Occasional blue smoke upon start up w/ 5.7L?
Discussion in '2nd Gen Tundras (2007-2013)' started by Mikelb01, Nov 5, 2019.
  1. Dec 10, 2023 at 6:50 AM
    Wallygator
    Start changing your oil every 5000 miles if you don't now. Possibly the beginning of a stuck oil ring. Mine blew a little smoke also. Then I put an oil flush in and now change the oil every 5000 miles. No smoke since starting this. Most of our trucks meet the severe duty maintenance cycle that is in the owners manual.
    2mchfun likes this.
  2. Dec 10, 2023 at 9:21 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Yeah, I have been since new. But for the first few years it wasn’t getting many miles on it. I’ll just start keeping an eye on it.
    Wallygator likes this.
  3. Dec 10, 2023 at 10:30 AM
    Wallygator
    May want to try a flush then right before your next oil change. Hope it resolves for you.
    https://www.amsoil.com/p/engine-and-transmission-flush-flsh/
  4. Dec 11, 2023 at 6:21 AM
    SnrDisregardo
    Wade
    IL
    I was thinking the same. I'm using HPL 5W20 right now. It cleans really well on it's own. It could be the temperature flux's we've been having in the Chicago area. 30's one day, 60's the next. That with a bit of thicker oil may be contributing.
  5. Dec 11, 2023 at 1:53 PM
    SnrDisregardo
    Wade
    IL
    Reading another thread, now I'm overthinking. I did an oil change not long ago, added the appropriate quarts, never checking the dipstick. Fast forward to a month ago, I get a hair up my ass to take a look at the dipstick and it's bone dry. I start worrying and thinking back to never seeing the gauge low. So I add until I get a reading. Could it be there is too much in there now?
  6. Dec 11, 2023 at 1:55 PM
    From full mark down to not touching the dipstick is a difference of 3 qts or so. You leaked or burned three quarts since your oil change?
  7. Dec 11, 2023 at 2:40 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Blue smoke on start is most certainly an indication of worn valve stem seals. On any engine.
    ZappBrannigan likes this.
  8. Dec 12, 2023 at 5:36 AM
    SnrDisregardo
    Wade
    IL
    Yeah, without a spec in my garage. And I added what the manual said. I'm thinking of just dumping it all and starting over. I've read on here that the dipstick isn't necessarily accurate.
    It's only happened twice. Last time was Saturday. Since then it hasn't happened. Just keeping an eye out.
  9. Dec 12, 2023 at 5:45 AM
    to be fair, you never checked the dipstick after filling it at your last oil change. Maybe you only put a 5qt jug in?
  10. Dec 12, 2023 at 6:03 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Be sure your truck is dead level when checking the oil. Just the slightest grade will throw off the readings badly. My driveway can swing it from low to full based on how I park. I have to pull it into the garage to get an accurate reading.
  11. Jan 22, 2025 at 12:20 PM
    TundraLuvr2017
    TundraLuvr2017 New Member
    I had similar issue and back in Sept-2024, I installed J&L catch can. Before I did, I remove the PCV value and cleaned it. Months later, I notice very hard start in the cold mornings and did other research and replace PCV due to it may be stuck open. It appears my theory was correct. With 128k on my 2017 Tundra Platinum, when you shake the old PCV it didn't move much. Of course the new one does. I started my truck in 32 degree weather, it appears no more hard start but also blue smoke again. I will monitor over the next few days to see if everything got out of the system where it shouldn't be.
    I have to say on my 2006 Tundra that I had, I've had less issues. But still loving the 2017.
    Again to my dismay, I saw a youtube video and this dude was talking about Flex Fuel and non Flex Fuel. I thought I had non-Flex but finding out now that it is Flex Fuel. ;-(
    Still no E85 for me!
  12. Jan 24, 2025 at 2:35 PM
    Wallygator
    What is your oil change interval?
  13. Jan 25, 2025 at 4:43 AM
    TundraLuvr2017
    Every 5k.
    Changing the PCV worked!
    ZappBrannigan and Wallygator like this.
  14. Feb 28, 2025 at 1:19 PM
    Troubleshooter
    Troubleshooter New Member
    Sam
    2018 tundra limited
    Have 2018 tundra, 44k. Just blew puff of blue smoke. Dealer maintained. Headed to appointment now.
