No more 130 or 150 amp alternators?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Philcam, Jan 26, 2019.
  1. Jan 28, 2019 at 9:11 AM
    Philcam
    Philcam [OP] New Member
    Yeah. I’m not looking forward to having to pull it off and reinstall.
  2. Jan 22, 2020 at 1:51 PM
    Breathing Borla
    Northern Illinois
    FWIW,
    Im bone stock battery and alt and run two JL-XD 600, no dimming, no clipping, everything runs perfectly, and has for some time.
    hope that helps someone.
  3. Jan 22, 2020 at 1:52 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    AGM batteries are looking for 14v+ to properly charge, not really amps. I don’t believe any upgraded alternator in the tundra is going to be giving you what you’re looking for. If I were you, I’d either be content with a shortened lifespan on an AGM battery (from not getting “topped off”) or be content with charging your battery system. My truck is charged when at home (98% of its life) and it takes me all of a few seconds to connect and disconnect, they come with quick disconnects you can route to easily accessible places. Sure beats 8 hours under the truck swapping out a perfectly good alternator, but to each our own.
    Piki likes this.
  4. Jan 22, 2020 at 1:58 PM
    Breathing Borla
    Northern Illinois
    looks more like an engine block heater plug for the secret diesel sweers has been keeping from us, HEHE
  5. Jan 22, 2020 at 4:11 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I was very happy with my previous setup with the aftermarket 240 amp alternator, 1/0 power, 1/0 ground and aftermarket battery setup. I never had any issues and while running all my aftermarket lights and all my other electrical accessories. My output electrical gauge never budged.
  6. Nov 1, 2020 at 4:42 PM
    Jerry2017QS
    Jerry2017QS New Member
    2017 TRD O/R Quicksand
    You have no idea how happy I am to have stumbled across this thread. I’ve got a 2017 that is making the exact noise you’re describing but I couldn’t really figure out how to put it into words for anyone else. I spent a lot of time with a long flathead screwdriver touching random points on the motor until I felt the rhythmic vibration right off of the alternator!
  7. Nov 1, 2020 at 4:55 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    After researching what I think are the 2 best aftermarket options; Mechman, and DC Power, I chose a 270 amp DC Power. It was due to the pully. On Mechman alts they reduce the size of pully in order to increase amps at an idle. DC Power does not. They keep it stock size, so there s less of a chance the ecu will be affected. https://www.dcpowerinc.com/search?type=product%2Carticle%2Cpage&q=tundra
    TundraLuv likes this.
  8. Mar 15, 2021 at 10:30 AM
    Rocko9999
    Rocko9999 New Member
    Was it like this?
    https://www.youtube.com/watch?v=YCMW4lAye4U&ab_channel=badderthanyou
  9. Aug 24, 2021 at 2:36 PM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    Or if you want a slight upgrade but staying with OEM Denso parts, 27060-38050 is the P/N for the 180 amp alternator out of the 200 series Land Cruiser and Sequoia. That's what I went with in my truck. Direct bolt on, just had to slightly open up the hole in the power wire lug that connects to the post on the alternator. The only real issue is the case for the 180 amp is slightly larger than the 150, so makes it tougher to get back into its space.
    Jack McCarthy, Half Assed and Sundog like this.
  10. Nov 21, 2021 at 9:04 AM
    henryselling
    henryselling New Member
    Henry
    2016 tundra
    Hey bro, so it’s a direct bolt on? No problems? My alternator just crap on me at 58k miles, and I’m looking for an upgrade.
    thanks
  11. Nov 22, 2021 at 10:48 AM
    KingKong
    KingKong New Member
    Asher
    Completely a direct bolt on, only thing I had to do was ream out the wire lug that attaches to the alternator power stud as the one for the 180 amp was slightly bigger than the 150 amp, but that was easy enough to do with a step bit. Besides that, it drops right in!
    henryselling[QUOTED] likes this.
  12. Nov 22, 2021 at 11:10 AM
    henryselling
    Henry
    2016 tundra
    Thanks
  13. Nov 22, 2021 at 11:26 AM
    AZBoatHauler
    So.Arizona
    My bearings started making noise at 5 years old and 63k miles. It has a JL 900 watt amp powering 2 sets of components and 2 10” subs. Truck has seen lots of dirt. Replaced with new OEM 150 amp.
  14. Dec 6, 2021 at 8:17 PM
    Bigbird57
    Bigbird57 New Member
    The 150 is plenty.Do not use a 100 amp alternator. The change out is brutal even if you watch the YT shortcuts.
    These alternators are mounted very low. In wet off-road use I can see where they take a beating. Buy OEM or a very reputable shop who can rebuild an alternator properly.
    Rocko9999 likes this.
  15. Dec 7, 2021 at 8:30 AM
    Rocko9999
    What stinks is many times the bearings are just shot-and finding someone who you can trust to use quality bearings and put back together is harder than just replacing the entire unit. Not many quality shops around in my area at least.
  16. Dec 7, 2021 at 1:03 PM
    Bigbird57
    We have one in Jax, Fl. Hunters on Lem Turner Rd.
  17. Dec 19, 2021 at 4:16 PM
    CSB
    CSB New Member
    CSB
  18. Jan 8, 2023 at 9:24 AM
    CSB
    CSB New Member
    CSB
    My 2019 Tundra Limited was scheduled in production with the HD 170 Amp alternator; however, Toyota parts group does not sell a replacement, only the 150 amp unit. I like to have a spare.
    I could go up to 250 with an after market from LAelectric when it is time to replace it, existing wiring will handle it, however, I would rather stick with the original amperage (170). I can’t seem to find it anywhere at 170 amperes. I saw that the Sequoia has a 180 amp unit (2706038050) for the 5.7 (3URFE). Does anyone know if it will fit/work?
