My DIY Roof Rack
Discussion in '2.5 Gen Tundras (2014-2021)' started by junior, Dec 10, 2020.
  1. Dec 6, 2021 at 1:06 PM
    #61
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    hahaha I drilled holes in roof for a lightbar mount and o_O the only other time im gonna do it is to mount a roof rack
  2. Dec 6, 2021 at 2:46 PM
    #62
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Excessive alcohol usually gives me a boost of confidence…and stupidity! LOL:D
  3. Dec 6, 2021 at 3:08 PM
    #63
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    goodluck lol. dont forget to check the inside for airbags and some sealant of some sorts.
    junior[OP] and joseph_womack like this.
  4. Dec 6, 2021 at 5:04 PM
    #64
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Go for it, it's not that big of a deal with some forethought and preparation. Check out my "build" page starting at post 15 to see how I managed to carefully drill mine safely and without incident. Your work with the "porch" lights on your rack inspired me to modify the process a bit and light my cab rack without drilling through the roof for the electrical connection.
  5. Dec 6, 2021 at 10:21 PM
    #65
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    :rofl:same for better or worse haha
    @TampaRD Pro thanks man. Your technique is definitely the way to go and I appreciate the pics! I definitely think about building the cab rack a lot still, here's the matching initial design to the rear:
  6. Dec 7, 2021 at 5:24 PM
    #66
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    That's a really nice design! I can see that you allowed for the curvature of the roof on the cab which is important. Make sure you allow for clearance for opening the sunroof if you have one, and on the 2020 I had to clear the sharkfin antenna in the rear, too. With a cab rack and a matching rack on the cap you will have a ton of real estate for carrying things up top. Go for it, and post some pictures when you finish, you do good work!
    By pulling down the sides of the headliner for safety you could also through bolt it and forego the rivnuts all together. It's probably a stronger attachment that way, too. I already had the RivNut tool and made good crimps so I feel good about using it. I've had two 15 foot kayaks up there at highway speeds plus an awning and lots of other gear and weight at different times with no problem at all. I love the cab rack and use it all the time.
    joseph_womack likes this.
  7. Dec 22, 2021 at 10:25 AM
    #67
    dandrilla
    dandrilla New Member
    Dom
    Boise
    2020 1794 Super White
    @junior this is fantastic - on my short list of projects to do now. When you say the fairing was measured for your leer shell - is that something you did? how did you account for the curve? that looks like a dicey measurement to get right.
  8. Dec 22, 2021 at 8:11 PM
    #68
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    I started with a straight on photo, then to a digital to-scale mock, then to a test cardboard cut template. What I didnt account for, and why I dont run it any more is for a tiny bit extra "space" that the rubber grommet edge took up after I applied it, so under vibration while driving it started to rub the clearcoat of the shell's paint.
    Badknees and joseph_womack like this.
  9. Dec 22, 2021 at 8:19 PM
    #69
    joseph_womack
    Joe
    Louisiana
    @junior one last question for ya... are you close to getting the measurements for the cab rack? I've got a single cab and was scratching my head on the best way to measure it since its such an obscure application
  10. Dec 22, 2021 at 8:24 PM
    #70
    dandrilla
    Dom
    Boise
    If you were going to fabricate this yourself, it seems like a feasible solution would be to use vertical grooves in the fairing sheet for the bolts that attach the sheet to the crossbar as opposed to round holes, which would give you a little play in how closely you mount it to the cap. Having built one already, does this make sense? Or am i thinking about this incorrectly?
  11. Dec 22, 2021 at 8:48 PM
    #71
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    Same technique I just posted above. I started with a super parallel photo. I used Adobe Illustrator to mock it up as close to full scale as possible and then made a cardboard mock up with printed sheets. Its not perfect but the best I can think of for DIY. If you don't have Illustrator, I'd start with a straight piece of cardboard and just slowly start trimming it til you get a curve that you like, you know?
    Edit: if you give me a good side shot of your truck I can help you if you need it
    100%. Slots would have definitely helped and give you adjustability. The thing you want to be careful of is to not let the top, leading edge of your fairing be above the crossbar/siderails. If you don't have anything on the rack its not a big deal though
  12. Dec 23, 2021 at 6:49 AM
    #72
    Badknees
    Badknees New Member
    South Carolina
    Think I’m going to try making a rectangular fairing out of 1/4” thick x 4” tall x rack width black UHMW. It will follow the rack dimensions and not the shape of the cap, but I’m not sure how much that matters…unless I hear excessive wind noise, of course. Will advise how it turns out and I may need to do something about the “scratched” surface appearance of the UHMW.
  13. Jan 15, 2022 at 11:50 AM
    #73
    Badknees
    Badknees New Member
    South Carolina
    Had a little extra time today so I installed a 1/4 Thk x 4”x54” UHMW fairing on the rack. Pretty simple work and looks ok for now anyhow. I’ll provide feedback and may need to remove if too much wind noise.
    Best
    D682CF00-C197-449F-AA04-BD8C11A19B51.jpg C936D9A2-65AE-4A2A-B2F2-913E7BC65052.jpg 324F756F-7626-4988-8B40-44480AD2F545.jpg B329FD06-C388-457F-91F7-E89B3A944445.jpg
  14. Jan 25, 2022 at 9:02 AM
    #74
    roadman
    roadman New Member
    2020 Limited CM
    Does anyone have the stock width of the roof rack rails on the leer toppers? I bought my topper second-hand without rails and I'm looking to install my own, hopefully with the same dimensions.
  15. Jan 25, 2022 at 9:21 AM
    #75
    junior
    junior [OP] Member
    Zach
    Santa Cruz, CA
    Somehow I missed this. Nice work man! How's it working for you?
    I just went out and measured on my 100XR. Its 40.5" center to center between the rails
  16. Jan 25, 2022 at 9:25 AM
    #76
    roadman
    roadman New Member
    2020 Limited CM
    Awesome, thanks for the information!
  17. Jan 25, 2022 at 9:34 AM
    #77
    Badknees
    Badknees New Member
    South Carolina
    Hey Zach! Thanks for the comments and hope all is good out your way. All is well here, but I just don't take the Tundra out too much. I've got a '98 Taco as my daily driver as it's a lot easier to wash than the Tundra and already has 330K+ miles...a bit better on gas too! I hope to get out soon for a road trip and check out the wind noise on the fairing.
    Take care my friend!
  18. Mar 2, 2022 at 8:35 AM
    #78
    Badknees
    Badknees New Member
    South Carolina
    Just for the record, using UHMW as a fairing material is a bad idea. Expansion/contraction under temperature changes makes it buckle between the anchor bolt locations. It was worth a try anyhow and the rack works fine without a fairing.
  19. Jul 28, 2022 at 7:52 PM
    #79
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    I'm a software engineer also. I think CSS was used to place the roof rack on the Tundra :rofl:Just missed the roof by a slight margin
  20. May 24, 2023 at 11:25 AM
    #80
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Hot Damn, I am a CS/math HS teacher and we have lots of toys in our Engineering Department, wonder how much the Engineering guy is going to charge me for the Aluminum to make this...
    WVI likes this.
