OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. Dec 25, 2021 at 7:55 AM
    #271
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Mine does the same thing. Never opened a ticket though. Looking forward to hearing what you find out.
    Merry Christmas.
  2. Dec 25, 2021 at 9:27 AM
    #272
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    TPMS seems to be the most problematic. I presume it is the way the Toyota modules work as I have had zero issues with nonToyota vehicles.
    I don’t like that you can’t be connected to the TPMS module and the other modules simultaneously.
    May be posted earlier in this thread but this gave me the best of luck but still inconsistent and I have to be driving for little while to get a reading.
    https://www.4runners.com/threads/obdlink-mx-for-realtime-tpms-psi.12521/
    TTund16 and omgboost like this.
  3. Jan 18, 2022 at 1:28 PM
    #273
    DirtE30
    DirtE30 New Member
    Brandon
    ‘19 TRD PRO CM Midnight Black
    Under seat storage, MaxLiners, 295/70-18 G2’s, swing out tool box, Toyota tri fold, tailgate pop lock, remote start, bed lights, Intake Mod, TRD filter.
    so to be clear, which PID wasn’t functioning with your older OBD2 adapter and exactly which one did you get that is now allowing all PID’s to function? I cannot get my Pan Temp PID to read on my ‘21 Pro when it worked fine on my ‘19. I can get TC outlet temp to read just fine. What’s weirder is that when I test in the editor, the result of the test is correct but the “result” reading is always 0.
  4. Jan 20, 2022 at 8:06 AM
    #274
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Try going back one year to 2020 when you select your vehicle. I had a similar problem when bought my 2020, I chose 2019 and it worked. Did you buy the Toyota enhanced?
  5. Feb 3, 2022 at 11:33 AM
    #275
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Are there any separate displays that can be used beside the phone to display the PID's? I have read somewhere someone used a iPod to do this, is that right?
  6. Feb 4, 2022 at 1:53 PM
    #276
    Mobeyk
    Mobeyk New Member
    Thanks for this thread. I bought the Veepeak BLE plus and got the OBD Fusion app. Played a bit around and set up a dash. Here my dash I came up with. Of course this is my first setup after what I learned on this thread. I can tweak it further.
    I know some of you guys got the add on. What exactly does the add on provide? I was looking spec. for the Trans temp. I see that you can go by model and year. Just wanted to see if its really that much more useable data on the add on. I read on here that you can add user defined pid's and a user defined pid for trans pan temp but wanted to make sure if its covered with the add on after knowing if the add ons are worth it.
  7. Apr 13, 2022 at 11:22 PM
    #277
    White Puff
    White Puff New Member
    Can anyone share their screenshots or data in regards to how the 2 upstream o2 sensors running by graph? I need a baseline to troubleshoot from.
  8. Apr 14, 2022 at 5:29 AM
    #278
    Jamyers13183
    Jamyers13183 New Member
    Houston
    i would really like to clean mine up to look like that. Please take a screenshot of the status of the lockup settings
  9. Apr 17, 2022 at 11:12 AM
    #279
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Screenshot_20220417-131101.jpg Screenshot_20220417-131044.jpg Screenshot_20220417-131033.jpg
    Galladanb and mtucker like this.
  10. Apr 26, 2022 at 7:47 PM
    #280
    Ranjit
    Ranjit New Member
    Hello Fellow Members,
    Can Someone help me with PIDs Used in Tundra 2010 for Odometer and Engine Hours?
    ELD Device that is attached is not able to read these two parameters.
    Your help would be greatly appreciated.
  11. Apr 29, 2022 at 12:43 AM
    #281
    l0cate
    l0cate 2015 SR5 TRD factory upgrade
    Christopher
    Vancouver, WA
    2015 Tundra Crew Max RWD
    Factory TRD upgrade, KYX nerf bars, RC grill, hidden bumper LED, ditch lights, LED upgrades on all lights
    This one seems to work for me. Unless it's reading something else.
  12. Apr 29, 2022 at 7:11 AM
    #282
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    My engine oil is always reading within 1 degree of the transmission pan temperature. I think it is the estimate, not an actual sensor reading.
    TTund16 likes this.
  13. Aug 2, 2022 at 4:17 PM
    #283
    bflooks
    bflooks New Member
    Metrowest MA
    Could someone post up what their coolant temps read when using the purchased Toyota PIDs? I'm trying to tell if the coolant temp option is correct or if I need to manually add a PID.
    Reason I'm asking is per the app, just driving around town I'm between 201 and 214. Per Toyota, normal is 176-183.
    Update: purchased Coolant Temp PID is correct and proved a thermostat issue. Truck is now running 188-192 on average. Thermostat is 185 degrees.
  14. Aug 5, 2022 at 12:45 PM
    #284
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    For anybody using Torque app, can confirm buying the additional Toyota plugin will give you current gear info and TC lockup.
    Will get screenahot from other phone that app is loaded on.
    (Crappy pic with the glare and reflections)
    snivilous likes this.
  15. Aug 8, 2022 at 5:53 PM
    #285
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Will OBD Fusion connected to a Veepeak BLD+ allow you to program fobs for a 2011 SR5?
  16. Sep 23, 2022 at 7:24 AM
    #286
    seydou
    seydou Distinguished Member
    Does anyone know if the pitch and roll displays are available for Fusion or OBDlink?
    I can find the PIDs but have to "force" them into one of the standard display options and not the style with a vehicle image that is commonly used.
  17. Oct 27, 2022 at 11:37 AM
    #287
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Reworking my OBDII reader after purchasing the Toyota add ons thru OBD fusion. Using veepeak dongle. I cannot find the gear indicator pid referenced earlier in this thread. SS of the exact list missing the one that others are using for gear indicator (status of shift change 1, 2, 3 etc) and the display config Im currently using.
    Screenshot_20221027-143438.jpg Screenshot_20221027-142646.jpg Screenshot_20221027-143446.jpg
  18. Oct 27, 2022 at 6:02 PM
    #288
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    running exact same setup as you. odb fusion with toyota add ons
    pid is "status of the shift status / 1st, 2nd, 4th, 5th, 6th..."
    its in the menu "engine and electronic controlled transmission"
    Galladanb likes this.
  19. Oct 27, 2022 at 7:41 PM
    #289
    Ckatz53
    Ckatz53 Newish
    MD
    I still don't see or have that. Whether scrolling or search function. "Shift status" under engine/ect seems to do the trick for me though. TC lock up status appears above the gear indicator when it's active.
  20. Oct 28, 2022 at 2:26 PM
    #290
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    On my 2021 I don't have the "Status of shift status..." either but I do have the "Shift Status" as well and that works for me also.
    Ckatz53[QUOTED] likes this.
  21. Nov 15, 2022 at 7:40 PM
    #291
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Which PID from toyota would one set up for fuel density learning value per the FFV tundras out there that possibly give you exact number per percentage? Curious if anyone has already set this up with obd fusion app?
    Alcohol density estimate and Long FT #1#2???
    Has anyone set this up all in a arc guage per obd fusion?
  22. Nov 29, 2022 at 5:35 AM
    #292
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    @BiggHertz check out this thread for the PIDs you are seeking.
  23. Jan 3, 2023 at 5:18 PM
    #293
    TiluDrop
    TiluDrop New Member
    Scott
    2022 Tundra Limited TRD Lunar Rock
    Would anyone here have info on the Gen 3 Tundras? I'm looking to add Trans Temp and a few other things to my 2022 Tundra, but need a PID.
  24. Mar 23, 2023 at 11:37 AM
    #294
    Ancient commentary here but I'm bumping it maybe for posterity or something...
    Not sure if it helps, but I recently had my TPMS light flashing, and like you, have the OBDLink MX+. I decided, "wtf, let's dig around" so I fired up OBDLink iOS app, I loaded all the custom PIDs offered for Toyota, connected to the MX+ via Bluetooth, then at the connection screen, told it to connect into the TPMS Network specifically.
    From there, I was able to scan all the TPMS info, see at least two of my five sensors (4+spare) aren't reading, fetch all my sensor info and output, then clear the two diagnostic codes which were set on those two unreadable (probably dead battery) sensors. Interestingly enough, no more TPMS errors, and no more flashing TPMS light.
    I did notice, the pressures (which were represented in mercury inches/Hg versus PSI) seemed a bit off to me also. I'd inflated all tires to 33psi just before this. Anyway, here's a quote of my post over in the 1st Gen forum, along with the screencaps and other crap I shared with the dudes over there if it's interesting.
    (NFN: I do really like the OBDLink MX+ tool. Connectivity is weird, and you need to be careful not to buy fakes if purchasing from scAmazon, but it's been solid so far)
    EXPAND THIS QUOTE FOR PICS AND INFO:
    TTund16 likes this.
  25. Mar 23, 2023 at 6:14 PM
    #295
    Black
    Thanks. I have not had a chance to just sit around and fool with it.
    Hopefully tomorrow I’ll read through your suggestion and get a chance to mess with it.
  26. Mar 23, 2023 at 6:16 PM
    #296
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Mine recently updated and I no longer see oil temp and it’s not coming up as an option. Anyway to add it manually as a user defined? Obd fusion app with dongle
  27. Mar 24, 2023 at 5:14 AM
    #297
    coTony
    Tony
    Montrose, CO
    Each time I try to go through everything I get interrupted with something else. I did not know it would take all that time. Too busy with work and projects I guess. I will get it eventually for my 2018 but yeah… never really got anything worth looking at yet
  28. Mar 24, 2023 at 5:22 PM
    #298
    Red406Tundra
    Red406Tundra New Member
    Billings, MT
    2019 Barcelona Red SR5
    Damn that looks great. I can’t seem to figure out how to change my gauges to look like that.
  29. Apr 19, 2023 at 2:25 PM
    #299
    coTony
    Tony
    Montrose, CO
    Ok I have everything working it appears but the refresh I guess is what it is for all gauges has a slight pause it seems then all updates at the same time... At least it works.
    What I do not have under control is the gauge for the what gear your in and the lock up ring. I simply cannot find the "Status of the Lock Up" anywhere in my list of PIDs and the "Status of the Shift Status/1st,2nd,3rd,..."
    Can someone help with which block of PIDs these are found in for a 2018 Platinum? I have purchased the Enhanced Package already but I cannot find the PID to select. I dug through everyone of them.
    I am doing all of this sitting in front of my computer and digging through the app on my phone. I am reading online trying to learn more about this but feel like an idiot. I understand for the two different one displaying on the same gauge is pushing to front/back to control which one you are working with but again I cannot find these last two. Do I have to be connected to my truck with it running for it to find them? I never had to do that for any of the others (7 gauges total). So close
  30. Apr 20, 2023 at 4:03 AM
    #300
    Gaston
    Gaston New Member
    Gary
    SE MI
    You do not need to be at your truck with it running and connected to find the PIDs
    I know when I was setting mine up the PIDs were slightly different than what I was seeing others use. For example, my lock up ring is using PID "Status of Lock Up / OFF or ON" and my gear gauge is using PID "Shift Status". Your year might use a different label for the PID, I'd just setup a 2 or three gauges with different options and go for a quick drive and see what works and what doesn't.
    Try going into the PID menu, select the Toyota. Lexus, Scion extension you purchased, select Engine and Electronic Controlled Transmission and in the search bar type "Status" and search. That'll help narrow down the list of items, both of mine show within the top 20 or so items.
    coTony likes this.
