Morimoto XB Gen 2 Amber DRL
Discussion in '2.5 Gen Tundras (2014-2021)' started by Broomsky06, Jun 5, 2021.
  1. Jul 5, 2021 at 2:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  2. Jul 5, 2021 at 2:35 PM
    Mr. Socom
    Mr. Socom New Member
    Los Angeles
    2021 Limited Tundra
    Noticed they’re 15% off today, so might jump on them :)
  3. Jul 5, 2021 at 2:52 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    It's a wiring bundle that allows the headlights to interface with your OEM equipment. If your truck came with OEM LEDs you're gonna need a pair of them. A pair will be around $100.
  4. Jul 5, 2021 at 2:53 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Ok perfect, that’s what I was wondering. Thank you
  5. Jul 5, 2021 at 2:56 PM
    memario1214
    Colton
    Missoula, MT
    Certainly. If I could beat the 15% off shipped price to you I'd do it! It's a good deal.
  6. Jul 5, 2021 at 3:09 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Just ordered it. Is the install difficult?
  7. Jul 5, 2021 at 3:16 PM
    memario1214
    Colton
    Missoula, MT
    Broomsky06[OP] likes this.
  8. Jul 5, 2021 at 4:12 PM
    Broomsky06
    Broomsky06 [OP] New Member
    2021 Tundra Silver CM
    From what I have read and seen on other threads talking about headlights; I am almost certain it connects existing LED harness (if equipped) from the factory to the new Morimoto harness. I’m not entirely sure since I didn’t have factory LED. Maybe @Headlight Revolution can chime in. That’s where I got mine from.
  9. Jul 5, 2021 at 4:20 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    memario1214[QUOTED] likes this.
  10. Jul 5, 2021 at 4:26 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Yeah I messaged them earlier but didn’t get a response. Went ahead and bought it though since they had a sale that expired today. Hopefully I need it.
  11. Jul 8, 2021 at 11:01 PM
    joe557
    joe557 New Member
    Joe
    2014 Crewmax SR5 4x4 TRD
    Bilstein 6112/5160s, durobumps, 1" CB shackles, RCI skids
    the gen 2’s come with all the wiring you need for either halogen or led factory. Nothing additional is required.
  12. Jul 8, 2021 at 11:49 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    If you don't have LED DLRs / turn signals you will need the non LED relay, it replaces the chip board that is outboard of the fuse box under the dash. At least that's how it works on my 2016. Huge improvement over stock and worth the money if you drive at night.
  13. Jul 8, 2021 at 11:54 PM
    joe557
    joe557 New Member
    Joe
    That non DRL relay is now included in the wiring harness with the gen 2’s check out the video from headlight revolution.
  14. Jul 8, 2021 at 11:59 PM
    AZ Red Nek
    Chuck
    Just my luck, I've had the gen 2s for about a month and I had to order the relay. Oh well, I'm still glad I got them. PS got them from Headlight Revolution.
  15. Jul 9, 2021 at 12:08 AM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    I bought the Gen 2 and the harness. So I guess I don’t need it? Can I return it? I spoke with headlight revolution and they said I needed it?
  16. Jul 9, 2021 at 11:06 PM
    joe557
    joe557 New Member
    Joe
    skip to 5:40 in this video. Just going by what they say.
    https://youtu.be/fQWXMGXDnLE
  17. Jul 10, 2021 at 12:21 PM
    memario1214
    Colton
    Missoula, MT
    I'm not sure where you're getting that the XB adapter is included from that video, but I am also now wondering if people are talking about 2 different parts...
    • The part I was referring to is part number LF532H which is the XB adapter harness that will be necessary (2 of them) for any 18+ truck that came equipped from the factory with LEDs. This is the "C"-shaped LED ring that goes around the outside of the housing and the full LED emitters for low/hi beams.
    • The part that I think folks may be getting confused with is part H135. This part (as I understand it) is for those trucks that use the turn signal bulb as part of the DRL array. This could be for those that have just the bottom LED bar and not the full C-shape, those that don't have LED DRLs at all, and I have even seen some trucks that use the C-Shaped LEDs as the DRL in conjunction with the turn signal. My scenario ('21 Limited Crewmax) uses ONLY the C-Shaped LEDs as a DRL which leads me to believe that I do not need this part. I personally have no idea what the truck combination has to be to drive each scenario. Either way, this part eliminates the turn signal being used as a DRL which wreaks havoc on aftermarket headlights.
    Either way... I have a set ordered and coming eventually to swap into my OEM LED equipped Tundra. I added the harnesses as I am 99% sure that I need them. I shall have more details when everything arrives!
  18. Jul 10, 2021 at 12:32 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Please keep me updated, I have a 2021 limited, And also ordered a set with the led harness.
  19. Jul 12, 2021 at 6:43 PM
    #49
    joe557
    joe557 New Member
    Joe
    Ok I stand corrected. I contacted HR to clarify what’s needed because the video suggests it’s all PNP. For OE halogen that uses the same bulb for DRL and turn signal, the relay is needed. The relay replaces existing Toyota relay behind drivers side kick board. Hope this helps someone. It helped me and I had to order the relay. It’s about $70
  20. Jul 16, 2021 at 8:35 AM
    #50
    memario1214
    Colton
    Missoula, MT
    SOON...
    AZ Red Nek likes this.
  21. Jul 7, 2022 at 1:49 PM
    #51
    Nick4wheelin
    Nick4wheelin New Member
    2017 Red Tundra TRD PRO
    I have seen where it's said that the amber color only looks good on certain colors of trucks. Do you think the morimoto gen 2 amber would be a good fit for a red TRD PRO?
    Also for those who have had both, would you recommend morimoto gen 2 or factory LED headlights? Pros and cons of both excluding the price, thanks.
  22. Jul 7, 2022 at 1:57 PM
    #52
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Forget matching, get DD SS3
  23. Jul 7, 2022 at 2:27 PM
    #53
    Is your red the Barcelona red or the Orange Inferno? As far as Morimoto or OEM leds, it's really personal preference to a point. The OEM leds are reflector housings and the Morimotos are projector housings. They are both good lights.
  24. Jul 7, 2022 at 6:44 PM
    #54
    Nick4wheelin
    It's red, a darker red. It's not orange at all.
  25. Jul 7, 2022 at 6:54 PM
    #55
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Just put mines on as well. Love the ambers!
  26. Jul 7, 2022 at 7:31 PM
    #56
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Looks awesome!!!:drool:
  27. Jul 7, 2022 at 7:39 PM
    #57
    OK so you have the Barcelona. You're in luck for pics. I have the white DRL on my truck and the amber DRL on the wife's 4Runner...both are Barcelonas. The amber is really visible during the day.
    Gee Dub, omgboost and WFD473 like this.
  28. Jul 7, 2022 at 7:42 PM
    #58
    Get PPF installed on them so that they don't haze.
    pkeawe809[QUOTED] likes this.
  29. Jul 7, 2022 at 10:04 PM
    #59
    Nick4wheelin
    The amber is looking really nice to me, expecially on the red! Does anyone know if the morimoto gen 2 has a better low beam than factory LED? By looks I am leaning toward the gen 2's.
    I currently have a black factory looking led set. They were like $350 and looked good but the low beams suck, one is burned out and they are less than 2 years old. I know, I know they were knock offs and I got what I paid for.
  30. Jul 8, 2022 at 5:02 AM
    #60
    The video on Headlight Revolution actually shows a comparison between the Morimotos and the factory leds.
    omgboost likes this.
