OEM Dash cam
Discussion in '2.5 Gen Tundras (2014-2021)' started by GCanuck, Dec 24, 2021.
  1. Dec 29, 2022 at 10:31 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Yes, it automatically turns on with the ignition and records in a loop. It's been a minute since I looked at the setting but I think you can set the length you want you videos to be, if I recall correctly mine are 1min long each. Front and rear videos are separate videos, though when you are viewing the live feed through your phone it is a picture-in-picture, rear camera smaller in the lower left of the screen with the front camera in the back taking up the entire screen.
    MadMaxCanon[QUOTED] likes this.
  2. Dec 29, 2022 at 10:37 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    If you are looking on their website, I never did see one on there, I ordered mine through Amazon
    https://www.amazon.com/gp/product/B0B399PKZD?ie=UTF8&th=1
    As for power, you get power from behind the plastic piece behind the rear view mirror, where the rear view mirror gets power from. You unplug that connection and place a hardness between, allowing the mirror to function as normal and also supply power to the cameras. It's a very simple and clean install, longest part is the time it took to run the wire to the rear camera, no running wires for power.
    bulldog93 and Rocko9999[QUOTED] like this.
  3. Dec 29, 2022 at 2:03 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How and where did you power the rear camera?
    Is the 50 dollar difference between 4k and 2k worth it you think?
  4. Dec 29, 2022 at 2:16 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I love my Thinkware Q800Pro (it included front and rear cameras). I hardwire it myself, easy peasy.
  5. Dec 29, 2022 at 4:23 PM
    Rocko9999
    Rocko9999 New Member
    Thanks. My mirror has no power-SR5.
  6. Dec 29, 2022 at 4:31 PM
    MadMaxCanon
    What year? I have an sr5 and it has power rearview and homelink.
  7. Dec 29, 2022 at 4:44 PM
    Rocko9999
    2014. Just has the 'way too small' mirror that's actually delaminating. I'd love Homelink.
  8. Dec 29, 2022 at 4:52 PM
    MadMaxCanon
    Oh ok makes sense think they made it standard only in last few years
  9. Jan 8, 2023 at 2:50 PM
    cjscinta
    cjscinta New Member
    Nashville TN
    I have a 2017 trd pro. I ordered this camera fitcamx from the link above and it doesn’t seem to fit. My mirror is powered but I only have a small cover behind the mirror that must not be compatible with the new cover even though the product description says it will fit. Anyone else experience this?5632461A-DABE-413A-BF1C-EC92E2BDB174.jpg
  10. Jan 9, 2023 at 10:09 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Sorry, I didn't see the notification on this post. Honestly, I don't think so. The 2K Front + 1080 Rear option wasn't there when I ordered or I probably would have gone with that option.
  11. Jan 9, 2023 at 10:20 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I'm not 100% sure but I believe the plastic housing the FitcamX system replaces is a cover to the AHB (Automatic High Beam) Sensor which is apart of the TSS (Toyota Safety Sense) and that was introduced to the Tundra in 2018. So that is probably why yours looks different, they should update their description to note 2018-2021 model years only.
  12. Jan 9, 2023 at 12:53 PM
    MadMaxCanon
    I was thinking you probably can't read plates with either one so just save some cash.....
  13. Jan 9, 2023 at 12:55 PM
    MadMaxCanon
    I have a 21 SR5 and my cover is smaller than what they show so it wouldn't fit either. Bummer.
  14. Jan 9, 2023 at 5:15 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    what does yours look like?
  15. Jan 9, 2023 at 5:19 PM
    MadMaxCanon
    It looks similar to what they show just like half the size....
  16. Jan 9, 2023 at 5:27 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Hmm, ok, I guess I haven’t paid attention to that area on other Tundras
  17. Jan 17, 2023 at 5:14 PM
    GCanuck
    GCanuck [OP] Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I went with a VIOFO and a dongle adapter for power.
