New Morimoto 14-21 Tundra Taillights have FINALLY arrived!
Discussion in 'Lighting' started by Headlight Revolution, Mar 24, 2022.
  1. Mar 8, 2023 at 12:01 PM
    #211
    Rod702
    Rod702 New Member
    Rod
    Cherry red Barca tundra !
    Oem
    is the resistor the black box with heat sink fins on them ? That’s all that came
    With kit ?
    WILLINH likes this.
  2. Mar 8, 2023 at 12:07 PM
    #212
    Rod702
    Rod702 New Member
    Rod
    Oem
    Circled in red
  3. Mar 8, 2023 at 12:19 PM
    #213
    SILVA1181
    SILVA1181 New Member
    Marc
    Houston, TX (Spring Area)
    Do not see resistors in the photos either. I have OEM Led headlights and had hyper flash issues as well when first installing the XB tail lights. As soon as I added the resistors hyper flash was gone. Not sure if your issue has anything to do with having XB headlights. I am sure you know this but just in case, these are the resistors.
  4. Mar 8, 2023 at 12:35 PM
    #214
    Rod702
    Rod702 New Member
    Rod
    Oem
    yes those are the ones.
    i switched driver side to passenger side same issue. Both had resistors on them, driver side had no issues.
  5. Mar 8, 2023 at 12:48 PM
    #215
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Hmm... Can I have you stretch the wiring out a bit more to allow me to see things a little more of an "exploded" view? My gut guess is that the resistors are not engaging on that side for whatever reason. What year truck do you have?
  6. Mar 8, 2023 at 12:56 PM
    #216
    SILVA1181
    Marc
    Hmm! Maybe provide a photo showing the resistors attached/connected to the tail light because what you circled on the photo are not resistors as far as I know, unless Morimoto has now built the resistors in to the taillights? Just for reference, I purchased my tail lights in late 2022 and installed in December and the resistors were not pre-installed.
    Sorry, can be more help, maybe others will chime in.
  7. Mar 8, 2023 at 12:57 PM
    #217
    Rod702
    Rod702 New Member
    Rod
    Oem
    2017 limited crewmax. I unplug eveything and check pins they look fine? Also I switched drivers with passenger side has same issue ?
    driver side was working fine.
  8. Mar 8, 2023 at 1:06 PM
    #218
    Rod702
    Rod702 New Member
    Rod
    Oem
    Both resistors plugged in prior to install. I removed them from truck and put the oem on tail lights in. So xb sitting in box.
    Nbab23 likes this.
  9. Mar 8, 2023 at 1:10 PM
    #219
    Both lights work fine if plugged into drivers side? Do they both hyperflash if plugged into the passenger side?
  10. Mar 8, 2023 at 1:12 PM
    #220
    Rod702
    Rod702 New Member
    Rod
    Oem
    I didn’t plug in the passenger side xb into driver side harness and test it.
    I figured when I plugged in drivers xb light into passenger side harness and it was hyper flashing, figured both units were fine and just that passenger side was problem.
  11. Mar 8, 2023 at 1:14 PM
    #221
    Try both on driver's side and see what happens. Then try both on the passenger side. If they both work fine on drivers side, and both hyperflash on passenger side, then the issue will be on the truck side, not with the lights.
    memario1214 likes this.
  12. Mar 8, 2023 at 1:19 PM
    #222
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I see now, I don't remember plugging my resistors into a plug like that-hence why I didn't recognize it in your first pic. They must have changed their design a bit with those.
  13. Mar 8, 2023 at 3:43 PM
    #223
    Rod702
    Rod702 New Member
    Rod
    Oem
    Ok so I plugged passenger side tail into driver side and with ignition on position engine off headlamps off it would hyperflash.
    With engine on, hyper flash would go away in on/off position with headlamps.
    So it leads to believe me that it’s the truck not the xb tails is problem?
    Also to add, i installed oem tails back on with engine off/on or headlamps off/on I don’t get any hyperflash. So oem tails work fine either way.
    This is driving nuts ! I installed these lights like 3x already.
  14. Mar 9, 2023 at 1:26 PM
    #224
    Rod702
    Rod702 New Member
    Rod
    Oem
    So update, Morimoto got back to me and they are sending me new updated resistor.
    so hopefully this will solve the problem!
    TheBeast, Tundrastruck91 and Nbab23 like this.
  15. Mar 29, 2023 at 9:44 AM
    #225
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Just got an email, 3rd brake light is shipped :yes:
    WILLINH likes this.
  16. Mar 29, 2023 at 10:03 AM
    #226
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Awesome. I ordered mine as well a little while ago. I had one off Amazon I was going to install but didn’t want to take the risk of it burning out like so many others have and having to do it again. Figured I’d go with something higher quality, do it once and be done.
    Y0TA PR0[QUOTED] likes this.
  17. Mar 31, 2023 at 9:12 AM
    #227
    19TundraFRD
    19TundraFRD New Member
    2019 Tundra SR5 XSP
    Just picked up a pair for my 2019 SR5 and only 2 out of the 3 harnesses fit the OEM taillight inputs.
  18. Mar 31, 2023 at 2:47 PM
    #228
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    So finally I get the 3rd brake light.
    But than I also get this email today.
    “We recently discovered that a number of our new X3B Third Brake Lights for the Toyota Tundra accidentally shipped without the threaded mounting studs; preventing users from successfully installing them.
    Since the OEM mounting studs cannot be swapped over from the OEM 3rd brake light, we encourage you to refrain from installing the X3B until these studs arrive.
    We are expediting the hardware from our factory, and it will be shipping out to the affected customers very soon. No action is required on your part. We recognize that you have waited this long for your new X3B to arrive, and we greatly appreciate your continued patience and understanding while we work to deliver the missing hardware.
    Thank you,
    Morimoto Customer Service
    RegGex, Nbab23[QUOTED] and WILLINH like this.
  19. Mar 31, 2023 at 4:36 PM
    #229
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Bummer. Good news is the light looks great though.
  20. Mar 31, 2023 at 4:42 PM
    #230
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I think the smallest plug from the new tail fits into the grey and white one with the two prongs. It’s slides inside it, not the same fit as the factory one but as long as the prongs line up you are good.
  21. Apr 1, 2023 at 8:29 AM
    #231
    19TundraFRD
    2019 Tundra SR5 XSP
    The one I'm having trouble with is the bottom left plug from the new tails is supposed to fit the top right (gray/green) OEM plug, and it absolutely doesn't. The other 2 fit perfect.
  22. Apr 1, 2023 at 3:21 PM
    #232
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Have you tried switching them? Bottom left plug of the tail to the bottom left plug of the truck. Then the bottom right tail plug to the Green/grey one? If that doesn't work I would say outreach to Morimoto for support. I don't think I've heard of anyone needing an additional wiring harness adapter for these.
  23. Apr 3, 2023 at 10:56 AM
    #233
    SkiCoach
    SkiCoach New Member
    Shane
    2017 Tundra CrewMax
    Gator Roll cover and wireless charger
    I installed the XB LED HEADLIGHTS and had no issues with the connectors. Had to think a little bit on the motor controls but everything worked out well. These lights are awesome, well worth the money! I also have no hyper flash without adding any other components. The DRL plug into the fuse box and the white DRL / Yellow signal work great! I also upgraded the taillights and remote brake light. Truck looks great! I am looking to add some additional lights behind my grill with connection to the DRL if anyone has any suggestion.
  24. Apr 3, 2023 at 11:15 AM
    #234
    Rod702
    Rod702 New Member
    Rod
    Oem
    Update: Morimoto got it done. They sent me new updated resistors and it did the trick. No more hyperflash and everything is looking sexy. They are a little slow at replying back, but be patient. They took care of me. Travis is a good dood.
  25. Apr 28, 2023 at 2:08 PM
    #235
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    talking this install in about an hour, seems pretty straightforward. fingers crossed
    Y0TA PR0 likes this.
  26. Apr 28, 2023 at 5:52 PM
    #236
    mista_g
    mista_g New Member
    Damn hyper flash haha. Got both resistors plugged in. Worked fine with hazards. Blinker gives hyper flash. Sigh.
    does it have something to do with me not installing the Morimoto relay?
    installed the gen 2 Xb led headlights two weeks ago. Those ran fine without the aftermarket relay.
  27. Apr 28, 2023 at 6:45 PM
    #237
    mista_g
    mista_g New Member
    Had to drive the truck to work with the Xb tails in. Sometimes it hyper flashes, sometimes it doesn’t haha. So strange. Headlights on sometimes hyper. Headlights off. Left works ok. Right hyper. Hilarious.
  28. Apr 28, 2023 at 8:33 PM
    #238
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  29. Apr 28, 2023 at 9:14 PM
    #239
    mista_g
    mista_g New Member
  30. Apr 28, 2023 at 10:33 PM
    #240
    mista_g
    mista_g New Member
    Just got home from work and driving the truck at night with the tails in. Just want to get this on paper before I forget. Truck in park engine on, headlights off: Hyper flash only passenger side. Headlights on in park, engine on: no hyper flash at all. Truck in drive, headlights off, both sides the same: hyper flash for half a second, then signals work as normal. Truck in drive, headlights on, both sides the same: no hyper flash at all.
    :facepalm:
