? I assume the strut mount is the same just the strut itself has a wire coming out of it. Thanks for all the help. This is an awesome community!
    ziznack likes this.
  27. Aug 3, 2023 at 6:11 PM
    #507
    Tundra22SC
    So the simple spacers like the one me from rough country will fit an AVS strut and strut mount without any modifications?!
    ziznack likes this.
  28. Aug 3, 2023 at 7:02 PM
    #508
    BrettRod
    BrettRod New Member
    2022 WCP Tundra Platinum
    I don’t see why not. You will still have to mess with getting the electronic connector apart but not nearly the mess I dealt with to get the spring and collar off.
    DimaA and ziznack like this.
  29. Aug 4, 2023 at 11:56 AM
    #509
    Proven21
    Proven21 New Member
    VA
    so will westcott. I have westcott on my platinum with AVS & Rear Air Ride - no modification were necessary.
  30. Aug 29, 2023 at 8:39 PM
    #510
    ziznack
    ziznack New Member
    Texas Y'all
    What are people's thoughts on the rear arms from Westcott and afe, specifically, over inflation of the bags?
    Same question on the front leveling kits or Westcott preload collar, specifically, doesn't this put undue stress on the shocks? Readylift comes with rear shock extenders, but I haven't seen any that come with the front.
