New best Gen Owner
Discussion in '1st Gen Tundras (2000-2006)' started by JakeJake, Jul 19, 2023.
  1. Jul 23, 2023 at 3:07 PM
    #61
    JakeJake
    JakeJake [OP] Slippery Snake
    2000 Tundra AC 4X4
    Thanks for the input! Ive put the carrier bearing on the "do then when I get bored" list.
    @shifty` sorry, no before pics, but here's the afters:
    Not bad for a 23 year old former work truck
    The drivers seat bottom is pretty threadbare and has a tear in the bolster:
    Any good options for durable seat covers on the 40/60 split? Im not sure who is dirtier after a long day playing outside, Myself or Dale.
    bmf4069 and shifty` like this.
  2. Jul 23, 2023 at 3:13 PM
    #62
    Xcruiserguy
    Xcruiserguy New Member
    Pete
    Ontario, Canada
    ‘06 DC SR5
    Bilstein 6112/5100, SPC UCA, Sumo Springs, 265/75/16 Nokian Outpost AT, ARE cap. DD/335k km
    Brakes: for a while after I got mine I thought a big-brake swap was inevitable (the brakes sucked) but as an experiment I installed Hawk green/SUV pads and I now do not see any need. These pads grab fast and hard, and do not fade. As long as your back shoes are in good shape and adjusted properly, and you have fully bled the lines, these are the bomb. No need for larger calipers/rotors/rims/tires
    w666 and JakeJake[QUOTED][OP] like this.
  3. Jul 23, 2023 at 5:58 PM
    #63
    shifty` Pattern Against User
    This has been a topic that's popped up once or ten times on the forum. I dunno there was a consensus on 60/40 but this may save you some legwork. https://www.tundras.com/threads/seat-covers.114878/#post-2956228
    Note the 9th/last reply links out to a crapload of other seat topics.
    You think I should replace the OEM factory carrier bearing on mine, at 75k miles, which has 1/2" play in it but shows no other signs of issue?
    JakeJake[QUOTED][OP] likes this.
  4. Jul 24, 2023 at 9:45 AM
    #64
    Xcruiserguy
    Pete
    Ontario, Canada
    ‘06 DC SR5
    You think I should replace the OEM factory carrier bearing on mine, at 75k miles, which has 1/2" play in it but shows no other signs of issue?[/QUOTE]
    If it does not bother you, no. But, if the fine engineering minds at Toyota intended for there to be that much play, they would have spec’d that much in the bearing when new. I tend to be real anal/sensitive to anything off spec, especially driveline and suspension, that’s all.
  5. Jul 24, 2023 at 9:53 AM
    #65
    I dunno, it's just something virtually everyone I've seen check on here has found. 1/4" to 1/2" of play, it's apparently normal for the OEM carrier.
  6. Jul 25, 2023 at 10:59 AM
    #66
    teereqs
    teereqs New Member
    What did the red hazard button come on?
  7. Jul 25, 2023 at 11:12 AM
    #67
    Earlier model trucks. I know in 2005 when the 5spd came out, they pulled 1st gear off the indicator and put a "SHIFT L" button for 1st gear in that location. It's possible they got rid of the red button earlier, but, like, my '06 has a black button with a red triangle in the middle IIRC.
    teereqs[QUOTED] likes this.
  8. Jul 25, 2023 at 11:17 AM
    #68
    teereqs
    teereqs New Member
    So, no specific package or trim had it? Was it just random whether the truck came with it or not? I know in some Japanese cars the JDM variant will have a red hazard and the USDM counterpart won't, but they can be swapped over.
  9. Jul 25, 2023 at 11:26 AM
    #69
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    My 2000 has the red hazard button also.
    teereqs likes this.
  10. Jul 25, 2023 at 11:27 AM
    #70
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I could be wrong but I think it's only the 2000's that had the red button. My 02 is black.
    teereqs likes this.
  11. Jul 25, 2023 at 11:28 AM
    #71
    Nope, it was just an earlier truck thing.
    Fun thing is, the button shape and size, I don't believe it changed thru the years. I wouldn't doubt if I could slap an old red button in my center dash bezel. But after the work I had to do to swap buttons when I upgraded to wood grain ... hell, I don't want to do that.
  12. Jul 25, 2023 at 11:47 AM
    #72
    So sexy. It clashes though. Think I’ll plastidip it
    shifty` likes this.
  13. Jul 25, 2023 at 12:02 PM
    #73
    That angle makes things look weird, like the dash bezel matte part is embossed outward or something. Total optical illusion. Or maybe the drugs the doc put me on are better than I thought. :rofl:
    And maaaaaan that 4HI button is looooooooooooooooong
  14. Jul 25, 2023 at 12:04 PM
    #74
    Better?
    bmf4069 likes this.
  15. Jul 25, 2023 at 12:10 PM
    #75
    Yup, and no more long 4HI button.
    I'm jealous of y'all earlier year trucks with the perfect double-DIN radio opening.
    The Black Mamba likes this.
  16. Jul 25, 2023 at 12:17 PM
    #76
    FirstGenVol
    East TN
    2002 AC
    Man I'm glad I don't have the fake woodgrain.
  17. Jul 25, 2023 at 12:26 PM
    #77
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    My T100 had a cloth bench seat, it developed a few rips over the years, I never got a cover for it but I did find that iron on patches worked pretty well and kept the holes from getting bigger and protected the foam.
    Even if you find a cover it might be a good idea to try the patches to protect the foam.
  18. Jul 25, 2023 at 1:33 PM
    #78
    Casper421
    In the woods
    06 DC
    Rattle can makes a quick fix of that
    bmf4069 and teereqs like this.
  19. Jul 25, 2023 at 2:14 PM
    #79
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I stitched up my driver seat when it was just an inch long tear and it’s held for a few years now. Might try an old school upholstery shop if you have one in your town
  20. Jul 25, 2023 at 9:27 PM
    #80
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah 00 only.
    teereqs likes this.
  21. Jul 26, 2023 at 8:52 AM
    #81
    teereqs
    teereqs New Member
    Looked at about every 2000 fb marketplace ad and confirmed all have red button. Good info!
  22. Sep 21, 2023 at 12:14 PM
    #82
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Amazon.com: Durafit Seat Covers, Made to fit 2000-2004 Tundra Front 40/60 Split Seats with Fold Down Console. Dark Gray Twill with Gray Velor Inserts. : Automotive
    Leaving this here for future searches
  23. Sep 21, 2023 at 2:25 PM
    #83
    JakeJake
    2000 Tundra AC 4X4
    From the dead!
    I think I'm going to go this route when its time. https://coverking.com/products/2000...02&sub=SR5&main=seat-cover-ballistic-tactical I reached out to them a while back to confirm fitment of the 40/60 split.
    Im a sucker for the convenience of molle. The rear seat is getting removed to fit a 60qt dual zone fridge/freezer, so the extra seat back storage will be nice.
    I'm 90% sure I just landed another project, just waiting on engineering and city plan approval. Unfortunately that means I won't be playing with the truck anytime soon. Im going to have more money in my new parts pile than I paid for the truck before too much longer.
    Somebody remind me in about a month that I have straight water in the cooling system, around Halloween is first freeze territory.:rofl:
