Looking for MAF sensor cleaning advice
Discussion in '1st Gen Tundras (2000-2006)' started by Black '00 Tundra, Oct 8, 2020.
  1. Oct 15, 2020 at 6:38 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Don't forget, the Walmart link I provided is half the price! Buy two for the price of the Amazon link. Have a spare for your spare.
  2. Oct 15, 2020 at 6:55 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So you remove the old sensor, cover the thread chaser with anti-seize and run it into the the hole to hopefully pickup the boogers in there? Did you also coat the threads of the new O2 in Anti-seize? Do you have the part number for the nuts, I'm going to bookmark this for later use.
  3. Oct 15, 2020 at 6:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do we know anything about that manufacturer? DNA Motoring? It doesn't even list 1st Gen tundra in the description.
  4. Oct 15, 2020 at 7:35 AM
    Professional Hand Model
    Hand Protectors
    Yes. Yes. No.
    I also cleaned up the welds around the bung holes and used some rust reform.
    Stumplifter likes this.
  5. Oct 15, 2020 at 10:05 AM
    Black '00 Tundra
    Black '00 Tundra [OP] New Member
    Micah
    Beefy black man-wagon
    lol yeah really! Along with all the god damned rubbing alcohol. Rubbing alcohol has become an endangered species...
  6. Oct 15, 2020 at 10:44 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    My mechanic claims cleaning is the cause of the throttle position sensor failure.
  7. Oct 16, 2020 at 4:23 AM
    Hand Protectors
    The FSM says not to directly spray the Butter Fly as the liquid will travel down the pivot arm and bring with it dirt a grime, thus contaminating the Sensor.
    Use a microfiber and spray the rag.
  8. Oct 16, 2020 at 5:10 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Hee, hee.
    @Professional Hand Model said "bung hole"!
  9. Oct 16, 2020 at 5:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  10. Oct 16, 2020 at 5:20 AM
    Hand Protectors
    I’ve been reusing Paper Towels from drying my hands from all the washing from all these evil viruses out there. The Planetary Offset Credits are building Peas in places that need it.
    bmf4069[QUOTED] likes this.
  11. Oct 16, 2020 at 6:36 AM
    Hand Protectors
    Rust Reformed and Anti-Seized Rear o2 Bung.
  12. Oct 16, 2020 at 6:38 AM
    Hand Protectors
  13. Oct 22, 2020 at 2:43 PM
    Black '00 Tundra
    Micah
    Wow nice bunghole!
  14. Oct 22, 2020 at 3:49 PM
    Black '00 Tundra
    Micah
    I replaced all 4 02 sensors with new Densos, yet I've STILL got a intermittent misfire sensation at idle, along with sometimes stumble/misfire sensation pulling away from a stop. It's much better than it used to be, maybe 95% better at this point, but still not as good as it was last summer. 243k miles on the truck. Should I do the spark plugs next? I haven't even checked them for correct gap and overall condition. Oh here's another thing: if I run premium gasoline, the problem goes away. Makes me think this stumbling is detonation caused by lean condition. Maybe an injector that's not working right causing one cylinder to fire super lean, causing detonation? I don't have any check engine lights coming on either.
  15. Oct 22, 2020 at 3:58 PM
    Hand Protectors
    Can’t hurt to check the spark plugs. I use the NGK ones spec’d for our truck ($2 each). Not sure what else is going on with your truck, but sounds like you are figuring it out. Coil Packs might need inspecting when you do the plugs.
  16. Oct 22, 2020 at 4:53 PM
    Black '00 Tundra
    Micah
    Hmm, ok. How do I inspect the coil packs? Can I test the resistance with a multimeter or something similar?
  17. Oct 22, 2020 at 4:59 PM
    Hand Protectors
    Yes. Also inspect for cracks. You have to pull them when checking the spark plugs.
  18. Jan 29, 2021 at 7:23 PM
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
  19. Jan 29, 2021 at 8:29 PM
    #49
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    pm07[QUOTED] likes this.
  20. Jan 29, 2021 at 10:58 PM
    #50
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
    Thanks!
