Lower ball joints keep snapping
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ttev2424, Sep 11, 2023.
  1. Sep 12, 2023 at 10:02 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Kinda thinking that too. Maybe previous owner snapped LBJs and bought aftermarket LCAs that do not have the same contact point as an OEM LCA and thus allowing it to turn past a critical point.
  2. Sep 12, 2023 at 10:06 AM
    Ttev2424
    Ttev2424 [OP] New Member
    2014 crewmax 5.7 SR5
    What's the best 4x4 brand of control arms y'all recommend? I am looking at purchasing new ones
  3. Sep 12, 2023 at 10:09 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    If you're in NorCal I'd give you my OEMs that I took off my truck. They're just laying around the backyard.
  4. Sep 12, 2023 at 10:18 AM
    Ttev2424
    Ahh thank you, but I'm North West Washington
  5. Sep 12, 2023 at 11:17 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    You could do a test to see if this is the source of the problem. Figure out a way to put like a nut, maybe use some wire to tie it around the knuckle, so that it makes contact with the LCA sooner. Then back that thang up. Warning: you might break another LBJ if it's not the source of the problem :rofl:
  6. Sep 12, 2023 at 11:29 AM
    Ttev2424
    Hmm so kinda just fashion it on there and see if I'm squishing the nut? Or if the nut doesn't make contact?
  7. Sep 12, 2023 at 11:35 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Nut should make contact. When you turn full lock the steering wheel should not rotate as much as it usually does.
  8. Sep 12, 2023 at 11:46 AM
    Ttev2424
    I'll do that, I looked it up and those knuckles do not come with the lift kit
  9. Sep 12, 2023 at 1:05 PM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Something's fishy and I think Cruzer may be on to it.
    Also - it's easy to bash bracket lifts but if anything they are easier on most IFS components(especially CV's) with keeping closer to factory geometry and should have zero to do with this. issue.
  10. Sep 12, 2023 at 1:18 PM
    Ttev2424
    I also think he's onto it. I'm going to entertain the bolt idea. But in the end here I'm looking at lift kits without spacers. And new control arms
  11. Sep 12, 2023 at 1:23 PM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    OEM LCA's are really not "that" expensive if those are the issue - and with that bracket lift you don't need new UCA's
    BDS sells the replacement FOX coilovers to eliminate the lower spacer that match the kit also.
  12. Sep 12, 2023 at 1:28 PM
    Ttev2424
    I have Bilstein 6112 strut and spring assembly I was planning on replacing my fronts with
  13. Sep 12, 2023 at 1:36 PM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    You'd still need the spacer bracket as far as I know and it may not work with the 6112's.
  14. Sep 12, 2023 at 1:44 PM
    Ttev2424
    Yeah I would use the bracket with them. But just because the price of them I'm thinking of returning them and spending a little more on a front lift kit that does not use spacers
  15. Sep 12, 2023 at 1:51 PM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    I thought you just said you were planning on using the 6112's??
    but yes, I'd get the fox coilovers to replace the fronts and eliminate the spacers.
    Either way, it's not going to fix your lower ball joint issue.
  16. Sep 12, 2023 at 1:58 PM
    Ttev2424
    Rite, I have the 6112s I was going to replace with. But in the long run I'm hoping to get rid of the spacers. Was not sure if I could just get coilovers that could replace the old ones and the bracket. I'm not too truck savy. But from the sounds of it I'll get in touch with BDS and talk about the fox coilovers to get rid of that bracket. And the Joint problem I'm going to test the bolt idea by cruzer and see what happens
    Rc23 likes this.
  17. Sep 12, 2023 at 2:13 PM
    ToyotaG
    ToyotaG New Member
    Are those outer tie rods upside down? or is that part of the lift kit that you have to flip them .
  18. Sep 12, 2023 at 2:16 PM
    Ttev2424
    No they are not upsidedown
