My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Jan 15, 2019 at 6:10 AM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    I'm thinking Amazon is wrong cause I think people have installed them on '18's.? And they are working fine. Quite honesty I don't think tundras have changed their headlights much lately.
  2. Jan 15, 2019 at 6:18 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Thank$! Now I need to convince the wife I need better turn signal lights! Perhaps there is a thread were somebody got into an accident due to weak signal lights I can use to bolster my cause...
    reelcracker likes this.
  3. Jan 15, 2019 at 6:49 AM
    skidds
    skidds New Member
    MA
    2018 CM Platinum - Black
    I need to order these - I have had a couple people tell me that they could not see the signal. one guy was pissed about it - I live in MA where 90% never signal, so not sure why he was so mad. (although... I am one of those people that get pissed when the other driver does not signal)
    YsoSeRiouS!, Pudge and reelcracker like this.
  4. Jan 15, 2019 at 6:57 AM
    reelcracker
    Farva
    2018 off-road d/c
    You could always just buy hem and say " look darling, all these folks are having trouble with people seeing their turn signals in their trucks so I ordered these really kewl bright ones so you would be safe" then after getting your azz kicked have some make up woopie and go drink a beer.:hattip:
    skidds likes this.
  5. Jan 15, 2019 at 7:32 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Anybody else have any feedback on VLEDS or JDM Astar if DRL still work after swapping out the stock with these? Is keeping DRL functioning with aftermarket LED bulbs even a concern?
  6. Jan 15, 2019 at 7:33 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    When you say they can't see your turn signals are you talking about at night when the headlights are on?
    Are these brighter only when flashing? I have the OEM 18's added to my '16 but I chose to go with the orange daytime option lit up as well. I don't want those brighter than they are but am OK with the turn signal part being brighter. I'm assuming it would all be brighter?
  7. Jan 15, 2019 at 7:52 AM
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    Correct, people couldn't see them at night when LED headlights are on.
    As for DRL...On my 18 OEM headlights, only the white strip (around the headlamp housing) and small amber side marker turns on in DRL mode. Amber turn signal bulbs were never on (with stock bulbs).
  8. Jan 15, 2019 at 8:15 AM
    JeremyGSU
    Jeremy
    2016 Tundra
    Correct. That is how the factory 18's are.
    When you opt to retro any 18's on a prior 18 you can splice into the daytime running lights on the old setup and have the orange light up as well. This is how mine look. I don't want the orange to over do the white, just blend in. It sounds like it would be too bright for my setup.
    Vr0ck likes this.
  9. Jan 16, 2019 at 11:59 AM
    drapex
    drapex Floridian by birth
    RTP, NC
    2018 CM Platinum - Barcelona Red Metallic
    I've noticed several people lately haven't been responding to my turn signals. Let's see what works here. I definitely want plug and play...
  10. Jan 16, 2019 at 12:40 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    it seems the 18+ trucks use the low wattage part of the bulb for the blinker? i retrofitted my 17 with amber DTRL with the 18 LED headlights. i like the amber DTRL, so kept them. the harness i made keeps the amber high wattage DTRL and blinker. i have no issues with the blinkers on my truck.
    i bet a simple fix would be to flip the hi/low wires to the bulb. i woudl think that would then illuminate the 21w portion of the bulb, rather than the 5w portion, on signal?
  11. Jan 16, 2019 at 1:59 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    No hyper flash. Resistor built in.
    SnrDisregardo[QUOTED] likes this.
  12. Jan 16, 2019 at 2:00 PM
    r1-superstar
    DB
    UTAH
    It fit and works with my 18.
    Silv333[QUOTED][OP] likes this.
  13. Jan 16, 2019 at 2:05 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I'm actually surprised the DRL don't turn off or dim when the turn signal is activated like you see on other models/brands.
    Watt maker likes this.
  14. Jan 16, 2019 at 2:10 PM
    r1-superstar
    DB
    UTAH
    I see other vehicles with this function and I don't care for it. I know it probably serves a purpose but it looks funny.
    Mark18TRD and Boerseun like this.
  15. Jan 16, 2019 at 2:11 PM
    SnrDisregardo
    Wade
    IL
    Agreed, but I notice how dim they were soon after buying and thought it should at least dim when the headlights weren't on. I have the JDM ASTAR's coming in the next day or so.
  16. Jan 16, 2019 at 2:13 PM
    r1-superstar
    DB
    UTAH
    You will like those bulbs. They are BRIGHT!!
    Pudge likes this.
  17. Jan 16, 2019 at 6:09 PM
    NorCalTrdsport
    NorCalTrdsport New Member
    2018 MG TrdSport
    Anyone consider sequential led strips just under the front of the fenders wrap towards the side following the body line?
  18. Jan 16, 2019 at 6:13 PM
    SnrDisregardo
    Wade
    IL
    Holy smokes they are bright. Huge difference. Anyone try them in the rear of a 2018 and not need resistors?
    r1-superstar[QUOTED] likes this.
  19. Jan 16, 2019 at 7:05 PM
    #49
    r1-superstar
    DB
    UTAH
    HAHA! Told you so. :rofl:
  20. Jan 16, 2019 at 9:43 PM
    #50
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
  21. Jan 17, 2019 at 6:20 AM
    #51
    SnrDisregardo
    Wade
    IL
    They are. Crazy bright. I have banana hands so it was a bit of a PITA to change driver side.
    r1-superstar likes this.
  22. Jan 17, 2019 at 6:53 AM
    #52
    r1-superstar
    DB
    UTAH
    They are so bright I can actually see yellow bouncing off walls and stuff when my headlights, DRL, and fog lights are on.
  23. Jan 17, 2019 at 6:57 AM
    #53
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Buy, buy, buy.
    :spending:
    Sloantundra likes this.
  24. Jan 17, 2019 at 7:05 AM
    #54
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I just checked my front turns out, they are plenty bright for another driver to see with the headlights on........2018 SR5. My bulb location isnt on the inside lower like the picture above though, its on the inside upper. I can see how a turn signal that close to the LED DRL could be indistinguishable.
  25. Jan 17, 2019 at 7:07 AM
    #55
    SnrDisregardo
    Wade
    IL
    20 smackers, you can't beat it. Hopefully they are somewhat quality product and get some life out of them. For how much they will get used, should be fine.
  26. Jan 17, 2019 at 7:18 AM
    #56
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I notice that too at night, very bright, probably because the area was meant for amber halogens and the light is bouncing all over the place in there. I’m not sure they’re that much brighter in full daylight but you can see the scatter.
    Visibility was the reason I undid my modded 3 amber marker lights in the hood. When I signal, it’s the only amber light on in the front.
    From the back I have no issue because these long Putco lights go half amber on turns.
    yoshi82, Mountun Goat, equin and 2 others like this.
  27. Jan 17, 2019 at 7:21 AM
    #57
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Wondering if these will work for my 2019 TRD Sport. If so, I'll order them today. Amazon says the bulbs will not work on my truck. :(
  28. Jan 17, 2019 at 7:25 AM
    #58
    r1-superstar
    DB
    UTAH
    They should. Amazon says they don't work on mine either. haha
  29. Jan 17, 2019 at 7:47 AM
    #59
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Same here.
  30. Jan 17, 2019 at 7:52 AM
    #60
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    Which tailgate break light do you have? Thats nice!
