Magnuson 2650 ordered 9/14
Discussion in 'Performance and Tuning' started by carn_dogg, Sep 15, 2023.
  1. Oct 23, 2023 at 8:04 AM
    #151
    carn_dogg
    carn_dogg [OP] i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    It’s here!!
    Silver17, Toyotoholic, bmw345 and 2 others like this.
  2. Oct 23, 2023 at 8:15 AM
    #152
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Dude.
    I'm excited for you!
    Life will be exponentially better now.
    19PlatinumCrew and Saltyhero13 like this.
  3. Oct 23, 2023 at 8:21 AM
    #153
    carn_dogg
    Pat
    Eastern Shore MD
    Thanks!!
    I'm definitely looking forward to this upgrade. I'm confirmed for 11/4 for the install day still. I will make sure to take as many pictures as possible for those interested and certainly keep you all posted along the way.
    AZTundra, Saltyhero13 and helidave like this.
  4. Oct 23, 2023 at 8:58 AM
    #154
    carn_dogg
    Pat
    Eastern Shore MD
    They did a nice job with the packaging. Big box has the blower in it. The medium box has everything else.
    PolishedTRD, Wynnded and snivilous like this.
  5. Oct 23, 2023 at 10:04 AM
    #155
    carn_dogg
    Pat
    Eastern Shore MD
    I was able to use the RTD tool to scan my truck and submit the file to magnuson.
    One of the steps was never prompted to me, #19 asking me to NOT scan/read the fuel control module (FSCM).
    Right now, I just followed what was asked and submitted the file to magnuson. we will see what I get back and see if I need to rescan/reread to get the correct file to upload for install day.
    edit - all is good. got my file back from magnuson and should be set for install day.
    Black@Blue19 and Wynnded like this.
  6. Oct 23, 2023 at 12:42 PM
    #156
    PentagonTundra
    PentagonTundra New Member
    2018 Tundra Platinum 4x4
    fully stock
    Congrats on the blower, which shop are you using for the install ?
  7. Oct 23, 2023 at 1:22 PM
    #157
    carn_dogg
    Pat
    Eastern Shore MD
    Thanks!
    I’m installing myself w my brother. He is a mechanic and I’m mechanically capable so going to make a day of it us two.
    The install is fairly straightforward for these kits. I had to replace the starter on my x5 last year that will probably prove to have been more difficult. But I’ll circle back to this claim post install lol
    Terndrerrr and Black@Blue19 like this.
  8. Oct 23, 2023 at 3:03 PM
    #158
    Ejp1234
    Ejp1234 New Member
    2021 TRD Pro DC Lunar Rock
    Where on the shore are you? Id like to check it out once finished. Im in the Denton area.
  9. Oct 23, 2023 at 3:18 PM
    #159
    carn_dogg
    Pat
    Eastern Shore MD
    pm'd
  10. Nov 1, 2023 at 4:34 AM
    #160
    carn_dogg
    Pat
    Eastern Shore MD
    One last pre install update:
    I re read through Magnusons installation instructions and decided to order new Intake Manifold gaskets and coolant bypass gaskets.
    Didn't like the idea of re-using, regardless of the condition when removed and inspected, and certainly didn't like the idea of winging it real time and not having the gaskets on hand at the time of install.
    So the final install list looks like:
    - Magnuson TVS2650 kit
    - Mishimoto Radiator Hoses, upper and lower
    - Radium PCV Oil Catch Can
    - OEM Waterpump and gasket
    - OEM Thermostat and housing
    - Innovate Boost Gauge
    - Innovate AFR
    MISC items:
    - New coolant bypass gaskets
    - New intake manifold gaskets
    - New ignition coil bolts
    - Toyota Coolant
    Oil change performed yesterday 10/31 at 163,674 miles.
    Ready to go for Saturday.
    Pictures to follow once I start up on Saturday.
    nasher75, helidave, Silver17 and 6 others like this.
  11. Nov 1, 2023 at 8:35 AM
    #161
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    If you don't mid sharing, what's your total cost for everything?
  12. Nov 1, 2023 at 10:03 AM
    #162
    carn_dogg
    Pat
    Eastern Shore MD
    I would need to run the numbers and can do that eventually but here is the rough breakdown
    Blower was 8095
    Gauges and pillar approx 600
    Water pump and thermostat approx 200
    Coolant 60
    Gaskets and bolts 70
    Catch can 250
    Radiator hoses 120
    So what… about 9395
    Still thinking about doing rear sway bar, koyo radiator, and traction bars. But one thing at a time.
    helidave[QUOTED] likes this.
  13. Nov 1, 2023 at 10:38 AM
    #163
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Replace the rad with an oem unit. Too many issues with aftermarket units.
    Wynnded likes this.
  14. Nov 1, 2023 at 10:48 AM
    #164
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah, that is what we (possibly you and I, but def a member on here - I'd need to go back and check) discussed earlier when going through the list of items to upgrade/refresh.
    Ended up deciding to wait and monitor temps and performance with OEM Radiator.
  15. Nov 4, 2023 at 4:13 PM
    #165
    carn_dogg
    Pat
    Eastern Shore MD
    She lives!!!
    7 am start. 7 pm finish. Lunch break and a trip to autozone to grab new idler pulleys. Truck rips.
    More pics tomorrow and a write up. I’m spent
  16. Nov 4, 2023 at 4:24 PM
    #166
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Did you have a pit crew in there?:)
    Looks very nice and clean, good job.
    carn_dogg[QUOTED][OP] likes this.
  17. Nov 4, 2023 at 4:42 PM
    #167
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Great job man! It def helps when you have a mechanic helping out huh?
    carn_dogg[OP] likes this.
  18. Nov 4, 2023 at 5:16 PM
    #168
    carn_dogg
    Pat
    Eastern Shore MD
    Haha yeah it does. It went pretty smooth, all things considered. 163k on the truck so you never know. All is well and the truck is healthyyyyy. It’s quick and moves effortlessly. Very happy this far.
    I’ll post a bunch more pictures of the steps and install. And a few irritating parts. But all went good!!
    Saltyhero13 and Ginsterkev like this.
  19. Nov 4, 2023 at 5:18 PM
    #169
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What’s the tuning?
  20. Nov 4, 2023 at 5:34 PM
    #170
    carn_dogg
    Pat
    Eastern Shore MD
    Hp tuners. Magnuson sent the tune. Might pay to have it custom tuned but for right now it works great. Pulls hard and feels strong.
  21. Nov 4, 2023 at 5:36 PM
    #171
    carn_dogg
    Pat
    Eastern Shore MD
    Few more pics
    kbark, Saltyhero13, Wynnded and 4 others like this.
  22. Nov 4, 2023 at 5:47 PM
    #172
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Awesome, glad to hear it went off without a hitch and that you’re satisfied with it. There aren’t many other engines out there that many people would consider putting a 8k+ supercharger on with over 160k miles. A true testament to how awesome they are built.
  23. Nov 4, 2023 at 6:28 PM
    #173
    carn_dogg
    Pat
    Eastern Shore MD
  24. Nov 4, 2023 at 6:46 PM
    #174
    carn_dogg
    Pat
    Eastern Shore MD
    Truck hits 10-11 psi at WOT.
    Still need to calibrate the wideband. The numbers jump all over the place. I must not have done that right. Or at all. Need to iron out that.
    damn fun to drive now
    Saltyhero13, Wynnded and Ginsterkev like this.
  25. Nov 4, 2023 at 6:50 PM
    #175
    Ginsterkev
    Kevin
    Pennsylvania
    Hey question, did you guys split the blower open and put the bottom half on first and then bolt the top part on ? Or am I seeing something different? I have the tvs1900 and it went on as one whole unit however it was very very heavy so was just wondering if you did as a weight saving thing and also to help with the intake gaskets or is it just how the directions said to do it ? Or hell maybe I'm not even seeing what I think I'm seeing lol
  26. Nov 4, 2023 at 6:53 PM
    #176
    Tundra_wil
    Tundra_wil New Member
    is it on a smaller pulley ? I thought stock was 8-9 psi. Also did you order directly from magnuson ? I’ve seen some shops offering same day shipping . Also if I end up buying one I’ll try to do a draggy test 60-90 run to see how much more passing power there is haha
  27. Nov 4, 2023 at 6:54 PM
    #177
    carn_dogg
    Pat
    Eastern Shore MD
    yeah you have to split it to install. I’m sure it provided some nice weight savings. But there are four long bolts that get installed from the inside of the blower. Then you can put the top on with loctite and torque down[/QUOTE]
    Saltyhero13 likes this.
  28. Nov 4, 2023 at 6:56 PM
    #178
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 65mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I read through the instructions some time ago, I think it's more of a cover than anything.
    Ginsterkev[QUOTED] likes this.
  29. Nov 4, 2023 at 6:56 PM
    #179
    carn_dogg
    Pat
    Eastern Shore MD
    I ordered from SCOL. Arrived in about 4 weeks. Not sure about what other shops offer. Shipping was included in the cost of the kit when I purchased. I wasn’t in a rush so didn’t need same day shipping and I’m too far from those shops to pick up local.
    oh there is instantly more passing power. Without even giving it much throttle.
    stock pulley size on it. Just makes good boost. Not sure why more than the advertised
  30. Nov 4, 2023 at 6:56 PM
    #180
    Silver17
    Eastern PA
    10-11 psi on the stock pulley!? What did they ship it with the wrong one on there? Lol best check your AFRs with a wideband.
    snivilous likes this.
